Urd fuel pump 1gr
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toytaco112, Jul 16, 2021.
  1. Jul 16, 2021 at 10:04 PM
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    2012 Tacoma DBLCB 4x4 short bed
    King 2.5 Extended travel coilovers, JBA UCA's Deaver stage 2 leaf pack, All pro Aluminum replacement front with 9500lb smittybilt winch, cheap ebay rear replacement, 285.75x16 BFG All- terrains on Method NV wheels, Air ride bags light bars, rock lights bumber light bar And the list goes on..
  2. Jul 16, 2021 at 10:27 PM
    Nalpak99
    Nalpak99 Booty Hunter
    Kyle
    2005 Toyota Tacoma pre-runner
    mid travel
    you can run it on a stock truck... but why?
  3. Jul 16, 2021 at 10:33 PM
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    im having fuel pressure issues and looking for an alternative replacement to oem
  4. Jul 16, 2021 at 10:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    AEM green top is solid. You can run any fuel pump on the truck, as the fuel delivery is computer controlled via injectors. To summarize, you'll be fine, supercharger or not.
  5. Jul 17, 2021 at 6:36 AM
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    Great thats the answer i was looking for appreciate that
  6. Jul 17, 2021 at 8:56 AM
    Nalpak99
    Kyle
    mid travel
    are you sure the issues are from your fuel pump and not your injectors or fuel lines?
  7. Jul 17, 2021 at 9:16 AM
    jfoster92
    jfoster92 Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    I bought the kit for my stock 1gr simply to have the serviceability fuel filter. You won’t regret it.
  8. Jul 17, 2021 at 9:20 AM
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    Well not 100 percent sure. All rubber lines have been checked all the hard lines i highly doubt thats my issue. Injectors very possible but my problem doesnt happen all the time and I have a fuel pressure gauge i watch all the time when it happens i see my fuel pressure drop either i have a leak or fuel pump is failing/ filter clogged, crap in my tank… Either way if im gunna go through the hassle to drop my take to inspect why not replace it. Its a matter of time before it fails truck is at 120,000 miles.
  9. Jul 17, 2021 at 9:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is key.
  10. Jul 17, 2021 at 10:06 AM
    Waasheem
    Waasheem
    2007 xrunner
    I believe the regular is in the engine bay therefore easier to access. You might be replacing it for no reason but it would be easy to eliminate the fuel pressure regulator as a problem.
  11. Jul 17, 2021 at 8:54 PM
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    Thanks Thats where i tapped in for my fuel pressure gauge guess it could be that… will have to see if there is a way to test it or skmwthing
  12. Jul 17, 2021 at 9:23 PM
    Waasheem
    Waasheem
    2007 xrunner
    Come to think of it, your problem could also possibly be the fuel pump resistor, also located in the engine bay, I think close to a headlight. I’ve read in here plenty of people finding problems they’re having ending up being that.
  13. Jul 20, 2021 at 4:34 PM
    Nalpak99
    Kyle
    mid travel
    that's a weird issue... i have 200k on my truck and the whole fuel system has never been touched and its running perfecty.
  14. Jul 20, 2021 at 7:50 PM
    toytaco112
    toytaco112 [OP] Sup
    Cedar Park, TX, US
    Could be normal i dont know but when i get on it my gauge drops to 39psi when let off it jumps back up to 41 and its only sometimes
