URD 2.8 Supercharger Pulley Installation Vid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rat107, Jan 27, 2017.
  1. Jan 27, 2017 at 5:00 PM
    rat107
    rat107 [OP] Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
  2. Jan 27, 2017 at 6:24 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Nice. The breaker bar in the puller for removal was smart. You make it look very easy putting the new pulley on.
    rat107[OP] likes this.
  3. Jan 27, 2017 at 10:52 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    this is awesome, thanks. you saved me frustration and busted knuckles, no doubt.
  4. Jan 27, 2017 at 11:19 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  5. Jan 28, 2017 at 6:11 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    Did you leave the little bolt in the end of the supercharger when pressing the pulley on? Did that lil bolt come with the pulley? Bout to order mine
  6. Jan 28, 2017 at 9:14 AM
    rat107
    Kauai, HI
    No, the bolt was removed. The bolt came with the URD installation tool. You may need to hold the snout shaft with a small strap wrench when removing the bolt.
  7. Jan 28, 2017 at 9:49 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I bought a "boa" strap wrench from Amazon for this. Worked great
  8. Jan 29, 2017 at 9:01 PM
    Blacktaco2042
    wisconsin
    You heat up the pulley before install or just install at room temp
  9. Jan 29, 2017 at 9:20 PM
    rat107
    Kauai, HI
    Room temp and it went on fine. Engine was cool.
  10. Feb 1, 2017 at 11:44 PM
    sawjai526
    sawjai526 Well-Known Member
    vincent
    Bayarea, CA
    15 DCSB OR 6spd
    did u lube shaft before pressing in the pulley?
    you make it look very easy, haha. nice video!
  11. Feb 2, 2017 at 12:40 AM
    rat107
    Kauai, HI
    Thanks! Yes, lubed lightly with motor oil.
    sawjai526[QUOTED] likes this.
  12. Feb 2, 2017 at 1:20 AM
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    Did you also heat up the pully?
  13. Feb 2, 2017 at 1:52 AM
    sawjai526
    vincent
    Bayarea, CA
    15 DCSB OR 6spd
    he didnt heat it up, just installed it, @ ambient temperature
    StOrMyThEtAcO[QUOTED] likes this.
  14. Feb 2, 2017 at 7:46 AM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    gawd dang you made it look too easy. between the pulley and the fuel pump I was worn and stressed out..........
