URD 70mm Throttle body
Discussion in 'Performance and Tuning' started by Super Werty, Apr 30, 2013.
  1. May 11, 2016 at 7:21 PM
    #141
    clupi
    clupi Well-Known Member
    Sacramento Ca
    07 taco 4x4
    I can't complain, and if is the same guy we are talking about... in the end I was still ok since these are hard to come by in good condition. I didn't have to spend all the $40+- but I'm a little picky with my stuff and wanted it to look clean
  2. May 12, 2016 at 12:20 AM
    #142
    1slowvq37
    1slowvq37 Well-Known Member
    Jose
    Tecate BC MX / Chula Vista CA
    bone stock superwhite trd sport
    new car smell pine
    For those of you with the 70/76mm throttle body, how is you MPG? I want to do this mod but I have read mixed reviews like this one :
  3. May 12, 2016 at 12:25 AM
    #143
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    I installed the 76mm and the IMS spacer from @highaltitude at the same time-ish and gained more low end power from the spacer and 1mpg. Then the throttle body gave quicker thistle response and .5-1mpg more on top of that. With running 35" tires and 4.56 gears I was getting 14.5-15.5 mpg steadily.
    1slowvq37[QUOTED] likes this.
  4. May 12, 2016 at 7:15 AM
    #144
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    4Runner members complain more about performance mods than TW members could even try to.
  5. May 12, 2016 at 8:12 PM
    #145
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I've noticed no difference in mpg.
    1slowvq37, clupi and nfs257 like this.
  6. Jul 24, 2016 at 4:49 AM
    #146
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Bump. Still want to do this mod eventually. Probably will be too late when I get to it :rolleyes:
  7. Aug 16, 2016 at 8:49 AM
    #147
    MTopp
    05 SR5 4x4
  8. Aug 17, 2016 at 6:49 PM
    #148
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    Just picked up a throttle body for $163 on eBay. Ordered the adapter as well. I'll port and polish when I get back in a week or so!
    I have the MAF calibrator installed. I ran the file for a TRD intake and according to my ultra gauge, it was a bit lean ( if I understand it correctly). I'd like to get a tune done with this, the intake, the manifold spacer, and the hopeful future snorkel, but I'm a little worried about tuning. Maybe when I understand it a bit more or find someone with a bit more knowledge to help
    MTopp likes this.
  9. Aug 18, 2016 at 8:41 AM
    #149
    MTopp
    05 SR5 4x4
    what'd you search for on ebay to find the throttle body?
  10. Aug 18, 2016 at 8:42 AM
    #150
    Rusty15Tacoma
    Rusty
    San Diego
    I think 4Runner throttle body or FJ throttle body.
  11. Aug 18, 2016 at 2:41 PM
    #151
    MTopp
    05 SR5 4x4
    Alright
  12. Aug 18, 2016 at 2:51 PM
    #152
    Rusty15Tacoma
    Rusty
    San Diego
    I may have limited my search to under $200. There's a guy on there with an adapter and a throttle body for $400. I think if you make an offer of $250, he'll go for that. I didn't want to spend that much because he shaved down the throttle body plate shaft and stripped a screw. I was worried it might dislodge while driving.
    I've done that mod on my CJ5's GM throttle body and snapped the head off the screw because those are barbed and designed not to come out. I was worried this would be the same.
  13. Aug 18, 2016 at 4:29 PM
    #153
    MTopp
    05 SR5 4x4
    Part ##s for those interested ^
  14. Jan 16, 2022 at 10:36 AM
    #154
    vladgregory
    vladgregory New Member
    Greg
    13 taco 4l
    Headers intake ho tune
    Why not just buy a upper off a 10+ FJ and bolt it on? Are the intake ports larger? I was looking at them and they appear to be the same other than tb size?
  15. Feb 19, 2022 at 10:55 PM
    #155
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I think utilizing an IMS would be more beneficial for about the same price point.
    and holy thread revival batman
    eljedi68 likes this.
