URD MAF Calibrator question
Discussion in 'Performance and Tuning' started by SAGENOVESETRD08, Mar 22, 2009.
  1. Mar 22, 2009 at 5:20 AM
    SAGENOVESETRD08
    SAGENOVESETRD08 [OP] Member
    Plymouth,MA
    08 TRD Rugged Trail
    ok, i just bought a URD MAF calibrator. It seems like an awesome mod, but I'm not gonna lie, its way out of my league. To really tune it, what other products will I need? ie. scangauge? (All this stuff about air/fuel ratios and shit!(Or should I just have it done by a pro. My truck will have Volant CAI w/ ram air scoop, JBA shorty headers, custom exhaust w/ magnaflow mufflers, so it should be further tuned right......damn, why cant these things just be easy....thanks for the help!!!
  2. Mar 22, 2009 at 8:33 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    The easiest tuning unit on the market is the APR X-1. Plug and Play and your done (for the most part).
    As far as tuning with the URD MAF cal you will need to install a wideband and AFR gauge to monitor the engine AFR. You'll need a laptop with the SS second software to tune it.
    Check out the U-Tune guide that Gadget made, that should help you. :thumbsup:
    http://www.gadgetonline.com/U-Tune.pdf
  3. Mar 22, 2009 at 8:39 AM
    SAGENOVESETRD08
    Plymouth,MA
    08 TRD Rugged Trail
    Damn, nothings easy huh?....i guess its worth it though. Thankx for the info.....i'm sure i'll get it figured out
  4. Mar 25, 2009 at 7:31 AM
    diver john
    diver john Member
    Gloucester MA
    03 DBL cab TRD
    Volant intake, JBA headers,1st, cat MIA, Gigson cat back, Sprayed Bedliner, Eclipse6620, Sunroof, Toyo open countries, Full OME suspension, ARB front bumper, CBI off road rear bumper, yakima racks
    I the only problem with the APR X1 is that it only works on 2nd generation Tacomas. Great product, not for the 3.4 L
  5. Mar 25, 2009 at 2:13 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Correct. It was designed for the 4.0L 1GR-FE. :thumbsup:
  6. Jan 21, 2010 at 7:47 PM
    YumaTRD
    YumaTRD 22R...Legends never die
    David
    El Cajon, CA hometown Yuma, AZ
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO's
    Is the URD MAF sensor calibrator and the URD AFR sensor calibrator the same thing?
    And is there the option of getting it pretuned to work with your engine mods?
  7. Jan 22, 2010 at 11:57 AM
    chanes8cwu
    chanes8cwu Well-Known Member
    Joe
    Black Diamond, WA
    2012 DCLB Tacoma 4.0L
    is there a manual for installation for the 2nd gen tacomas? I just bought the urd maf sensor as well, ive emailed urd and havent heard back in 3 days. I have the ss software just dont know what im doing! HELP!
  8. Jan 22, 2010 at 12:05 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    pm this guy XrunnIT
  9. Jan 22, 2010 at 8:56 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    I have answered all the emails in the que. If you have not gotten a response, we have not gotten your email for some reason.
    Give Tech Support a call 877-887-3872 x3 and we will get you fixed up. We will need to know which version of the MAF Sensor Calibrator you have, what vehicle you are installing it in, what year it is, and what engine you have.
    Gadget
  10. Jan 23, 2010 at 9:06 AM
    ScubaSteve
    ScubaSteve memeber member
    Manatee County
    2010 SR5 4x4
    FM american thunder, 32" terra grapplers on XD machined addicts, AFE pro dry drop in 3" OME lift
    Does the urd maf sensor affect mpg's?
