URD 2.825" Pulley for TRD S/C
Discussion in 'Performance and Tuning' started by BradleyJ33, Apr 18, 2012.
  1. Apr 18, 2012 at 7:03 AM
    BradleyJ33
    BradleyJ33 [OP] Geaux Tigers
    Brad
    Brandon, MS
    2010 TRD Sport 4x4 DCSB S/C'd
    TRD Supercharger with URD 2.825" Pulley, Toytec Ultimate Lift, LR UCAs, BFG All Terrain 275/70R17s on Procomp 7089 17" wheels, BAMF rock sliders, Viper 5902 alarm/remote start with smartstart, Pioneer Avic-Z110BT dvd/navi head unit, 2 Pioneer 7" monitors in headrests, 2 Rockford Fosgate Shallow-mount 10" subs pushed by RF Punch 500.2 amp, RF 5.25 components (front doors) and 5.25 full range (back doors) pushed by RF Power 400.4 amp, sound deadened, Whistler pro remote radar detector, scangauge II, debadged, Sockmonkey decals, blacked headlights with FX-R projectors, DDM Tuning HID fogs, Grillcraft upper and lower MX grill with Hella 500ffs converted to HIDs behind, AFE Stage 2 Cold Air Intake, Walbro 255 Fuel Pump upgrade, Dynomax Super Turbo muffler, Bestop Supertop, Wet Okole seat covers, Weathertech floor liners, Pop & Lock tailgate handle, Lighted 4x4 switch mod, 2 110v AC outlets in cab mod, Always at 400W mod, Maplights on with dome light mod, homelink in headliner mod, foglight
    If I want to upgrade to the URD pulley on my TRD S/C for a little extra boost, is there any further tuning that needs to be done or is the stock re-flash for the S/C sufficient? I'm interested in adding a little extra "oomph", but not real keen on the idea of dropping $1500 for the UCON just yet after just dropping the cash for the TRD S/C. Thanks in advance!
  2. Apr 18, 2012 at 5:12 PM
    grant99
    grant99 Well-Known Member
    London, ON
    05 4DR TRD Sport 6SPD
    from what I have seen you can run it without any special tuning. however its always best to tune for the specific set up to get the best out of your mods, not to mention its the safest option. I will be running my pulley for a bit before I install my X1. Any other mods than the SC?
  3. Apr 18, 2012 at 5:30 PM
    BradleyJ33
    Brad
    Brandon, MS
    Yeah, just a dynomax muffler and CAI, and will be installing the Walbro fuel pump upgrade soon. Not a whole lot of stuff, but the X-1 isn't an option for me as I have a 2010, and the UCON doesn't cover the 09 and up yet either...
  4. Apr 18, 2012 at 8:35 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The 2.85 pulley is great with the reflash... Anymore boost from nst though would need additional tuning like the x1 or ucon... Get some dtlt's already...:cool:
  5. Apr 18, 2012 at 9:11 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I am currently running the 2.85" pulley without any other reflash and the thing is a fucking beast. It seriously wakes up the supercharger. Currently the only tuner for our trucks (2010) is the Un-i-chip as no one else has a plug and play set up for our trucks due to toyota not releasing the plug specs so no can make one.
    Go for the pulley, installation is easy, jsut follow the ones provided and go for it. I havent had a single problem with mine and I drive/wheel mine hard.
  6. Apr 19, 2012 at 4:36 AM
    BradleyJ33
    Brad
    Brandon, MS
    Ya'll sold me on it! Gonna place my order this afternoon! :burnrubber:
  7. Apr 19, 2012 at 4:44 AM
    extremachn1
    Turd Furgison
    Tucson, AZ
    Get the URD installation tool as well. It will make your life so much easier.
  8. Apr 19, 2012 at 2:05 PM
    BradleyJ33
    Brad
    Brandon, MS
    Got both the pulley and the installation tool headed my way :D
  9. Apr 19, 2012 at 5:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You can also run that pulley you just ordered, as well as the NST lower s/c pulley, on the reflash. That will put you ~ 10ish psi. But...... You have to move a vacuum line. o_O
  10. Apr 20, 2012 at 5:46 PM
    grant99
    London, ON
    is 10psi safe on a stock block? seems high for a NA block, not that I really know much about the stock internals of a 1gr). Would it be reliable, meaning could you DD it for 50K-75K without a motor build?
  11. Apr 20, 2012 at 8:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How often does the driver have to floor the skinny pedal? o_O
  12. Apr 20, 2012 at 8:21 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The stock reflash is gonna be cutting it damn close to getting out of spec with that much boost... I'll let Tor explain this one though
  13. Apr 20, 2012 at 8:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    May I present sdxrunner619? .....
    I will let that sink in a little before I continue....
