URD Headers / O2 simulators and tuning knowledge
Discussion in 'Performance and Tuning' started by StuckinOhio, Aug 29, 2015.
  1. Oct 4, 2016 at 9:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Nope. It was from a company called Empire. Empire USA I believe. Shocked me the first time I saw it because the sensors were "missing". Yet just replaced by the box.
  2. Oct 4, 2016 at 9:43 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I see now... some chatter about it on CT, someone was emailing them in 2007 and ever got any reply.
    Sad.
  3. Oct 5, 2016 at 5:26 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Short lived product but better in my opinion.
  4. Feb 27, 2017 at 7:18 AM
    SFCDAN
    SFCDAN Member
    Dan
    Idaho
    2013 Barcelona red DCSB S/C Offroad
    TRD S/C DT Long Tube Headers URD 2.85 Pulley, CAI, MAF Cal, O2 sim, Gauge Pod with Oil pressure and AEM wideband AFR/Boost Redline Hood struts Puck Lift, rear Firestone Airbags 285/75/17 Toyo AT II FJ wheels All-Pro front and rear Bumpers Tailgate Pop-a-lock tail gate lock with easy down strut. Dodge Flip up Tow mirrors. Nitro Gear 4.56 gears (still in the box)
    How did you fix your 430 code did you use a spark plug fouler adapter or did you go a different route? I have the same setup DTLT stock y pipe o2 sim and 420 and 430 codes intermittently.
  5. Jan 28, 2019 at 10:37 AM
    USMCtaco88
    USMCtaco88 Common sense isn't always a common trait
    My names Jeff
    Savannah, Georgia
    2015 Silver Sky DCSB TRD OR
    I did some stuff.
    Resurrecting this thread. Wanting to get long tube headers for my 2015 V6 and need to know if anyone found a fix for the CEL's since the simulator doesn't work?
  6. Jan 29, 2019 at 5:25 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
  7. Jan 29, 2019 at 8:46 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I have been running the jbung and urd sim for over a year and the light has not come back.
    BassAckwards likes this.
  8. Jan 30, 2019 at 12:46 AM
    USMCtaco88
    My names Jeff
    Savannah, Georgia
    I did some stuff.
    Thank you I just read through this one and will give it a try.
    I saw your posts that the previous guy posted. I just ordered a set of those j bungs now actually. Thanks for the help.
  9. Mar 9, 2020 at 8:36 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Currently dealing with P0420 / P0430 after DTLT install.
    What if I were to use an antifouler and weld it completely shut, then slowly drill bigger and bigger holes until they passed?
    Anyone tried the "5$ 02 sim" with diode and capacitor as found here? : Lots of discussion in that thread how URDs $150 02 sim is just that in a fancy package, can anyone confirm or deny this definitively? Does URDs REALLY help to calibrate the front sensor?
  10. Mar 9, 2020 at 8:51 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I took one apart, some years ago. It has a circuit board in there. More than just a simple diode and capacitor. For whatever that is worth. By all means though, if that thread has directions and true positive feedback, give it a shot. Let us know how it goes.
    excorcist likes this.
  11. Mar 9, 2020 at 9:52 PM
    excorcist
    Reno, NV
    Thanks for the response! Will chime in again when I have an outcome.
    Torspd[QUOTED] likes this.
  12. Mar 12, 2020 at 4:58 PM
    excorcist
    Reno, NV
    So my solution was just to stack 3 non-foulers on each 02 sensor, the center non fouler I welded shut, then proceeded to change the diameter of the hole in that middle non fouler with a drill bit.... it took me about 3 or 4 different test holes but I ended up at about only a 1/8'' hole and I haven't had the code come back, and nothing pending either. This is the same concept as the Vibrant J bung with the adjustable inserts, I was just on a time crunch for a trip Im leaving for in a couple days. I spent about 15$ for 3 sets of 18mm non fouler's from oreilly. No 02 sim needed as far as I can tell with this method.
    Torspd likes this.
  13. Mar 13, 2020 at 6:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Give us an update on this, after about 120 miles or so. 50-60 should have every system ready, so that will be over that amount enough to get a better idea.
  14. Mar 13, 2020 at 8:03 AM
    excorcist
    Reno, NV
    Will do. I have already driven enough for all the systems to do their thing and I passed smog yesterday. I'm leaving on a ~1500 mile round trip with lots of varied driving so that should be a good test.
  15. Mar 13, 2020 at 10:22 AM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Awesome!
  16. Apr 29, 2020 at 9:26 PM
    #36
    excorcist
    Reno, NV
    Figured Id pop back in here for an update for anyone that happens upon this thread like I did . Going on about 7 weeks, and probably around 700 miles of varied driving. Still no CEL and nothing pending either. No perceived negative impact on MPGs or otherwise..... was a great alternative to the O2 sims for me.
    MightyMouseTom and Torspd like this.
  17. Apr 29, 2020 at 9:55 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You sir just gave me an idea, for another project.
    excorcist[QUOTED] likes this.
  18. Apr 29, 2020 at 9:56 PM
    #38
    excorcist
    Reno, NV
    Go on...
    dirtdigginjoe likes this.
