URD 70mm Throttle body
Discussion in 'Performance and Tuning' started by Super Werty, Apr 30, 2013.
  1. Apr 14, 2014 at 5:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    2007 5.7L Tundra. T.B. P/N 22030-0s010. Same P/N for other vehicles with the 5.7L.
  2. Apr 14, 2014 at 9:06 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    So what is the difference between that one and 2203031010?
  3. Apr 14, 2014 at 9:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I don't know what your part number is. Not without looking on Toyota's database. The one I posted is from my friend at Toyota.
  4. Apr 14, 2014 at 11:26 AM
    FreidTaco
    FreidTaco boost
    jeff
    Is that the one you are running?
  5. Apr 14, 2014 at 12:02 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Posts edited.... Wrong place
  6. Apr 14, 2014 at 12:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not yet.
  7. Apr 15, 2014 at 6:58 AM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    From what I have found These are the P/N For those interested.
    65mm Tacoma Throttle Body - 22030-0P010
    70mm 4runner Throttle Body - 22030-31060
    70mm Fj Throttle body.........- 22030-31060
    76mm Tundra Throttle body - 22030-0s010
    MadTaco461 and zerotimeouts like this.
  8. Apr 15, 2014 at 7:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You the man :thumbsup:
  9. Apr 15, 2014 at 8:51 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Anyone have any actual HP & TQ numbers using one of these with a TRD S/C? Also does anyone know if the inlet on the TRD S/C is 65mm or can be enlarged to match the URD adapter plate and 70mm TB?
  10. Apr 16, 2014 at 5:24 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    SC inlet is just like the NA stock one so plate adapter is a direct fit.
  11. Apr 16, 2014 at 12:13 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Right so if the S/C inlet is 65mm and the urd adapter plate is 70mm and the throttle body. Then you would need to open up the S/C inlet to 70mm to alleviate the restriction. But can it he done is their enough material?
  12. Apr 16, 2014 at 2:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  13. Apr 16, 2014 at 6:35 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
  14. Apr 21, 2014 at 7:54 AM
    Vassily28
    The plate is an adapter with diameter of 70mm to 65mm.
    Even at 70mm, the throttle body is still probably the more restrictive componments. The more restrictive parts are elbows, reducers, and valves like the thorttle body. A larger area will reduce air speed trough the TB and then the pressure loss.
  15. Apr 21, 2014 at 7:11 PM
    #35
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    22030-31060 thats for 2010 4Runner TB.
  16. Apr 21, 2014 at 7:27 PM
    #36
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Ditching the adapter plate and opening up the inlet on the supercharger to 70mm to match the throttle body would be getting rid of a reducer. But I dont know how beneficial it would be vs. using the adapter as far as money & time vs. performance gains.
  17. Apr 29, 2014 at 10:46 AM
    #37
    FreidTaco
    FreidTaco boost
    jeff
    Will part number 22030-0F010 work?
  18. Apr 29, 2014 at 3:37 PM
    #38
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Your best bet would be to call/ message Gadget @ URD.
    That part number is the throttle body for the 4.7L V8
    I do not know much about the 4.7L
  19. Apr 30, 2014 at 7:48 PM
    #39
    Super Werty
    Super Werty [OP] Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    That wont work.
    The 4 bolt pattern of the 70mm is spread out farther than the 65mm throttle body.
    So you need the adapter still if you want a 70mm with the TRD blower.
    I dont know what the opening of the TRD blower is but I bet its 70mm+
  20. Apr 30, 2014 at 8:40 PM
    #40
    FreidTaco
    FreidTaco boost
    jeff
    I emailed him but have not gotten a response. Not a big deal.
