URD MAF Calibrator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TodaGuy, May 24, 2009.
  1. May 24, 2009 at 10:55 PM
    TodaGuy
    TodaGuy [OP] Well-Known Member
    Oregon
    Almost Murdered 09 Taco
    Revtek 3" spacer in front 1" block w/ 2" AAL in rear. Blacked out grill, debadged (almost all done), Magnaflow muffler, black Konig Countersteer Off Road rims, 285/75/16 Toyo Open Country M/Ts.
    I did hours and hours of reading and pming and I did not get a solid answer on this.. Sense my lift and bigger tires I lost some of my power and mpg and I have been looking for ways to improve both if possible. My question is if I install the URD MAF Calibrator on my 09 4.0l taco (currently stock besides a Magnaflow muffler) on the default tune that is suposta supply 15whp to a stock rig will my everyday mpg increase or will it not be effected. Thanks for the help!
  2. May 25, 2009 at 2:22 AM
    TodaGuy
    Oregon
    bumpin! I want to have my power back with my new improved looks!
  3. May 25, 2009 at 2:54 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    If you really want your power back, either go back to stock tires or re-gear.
  4. May 25, 2009 at 10:42 AM
    TodaGuy
    Oregon
    Has anyone regeared their 2nd gen 4.0l taco? what gears should i use with a 33" tire?
  5. May 25, 2009 at 1:10 PM
    TodaGuy
    Oregon
    Well i just found out that regearing is way outta the question. It would be something like $1500 for that junk.. So I'm sol unless URD MAF Cal. will give back any mpg. From what i understand the only time the URD MAF Cal. effects my tuck is WOT? So I will not see any effects from this mod in normal every day driving?
  6. May 25, 2009 at 1:15 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    super charger or turbo??
    my brother had a gen1 and had to put a SC on when he went to 35's
    I don't think the calibrator will help you, unless you do intake and/or headers
  7. May 25, 2009 at 1:21 PM
    TodaGuy
    Oregon
    I sort of had plans on doing both headers and a trd cai and then installing MAF Cal after those mods thinking the modifications combined with the cal. would give me a nice mix of power and mpg.
  8. May 25, 2009 at 1:25 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    The only way to really gain power is forced induction. Nothing else is going to be worth the money
  9. May 25, 2009 at 1:32 PM
    TodaGuy
    Oregon
    Well for a fraction of the price of forced induction I could regear, do an entire aftermarket exhaust from head back, cai, maf tune and probably be pretty happy with that but I guess more then anything I'm just tryin to gain any mpg's I can at the lowest cost to do so. Thats why I have been trying to find out if the URD Maf Cal. will have any effect on simple every day driving. Thanks for the ideas and keep em comin!
  10. May 25, 2009 at 3:26 PM
    TodaGuy
    Oregon
  11. May 25, 2009 at 4:47 PM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Sierra Vista, AZ
    I have TRD intake/exhaust, URD y-pipe, URD MAF, and Doug thorley headers. As someone stated already, for such little power gains it may not be worth it. With all those mods and a tune i am turning 215 RWHP and im driving a dub cab on 33's as well.
    If i could do it again i would probably still do all the exhaust because i love it, but i would have gotten the APR X-1 instead of the MAF..... and i would get supercharged too.
  12. May 25, 2009 at 4:53 PM
    TodaGuy
    Oregon
    What kind of MPG are you getting with that setup?
  13. May 25, 2009 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, Re gearing is the Best way to return performance lost from a lift and tires. It would give the largest benafit for the money.
  14. May 25, 2009 at 4:59 PM
    TodaGuy
    Oregon
    ya but it would prob cost around $1500 do regear:( I think im screwed. I just wanna know what poeple with the URD MAF Cal. are getting for mpg during everyday driving.
  15. May 25, 2009 at 7:44 PM
    TodaGuy
    Oregon
    anyone with urd maf cal?
  16. May 25, 2009 at 7:54 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    the urd maf cal will help with the mpg, but your going to have to tune it a little to get the best results. which means buying a few more things to get it tuned right.
  17. May 25, 2009 at 7:55 PM
    TodaGuy
    Oregon
    even when the truck is in closed loop i should still see an mpg improvement with that urd?
  18. May 25, 2009 at 8:12 PM
    jaxchrisfla
    flooriduh
    lots
    you will see a little gain. the maf cal is more for a more smooth power band and better mpg really. not really for more hp. you may gain some just because your afr's are not in a good spec in a given rpm, so either making it more rich or more lean, is where youll get some power.
  19. May 29, 2009 at 2:07 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I have a 1st gen. I thought about the urd maf as well. What accessories are needed to properly tune it? As long as this product will not hurt my mpg I would like to look into it. I have the 3.4L. I have wanted to get into the computer aspect of performance, is this a good product to start with? I have a CAI headers and a custom exhaust (cut the cats out). I built my truck to get good highway gas mileage and it gets around 25. Would this help at all if I learned how to properly tune it. Any help would be apreciated. Also any other suggestions for other performance chips would also be helpful.
  20. May 29, 2009 at 5:29 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    You could always leaf blower it? LoL
