URD and TRD/Magnuson superchargers in DFW-
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DanoDavis, Sep 5, 2017.
  1. Sep 26, 2017 at 8:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No one is talking about transmissions. Just the clutch.
    blu92in99 and TRDMountaineer like this.
  2. Sep 26, 2017 at 9:48 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    That's actually a good point. Unless you have the transmission and oil cooler you might realize some issues with overheating the trans once you start putting more torque through it.
    Torspd[QUOTED] likes this.
  3. Sep 26, 2017 at 9:58 AM
    TRDMountaineer
    TRDMountaineer Well-Known Member
    Ripley, WV
    2015 AC TRD Sport MGM 6-spd S/C
    TRD S/C, aFe Stage-2 Intake, Magnaflow 15315, Leer 100XQ w/ Tracker II Rack, General AT2 265/70R17, OEM skid, TRD FJ caps, Wet Okole Realtree seat covers, TRD grey shift knob, Weathertech floorliners, Weathertech window visors, Salex glove box+console organizers, Grid-It console lid mod, Lamin-X amber fogs, Craven Speed A-pillar phone mount, Debadged
    If you're referring to the clutch, it does indeed create an issue. I doubt I have even touched full boost on mine, yet I was noticing 5th and 6th gear slippage within a couple months of having the S/C. That was with a free flowing exhaust and larger air intake, though.
    Torspd likes this.
  4. Sep 26, 2017 at 10:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    True. This is the root from whence forth comes the valve body upgrade, and or the upgraded automatic trans cooler.
    @Camby has an '06. Assuming his clutch is original, it is the LuK brand clutch. Very stout, in comparison to the Aisin clutches which came out mid '08 - early '09. Those failed with hubs ripping off of the disk, left and right. Then they changed again sometime later. My LuK clutch didn't last but a few months with my extra power. Combined with the weight of tires and lift.
    All a matter of when, not if. Taking into account the variables acting upon it.
  5. Sep 26, 2017 at 10:36 AM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    So Nice! DO You have the TRD Flash? Does your AFR hold up well with the increase boost?
  6. Sep 26, 2017 at 10:37 AM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    2.5??? Giddyup!
  7. Sep 26, 2017 at 11:19 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yessir.. Stock TRD tune. AFR holds up great, but I also have a lot of supporting mods to go with it. I run the FPR mod as I notice a corresponding drop in boost as the AFR gets a little higher if I don't run it. Without the mod hooked up I peak at 9.7 psi boost. With the mod hooked up I top out to close to 11 psi on a 86* day.
    Not to mention an added additional pep in general when the mod is hooked up. Overall it just feels better.
    Once Ovtune is released for the second gen I'll pick up their tuner and use that to dial in the AFR's to levels that don't bounce between numbers at part throttle, but for now this does just fine.
    Yessir! Vroom vroom!
    Actually in this case, whineeee whineeee! :thumbsup:
    BassAckwards likes this.
  8. Sep 26, 2017 at 11:34 AM
    Camby
    Brian
    Denver
    Sick! At some point down the road, I want to put a 2.85 pulley on; but at the same time dont want to disrupt my AFR curve...
  9. Sep 26, 2017 at 11:35 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I assume the FPR mod is moving the FPR vacuum line to a boost source? @snowsk8air2 have you done this?
  10. Sep 26, 2017 at 11:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tee'd into the source where the boost gauge gets its vacuum and boost reference.
    12TRDTacoma likes this.
  11. Sep 26, 2017 at 1:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you run the stock fuel pump the 2.85 pulley will require FPR mod most likely. Even in stock NA configuration the fuel pump has difficulty maintaining proper fuel volume, slap a SC on there and you are asking for trouble.
    I have ran every pulley I have had on the blower (3.0, 2.85, and 2.50) with my aftermarket fuel pump so I have never had an issue with proper fueling volume.
    The stock TRD tune is designed to overfuel rather than under at WOT. In stock SC configurations and even with the 2.85 pulley with a proper fuel pump you will see AFR's of around 9.0-9.8 without FPR mods. If you do the mod with an aftermarket fuel pump you will peg out your AFR gauge and be SUPER pig rich. Hope this piece of info helps you in the future.
    Yes, instead of running the FPR line to the intake air box you run it into the boost source nipple at the back of the SC. If you have an AFR gauge you at that point require a T to run vacuum/ boost to both the gauge and the FPR at the same time.
    It drastically affects AFR's depending on your configuration!
    Torspd likes this.
  12. Oct 2, 2017 at 9:08 PM
    Camby
    Brian
    Denver
    Would it be a lot to ask for some photos of the FPR Mod? Ive been looking online for a while now and still confused what gets connected into what. From what I gather, the FPR vacumm hose is connected to the intake port. The FPR Mod is simply disconnecting said vacuum line and connecting it to the boost port on the SC yes? Thats it???
    12TRDTacoma[QUOTED] likes this.
  13. Oct 2, 2017 at 9:39 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes
  14. Oct 2, 2017 at 11:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's basically it. Disconnect the line from the intake airbox or aftermarket filter setup, cap the port and reconnect the vacuum hose to the boost port. Simple.
    Camby[QUOTED] and Torspd like this.
  15. Oct 3, 2017 at 6:09 AM
    #35
    Camby
    Brian
    Denver
    Thank you!
