URD Mark 2 Y Pipe V6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dean62, Jul 2, 2020.
  1. Jul 6, 2020 at 12:59 PM
    2dogs_and_a_taco
    2dogs_and_a_taco Well-Known Member
    Nick
    2020 Army Green Taco
    Ah! Makes sense. I’ve had mixed results with different exhaust setups on street cars but tubing diameter was definitely a factor. Is anybody on here running widebands and tuning their own trucks?
  2. Jul 6, 2020 at 4:09 PM
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    If I remember correctly that would be with the individual header tubes. But from the collectors back larger diameter pipe within reason works better. The previous pulse helps scavenge the next. That is why we ran crossover headers on the late models we raced. By combining header tubes from opposite heads you could increase the scavenge effect. The reason being was the firing and exhaust were timed closer to each other in a crossover configuration.
    Roostfactor likes this.
  3. Sep 25, 2021 at 8:19 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Anymore feedback on the URD MK2 y pipe, or others? I'm seriously looking to do this for the clearance but don't want a cel problem to deal with.
  4. Sep 25, 2021 at 9:17 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    I had the URD Y pipe, and i don't think it was built with gaining clearance in mind. The driver side pipe goes right under the transmission pan, and sits lower that everything else under my truck when I had it.
    I now have aFe's ypipe which is a much cleaner install.
  5. Sep 28, 2021 at 6:41 AM
    02Duck
    Thanks for the info.
  6. Sep 28, 2021 at 6:42 AM
    Dean62
    Dean62 [OP] Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    does the Afe y pipe throw a check engine light after install?
  7. Sep 28, 2021 at 6:47 AM
    Rainoffire
    No check engine light on my end.
    For the URD, I had a CEL when I first installed them. I then used copper anti-seize for the O2 sensors and no more CEL for the 2 years I owned it.
  8. Jun 18, 2025 at 5:28 AM
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    I am looking at making this purchase soon…
    Anyone have issues with drone from the y pipe itself? I will likely run it with an oem catback
  9. Jun 24, 2025 at 7:37 AM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Installed this last month. It replaced the AFE y pipe with hi-flow cats I had for the last two years.
    Sole purpose for going with the URD was to get rid of the low hanging dip in the stock routing, which the AFE followed.
    I kept the same catback, the AFE rock basher.
    No noticeable drone more or less than the AFE. I haven't had a stock configuration in years so I can't attest to any sound. It's deeper, but smooth, louder than some, but modestly.
    The URD sits a little close to the transmission pan which is not really an issue, but because overkill is fun I wrapped that portion of the URD pipe with titanium exhaust wrap to keep exhaust heat from the pan.
    Only possible drawback to the URD pipe is that any transmission issue involving removing the pan will be a little bit more of a hassle.
    Had to modify my RCI skid plate to accomodate the URD. @ClassyTacos on YouTube highlights this easy fix in his install video.
    If you're already a high mileage truck and haven't yet, maybe go ahead and do a transmission filter change prior to install? I did not (truck at 112K) but some might want to do this.
    Truck profile looks so much cleaner without that weird looking dip the stock y pipe configuration takes. Definitely and obviously helps a bit with mid-body clearance.
    And I am pretty pleased at the unexpected gain in the mpg's. Nothing crazy, but absolutely noticeable.
    I was very surprised at this as no other exhaust system has had that effect and I've had quite a few configurations.
    So yeah, big fan of the URD y pipe all around.
    02Duck likes this.
  10. Jun 24, 2025 at 8:19 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    THIS looks like a great pipe and I can see the benefit, now for the $10,000 question, how do you think this will pass state insp & doesn't this have down stream o2 sensors in the oem pipe ??? Im all ears
  11. Jun 24, 2025 at 8:31 AM
    Phich
    San Antonio
    Six Demon Bag
    Truck registered in Texas so not an issue for me but for those states with stringent emissions tests (CA,CO, etc), an issue is certainly possible.
  12. Jun 24, 2025 at 8:35 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    >>>> Like me NYS THAT SUCKS.
  13. Jun 24, 2025 at 8:43 AM
    Phich
    San Antonio
    Six Demon Bag
    Ah, politics... It is what it is...
  14. Jun 29, 2025 at 1:35 PM
    black3rdgen
    black3rdgen Well-Known Member
    STL
    3G on 35s, 5.29s
    YW tune, 5.29s, equal length dual exhaust, 2000w audio system
    Go with equal length. You won’t regret it
