URD CAI
Discussion in 'Performance and Tuning' started by SirBunnyEater, Sep 13, 2015.
  1. Sep 13, 2015 at 9:52 AM
    SirBunnyEater
    SirBunnyEater [OP] Member
    2015 Tacoma TRD Sport
    Looking into getting a new intake and came across the URD. Looks good and all but being positioned right behind the grill wouldn't it be susceptible sucking water? Like if you go through the wash or are in a heavy rainstorm? Just seems a little exposed. If you guys have one is this an issue? If so how do you overcome it? I definite get the idea of getting it outside of the engine bay. Thanks!image.jpg
  2. Sep 13, 2015 at 11:37 AM
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    I currently have one with the splash guard and I've gone through water, car washes, and rain and I haven't seen a problem with it yet.
  3. Sep 13, 2015 at 3:42 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Maf sensor seat is shit.... Water can and will leak onto maf sensor.... Happend with two different ones, purchased yrs apart
  4. Sep 13, 2015 at 3:44 PM
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    Any ways to fix that? Other then buying a new intake?
  5. Sep 13, 2015 at 3:45 PM
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
    URD TCAI is the best intake option (except if you stick with stock or go boosted). If you are worried about hydrolocking get the splash guard, I did and I haven’t looked back.
  6. Sep 13, 2015 at 3:45 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Gadget said to use rtv......
    Great suggestion from a manufacturer huh?
    Why fix the problem when u can make customer half ass rig something
    6xchamps likes this.
  7. Sep 13, 2015 at 3:46 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Besides, intake air will NOT be any cooler than stock when approx 45 mph.
    Proven with Scangauge, and ultragauge
  8. Sep 13, 2015 at 3:48 PM
    Ninj
    Ninja
    New Hampshire
    I’d like to see those results. I’d rather get air from the grill out of the engine bay then through a fender in the engine bay.
  9. Sep 13, 2015 at 3:51 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Buy a gauge..... I already know it for fact..... Ran URD, afe, stock, and k&N.
    Don't buy into the hype, its all sales bullshit..... The only issue with stock is the internal baffles/chambers built into almost all OEM intakes to keep down noise.
    The rest is just gullability
  10. Sep 13, 2015 at 3:56 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Ur fender draws ambient air.....
    How in the world can u EVER draw colder than ambient in our trucks without some cooling setup?
    The math is simple
  11. Sep 13, 2015 at 3:57 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Truth...... I've spent the money for u guys
    Ninj likes this.
  12. Sep 13, 2015 at 4:04 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    With thousands into the blower, exhaust, ypipe, headers, pulley...... Don't think I've skimped on trying to find the coolest intake temps on the market, trust me
  13. Sep 13, 2015 at 4:12 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Hype based on the best pull, in optimum conditions, with air conditioner blowing cold air into the path on a dyno in a cooled garage at lowest altitude anyways
  14. Sep 15, 2015 at 5:23 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Have had mine on for 3 years now with the splash guard (IMHO the sock makes the intake a total waste). I live off the Gulf coast, so it has been through many rain storms with no issues or stumbles.
    I don't discount Justus' experience as he has a good rep, but I have not heard of anyone else with this particular issue.
    This is very much true. I have had the stock, a Volant scoop plumbed into the stock TB box, an aFe Stage II SI, and a URD. The differences in those at 30+ mph is only 1-2 degrees. There are some bigger deltas with heat soak though at idle, or low speeds that I've seen. URD still stays 4-5 degrees at low speeds and heat soaked. All the others will go 15-20 degrees over.
    End of the day, you just need to figure out what you want. You may get a few HP from high-mid to high rpms from an intake for an NA setup. If you ever cross high water, do not get a URD. URD also requires some cutting of the sheet metal next to the radiator.
  15. Sep 15, 2015 at 12:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There have been numerous accounts. URD actually recommends the splash shield because it is such a common knowledge issue. What's strange is that the don't just make it part of the kit.
    Justus likes this.
