URD MAF calibrator HELP!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krackalacka, Jun 27, 2011.
  1. Jun 27, 2011 at 11:12 AM
    Krackalacka
    Krackalacka [OP] Well-Known Member
    Jake
    West Virginia
    06 Tacoma TRD SR5 Sport
    B 5100s 2.5 AAL Suspension Lift
    Just installed URD MAF calibrator, they sent it to me pre tuned for my truck, installed it now the truck turns over begins to run for 1 second then dies. Any ideas?
    P.S. I installed it on my lunch break and as of now i'm stranded at work AAAHHH!!!!
  2. Jun 27, 2011 at 11:13 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    You might've wired it incorrectly, call URD and ext#3 to reach Gadget.
  3. Jun 27, 2011 at 11:18 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  4. Jun 27, 2011 at 11:22 AM
    Krackalacka
    Jake
    West Virginia
    checked the wiring twice it all adds up. Any other ideas?
  5. Jun 27, 2011 at 11:26 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    you did disconnect the battery before doing this correct?
    you are sure the green & violet connections are in the right order?
    did you solder the connections or crimp them?
  6. Jun 27, 2011 at 11:29 AM
    Krackalacka
    Jake
    West Virginia
    AH, thank you, gonna go try the order swap.
  7. Jun 27, 2011 at 11:46 AM
    Krackalacka
    Jake
    West Virginia
    I didn't disconnect the battery, but after i rememberd, i unplugged all the plugs from the ECU disconnected the battery and then re plugged the plugs in hooke the battery up. Checked the green and purple, they seem to be in right order. I just twisted together the connections until i knew it would work.
    Next Question:
    This is a stupid one, but when i connect the wires of the MAF calibrator do the wires connect the plug end (the part that goes in to the ECU or do they go to the end that goes out into the vehicle?
  8. Jun 27, 2011 at 12:01 PM
    rberumen2
    rberumen2 Well-Known Member
    Ralph
    California
    2017 White Tacoma TRD Sport 4x4 DCSB
    sorry for not having any input, but where did you get your calibrator at? just wondering. what is the purpose if you don't mind me asking.
  9. Jun 27, 2011 at 12:10 PM
    Krackalacka
    Jake
    West Virginia
    Look up Under Dog Racing Development and its called a Mass Air Flow Calibrator.
  10. Jun 27, 2011 at 12:11 PM
    Krackalacka
    Jake
    West Virginia
    or am i simply splicing the calibrator in, so if i cut the ECU wire, i'm then splicing 3 wires together?
  11. Jun 27, 2011 at 12:22 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Negative! Your not splicing 3 together, you will be replacing some wires with others.
  12. Jun 27, 2011 at 12:22 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I have a slightly different gear in my truck, I used UNICHIP programmer but it installs near the same way.
  13. Jun 27, 2011 at 12:40 PM
    Krackalacka
    Jake
    West Virginia
    ok, well i don't know if i've accomplished anything or not, other than, the truck runs. What I tried:
    I connect the MAF wires to the plugs going into ECU, nothing.
    I connect the MAF wires to the wires that would have been leaving the plugs on the ECU, nothing
    What worked (as in the truck runs):
    I spliced the MAF wires into the wires going into the ECU plug and out into the vehicle. Will drive it here in a few minutes and find out if there is any improvement, I did start it and it sounded different.
  14. Jun 27, 2011 at 12:47 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    so it IS done doing splicing?? Wierd, it could be I guess, but that wasn't how mine installed
  15. Jun 27, 2011 at 1:02 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    you want to peal back some of the rubber coating and wrap the calibrator wire around the ecu wire, then solder them together
  16. Jun 27, 2011 at 1:02 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    the green & violet connection is the only wire that you have to cut...then you will connect the wire "through" the green and violet wires
  17. Jun 27, 2011 at 1:07 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    my diagram
    the red/yellow>green>maf calibrator>violet>red/yellow
    all other wires, i pealed back the rubber insulation to expose ecu wire and wrapped the maf calibrator wire around it, and solder
  18. Jun 28, 2011 at 4:56 AM
    Krackalacka
    Jake
    West Virginia
    Yup, definitely got it working, felt the difference going home and back to work, I notice it around 2500 rpm, but generally i can feel it through the gears and throughout the rpms. Gas mileage, hard to tell at this point cause the foot was quite heavy with the new power.
  19. Jun 28, 2011 at 6:03 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    I noticed the power jump around 3k rpm and my mpgs have gone from 16mpg avg to 19mpg avg (daily driving). If you're a manual, hit an onramp in 3rd and keep at it til 60 in 3rd...fun stuff right there
    What intake setup do you have? I have the volant with scoop
  20. Jun 28, 2011 at 6:11 AM
    acdronin
    acdronin Well-Known Member
    Glad it worked out, the other thing to make absolutely sure of is that you don't have any shorts, I would recommend heat shrink, if you cant find a three way shrink, then what i did was get some wider (flat) shrink, cut a length of it off, then split it open. I then folded my splice so it fit inside the split open shrink and then sealed it. I took as much time doing the heat shrink as i did doing the splices.
