URD flywheel and stage 2 clutch
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Forumuser, Jan 16, 2021.
  1. Jan 16, 2021 at 10:09 AM
    Forumuser
    Forumuser [OP] Well-Known Member
    Rob
    2011 Tacoma 4x4
    Fox 2.5 front 2.0 rear, Camburg uca's, ubolt flip w/timbren bumps, afe intake, URD fuel kit, TRD S/C, URD 2.6pulley, URD 160 thermostat, URD Headers Y-pipe exhaust, short throw shift, innovate boost afr gauge, optima battery, URD heavy flywheel, stage 2 clutch, hydraulic throw out conversion
    I dropped this stage 2 and heavy flywheel in my 2011 4wd and it wasn’t the right setup. It held really pretty good in 2wd chirping through 3rd. 4wd drive wasn’t as good. I think the rotating mass of the heavy flywheel compounded with tire size and 9lbs of boost and it slipped really bad on me but only twice.clutch only has 20k and I’m not mean to them ever. Routinely get 100k on my clutches. There’s a couple hotspots on the flywheel but I’m sure it’ll be excellent for someone with a different application. I’m more “rally” my truck than crawl it. I’m loving the throttle response on the lightweight flywheel and stage4 I swapped to. The heavy flywheel was extremely easy to feather. Can walk the clutch out on idle. More of the serious off-roader or crawler would enjoy the benefits. It’s free to someone who needs it and will use it. Gotta pay all shipping and it’s probably 50lbs give or take.
    MuddySquirrel and whatstcp like this.
  2. Jan 16, 2021 at 10:11 AM
    Forumuser
    Rob
    2011 Tacoma 4x4
    More
    whatstcp likes this.
  3. Jan 16, 2021 at 10:31 AM
    Forumuser
    Rob
    2011 Tacoma 4x4
    Also, pro tip. I had an alignment pin migrate loose and rattled my throwout conversion to death. Red loctited all the pins before pressing them in
  4. Jan 16, 2021 at 10:38 AM
    Forumuser
    Rob
    2011 Tacoma 4x4
    After my clutch slipped twice on the stage2 my pedal randomly collapsed to the floor. Just fell. I was locked in gear, limped home to fix it. So it was kinda mandatory to go in and figure out what was up.
  5. Jan 16, 2021 at 12:57 PM
    Forumuser
    Rob
    2011 Tacoma 4x4
    I’ve seen a ton of debate on swaybars also. I’ve pulled mine off and on for 10 years and I’ll never take it off again. Trying to carry corner speed without one isn’t even close to safe or better.
    econwatch likes this.
  6. Jan 16, 2021 at 2:17 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
  7. Jan 16, 2021 at 6:10 PM
    Forumuser
    Rob
    2011 Tacoma 4x4
    Checking
    Shadowhunter[QUOTED] likes this.
  8. Jan 16, 2021 at 6:39 PM
    ebuyaer2002
    ebuyaer2002 Well-Known Member
    Nate
    Salem, OR
    08 Tacoma TRD OR DCSB 6 Speed
    RC 6" lift, icon coilovers, DK uppers, URD intake, DT Longtube Headers, Cam gears, 70mm throttle body, Custom Tuned with HPTuners
    Send you a message. Thanks
  9. Jan 16, 2021 at 7:00 PM
    Forumuser
    Rob
    2011 Tacoma 4x4
    It’s been spoken for gentleman. Thanks for the interest
