URD Fuel Pump kit
Discussion in 'Performance and Tuning' started by JaxJacket, Jun 17, 2018.
  1. Jun 17, 2018 at 11:45 AM
    JaxJacket
    JaxJacket [OP] Well-Known Member
    2013 DCLB
    Did anyone else have problems keeping the filter sock from popping off during install?
    Deatschwerks 255 lph pump kit - each time I tried to insert the pump into the bucket the filter sock would pop off as it rubbed on the side of the bucket. I think I finally got it in by pushing on the sock with a screwdriver while simultaneously pushing the pump in, the truck is running, but I'm wondering if I missed something.
  2. Jun 20, 2018 at 7:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did you use the teeny tiny lock ring, that attaches the sock to the bottom of the pump?
  3. Jun 20, 2018 at 3:23 PM
    JaxJacket
    2013 DCLB
    Crap - that must be the little flower shaped washer. I didn't even see it until I just went back through the box - I thought the ring being referenced was the silver ring already installed on the sock where it snapped over the pump inlet. Looks like I need to get another strap for the pump and go back in. Thanks.
  4. Jun 20, 2018 at 4:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's the one. Glad you found it. Marking the ring with a sharpie, and then using a large flat head and a dead blow, will also loosen off the lid. As another option.
  5. Jun 20, 2018 at 6:53 PM
    JaxJacket
    2013 DCLB
    That's how I ended up opening it the first time - my strap wrench wasn't moving anything. I was referring to the metal strap that holds the pump in the bucket. I believe I have to cut it to pull the pump back out and put the sock retainer on, so I'll need a new one. Is there another way to get to it?
  6. Jun 22, 2018 at 2:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah, you’ll likely need a new one. Metal zip ties. Do a Bing search, and you’ll find where to purchase some. Might even be at your local auto parts store.
    KTM753 and inwood customs like this.
