Urd 3x clutch and light flywheel shutter ,help !
Discussion in 'Performance and Tuning' started by Honda400ex66, Mar 2, 2014.
  1. Mar 2, 2014 at 8:07 AM
    Honda400ex66
    Honda400ex66 [OP] Member
    Nova Scotia
    07 tacoma 6" pro comp ,king coils supercharge
    I have an 07 tacoma with the trd supercharger exhaust intake ,I recently installed a 3x clutch and lightened flywheel I took it easy for a few hundred km , but have been trying it out with launches and hard pulls , it makes a whining noise when launched hard , and shutters almost like it's slipping anyone have any idea what I should do ? Or what is wrong
  2. Mar 2, 2014 at 8:26 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Call Gadget at URD
  3. Mar 3, 2014 at 8:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How many miles did you put on it before you started launching on it?
  4. Mar 4, 2014 at 5:52 AM
    Honda400ex66
    Nova Scotia
    About 200 city miles everything works great untill it's under a lot of pressure
  5. Mar 4, 2014 at 6:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Five hundred is the average number of miles for break-in. Before you get on it. Better take it easy for another 300 or so.
    Did you adjust the push rod underneath the clutch pedal? There should be about 5mm play between the pedal and top of the rod.
  6. Mar 4, 2014 at 12:59 PM
    Honda400ex66
    Nova Scotia
    I'll have too check that out tonight , do you think it should work it's way out , I have over 500 miles on it now
  7. Mar 4, 2014 at 7:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    See if you can get a video clip. Post it up.
    You shouldn't hear the clutch when it is engaged. Only during engagement.
    I would also double checl all of the bolts under there. If you are having vibration issues, it could be the driveshaft, carrier bearing, or that something was under/over torqued on the clutch/flywheel.
    Did you get the ARP hardware?
  8. Mar 10, 2014 at 1:10 PM
    Honda400ex66
    Nova Scotia
    Yes I did get the arp hard wear , I'll see
    If I can get a video in the next couple days
  9. Mar 15, 2014 at 7:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Updates?
  10. Mar 29, 2014 at 2:04 PM
    Honda400ex66
    Nova Scotia
    Can't upload the vid I Tryed said invalid file , trying from my iphone , help ? Sorry so late too reply I was away for work
