urd maf
Discussion in 'Performance and Tuning' started by flipkid420, Jul 1, 2007.
  1. Jul 1, 2007 at 9:17 AM
    flipkid420
    flipkid420 [OP] Member
    has anyone installed or use the urd maf on there trucks and if you did was there a big increase in noticable power
  2. Jul 1, 2007 at 12:35 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    They are highly recommended if you want the most out of your intake and exhaust.
  3. Jul 1, 2007 at 3:24 PM
    flipkid420
    how does the thing work is it easy to install where does it hook up too I wonder what the dyno whould be on my 2.7 with intake and exhaust looking for a header any suggestions maybe sema
  4. Jul 1, 2007 at 4:16 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    I honestly don't know of many for the I4s.
  5. Jul 2, 2007 at 12:42 AM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    The URD MAF sensor calibrator basically gives you control over your Air/Fuel Ratio. You can add or remove fuel where needed to get the most power out of your mods. There's 5 wires that splice into the ECU wiring.
  6. Jul 2, 2007 at 7:45 AM
    flipkid420
    air to fuel ratio where do you get specs on that data and how will I the operator of the urd know what to set them at Iam a novice when it comes to engine and performance enhancements.
  7. Jul 2, 2007 at 1:57 PM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    You will either need to get a wideband O2 sensor hooked up or else you can use a dyno to get feedback on what the air/fuel ratio is.
    URD can either send you a map that makes no changes to fuel (leaving it to you to tune it where you want) or they have a map available with their cold air intake system that will help to get a better AFR is your only mod is the intake. Everytime you add a new performance mod, you can go back into the software and retune to make the most power out of it.
  8. Dec 2, 2007 at 10:05 PM
    stokedsurfer
    stokedsurfer Member
    98 TRD 2.7
    Downey off road cold air intake optama blue top
    check out http://www.lcengineering.com/, and downey off road both are toyota only enthusists and both do lots of research on products for there headers.
  9. Jul 17, 2009 at 8:46 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    do they have a map for exhaust and air intake that can be pre programmed
  10. Jul 24, 2009 at 11:08 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    Good question. I am wondering the same thing. :notsure:
  11. Jul 25, 2009 at 9:11 AM
    Alex352
    Alex352 Well-Known Member
    Alex
    Oregon
    07 Tacoma Dbl Cab
    http://www.tacomaworld.com/forum/2nd-gen-builds/281569-alex352s-build-thread.html
    Will the splicing mess anything up if u want to turn it back to stock. Is there a way to not have to splice into the ecu? Thanks
  12. Jul 25, 2009 at 9:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They have a "Plug & Play" version that just plugs in. It has wireing harnesses already attached. Also, they do come with a MAP for Intake and exhaust already installed. Its a generic MAP, and, ultimatly, for best performance, a dyno tune is the best.
