URD cai and MAF cali
Discussion in 'Performance and Tuning' started by DirtyMyrtle, May 18, 2015.
  1. May 18, 2015 at 12:23 PM
    DirtyMyrtle
    DirtyMyrtle [OP] Active Member
    Jordan
    Myrtle Beach
    12 Pro Comp Taco
    6in Pro Comp es9000 rear shocks Bilstein 5100 adj 37x13.50x22 Toyo M/T 22" Fuel Full Blown Thule MOAB basket Yakima Racks
    I'm 21 and just really starting to get my hands greasy.. so was hoping for some help here. My truck gets some pretty sucky gas mileage right now running 37s. And with my age I obviously want to go fast haha so why not get bad gas mileage with a mean motor? Yes I do know that going to smaller tires will help me out a bunch.. but I also want a badass ride.
    But to what I'm really here for. I am looking into getting the URD cold air intake to start with, from research these guys are trustworthy and best work for toyota.
    At the bottom it has a check box to add the MAF calibrator. I was wondering if I should just go ahead and purchase that as well... and what will that actually do once I start playing with it? (in simple terms)
    Or should I start with regearing to 4.88s first before I start with tuning and beefing the motor up?
    Not looking for smartass replies.. if you have something stupid to say, please don't even bother replying. Just looking for help and some smarts. Thanks in advance guys.
  2. May 18, 2015 at 12:36 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Gears may get you better mileage, just depends on your driving habits. More gear may help city mpg, but will hurt highway mpg. I have the CAI and the MAF Cali and like them both together. Nice little bump, but no mpg gain, or loss.
    But,,, in your case, with 37s, I'd gear it first. If you do spend lots of highway time though, be careful as to how much gear you get.
  3. May 18, 2015 at 1:04 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    No mpg gain, risk of maf fouling in rain, poor maf sensor seat may leak, urd does not work best for Toyota, gadget is NOT trustworthy when u have a problem with a product, get an afe stage 2 si intake.
    I have had both of what u are asking about and hated them...........MAF calibrator was fun but its not easily adjusted or turned off if u have drastic elevation changes, a super hot day, long grades all of which have lead me to pinging.
    intake, well I already summed that up. The URD intake sees ZERO cooler air than stock while cruising at 40 mph and above.
  4. May 18, 2015 at 1:31 PM
    DirtyMyrtle
    Jordan
    Myrtle Beach
    12 Pro Comp Taco
    Okay this is what I'm looking for.. If you were to recommend anything else besides the afe stage 2 what would it be? I guess I can just scratch gas mileage out. Just want to gain some power back.
    Any knowledge with programmers or what is your opinion on that?
  5. May 18, 2015 at 1:34 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    headers, y pipe, supercharger.
  6. May 18, 2015 at 1:37 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  7. May 18, 2015 at 1:59 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    He didn't get a potato
    Torspd likes this.
  8. May 18, 2015 at 3:08 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just fyi OP, I have had zero of the issues with my URD that Justus did. I will agree that there is only a few degrees difference between stock, aFe stage II SI and the URD (I've had the aFe and the URD also). I also had no issues, so did not have to deal with URD support, for good or bad. I had an aFe first, but did not like the sound when running around 1500rpm, annoyed me, so switched to the URD.
    I did run some 1/4 times for both the URD and aFe, and the results were similar for both, about a 1/10 over OEM.
    I still stick with my original recommendation though, if you are running 37s, gear it first, then hit up the perf mods.
    Nicks4x4LT likes this.
  9. May 18, 2015 at 3:12 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    U don't hear the same rasp, and the glove box doesn't shake like a dog shitting razor blades when supercharged at least..... I know what u mean tho, the afe can be loud while n/a
  10. May 19, 2015 at 9:26 AM
    DirtyMyrtle
    Jordan
    Myrtle Beach
    12 Pro Comp Taco
    Thanks guys for the help and the personal experiences on your purchases. Going to wait it out a little to see what I can come up with to really get the engine opened up.
  11. May 19, 2015 at 7:35 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Im going to vote for the gears first as well. If you do it right you can get similar performance to stock while still rolling like a boss on 37s. Then any performance mod you do will be far more effective and cause less strain on the engine.
  12. May 19, 2015 at 8:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Maybe your bypass valve stays somewhat in bypass. Happened to Memario with his brand newly installed S/C. Disconnected it and it was a boosting SOB
  13. May 24, 2015 at 2:13 AM
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I liked my URD TCAI with maf cal. Had no issues, noticed a V tech sort of pull around 3500 rpm's. Haven't had any issues with it but run it with the shield and the aqua net. I would also go with regearing first. I don't think you'll notice a real difference with my setup on 37's.