  14. Apr 20, 2012 at 8:38 PM
    memario1214
    Colton
    Missoula, MT
    I know that he makes it work. It still scares me though
  15. Apr 21, 2012 at 4:28 AM
    grant99
    London, ON
    sorry new to the forum, don't know who sdxrunner619 is. But by his signature its seems that his truck is an xrunner and, most XR owners I bet he treats it like a car, mine however is pulling at least one quad most weekends, a 20' enclosed car trailer about once a month and hopefully a boat in the future, along with running 4X4 thru snow/etc. Now, could this be a DD set up with a stock motor? I don't drag race my truck, I have cars and a bike if I want to do that, but I do think I work my truck (like a truck is meant for) and I would like it to have a bit more power for that
    I have contemplated getting another motor as a failsafe or build motor, but contemplating and forced too are two different things
    thanks for your input
  16. Apr 21, 2012 at 6:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Being concerned for one's investment is always good.
  17. Apr 21, 2012 at 7:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Let's go back a little bit. To the original question. ~8 psi on the reflash? Simple. Only thing necessary is a fuel pump upgrade. Two things usually have happened when people start to boost. One, their factory fuel pump hasn't been under the regular service interval. At 30k. Why would it have been in the first place though? Most are running fine still at that point. So, the factory fuel filter is fairly clogged. Would not even be noticeable until the pump is required to push more fuel for boost.
    Two, the factory fuel pump is barely rated for 6 psi, at WOT, higher rpm range. Couple that with a clogged filter, and 6 psi of boost could cause detonation to blow the rings or head gasket.
    Solution, upgrade the pump to, at minimum, a Walbro 255. I recommend the HP unit, for those that are trying to push past 10 psi, with rising fuel pressure. www.urdusa.com has a nice kit with instructions. Their 255 lph is the non HP version. It likes static fuel pressure. 12 psi increase of fuel pressure on that pump will cause fuel flow fluctuations. Either pump, at static 43.5 psi is capable of around 700 whp. Add the inline fuel filter that is easily changed within minutes vs the factory one which needs the tank to be dropped, as well as the whole unit to be replaced for $450+ , and you see that it is a no brainer.
    www.Dezod.com sells them for the Tacomas as well.
    Now that you have fueling coverd for boost, 14 psi boost at static pressure, then it comes down to the injectors flow capability. The 425ccm injectors that come with the TRD s/c kit, are rated to effective 400 crank HP, at 43.5 psi. Well my friend didn't have the money to purchase an aftermarket EMS. He said that at 8 psi boost, he was having certain AFR fluctuations. He is also a Toyota mechanic in training. I told him to run a vacuum line from the point on the s/c where the boost gauge hose ties in, to the factory fuel pressure regulator. Oddly enough it isn't used in by the way the factory setup the hose to it.
    From that nipple on the s/c, his FPR now sees vacuum and boost. So for each psi of boost increase, his fuel pressure also increases as well, to make the 425cc injectors able to flow more. His AFRs are now smoother than they were before, and he was even now running rich at 8 psi. Being that he likes to push the envelope, he decided to add the www.nonstoptuning.com lower s/c pulley. The added boost raised his AFR to be mid to low 11's. Perfect.
    The point of all of that is this alone. He abuses the crap out of his truck, since he drift races it. Always at the high end of the rpm range. Plus it is his DD. It is a stock block. He also has a T-stat mod that I did for him, to keep his engine nice and cool, to aid in knock prevention. It works very well, i must say. He has been going strong since February at 10 psi on his stock block, on the reflash.
    Aside from him, there are tons of people running 10 psi, and have been for a long time with the addition of some aftermarket EMS. All on stock components.
    Two things will tear apart a stock block. Knock, and raised rpm over stock for a length of a few years.
    I hope that helps.
  18. Apr 22, 2012 at 4:29 AM
    grant99
    London, ON
    ya sorry to get swerve from the OP's question. I do appreciate the response, there is a lot of great info in there
  19. Apr 22, 2012 at 10:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    All about sharing the knowledge in depth as possible, so that others can learn as well. Educated over biased assumption. :thumbsup:
  20. Apr 24, 2012 at 6:25 AM
    ModernPopeye
    ModernPopeye Well-Known Member
    Hampton Rds,Va
    12 DBL Cb Sport LB
    DAMN I LOVE ANSWERS LIKE THIS !:thumbsup:
