URD O2 Sensor help
Discussion in 'Performance and Tuning' started by cookee62, May 30, 2013.
  1. May 30, 2013 at 8:14 PM
    cookee62
    cookee62 [OP] Well-Known Member
    Lake Mary, FL
    06 DBL Cab
    URD SS, URD Y-Pipe, DTLT Headers, 3" URD Cat Back, Fox 2.5 CO, TC UCA, Fox Rear Resi, SS brake Lines, All pro 1.5" leafs, Halo Projector Headlights, WE Bead-lock Rims, 33 BFG AT, No Sway Bar
    so Have any of you had this problem? I have DTLT headers and with that a URD o2 sensor and I keep getting a check engine light code PO154 low voltage so I changed the o2 senor and put a new one in but still same code? I'm thinking the URD o2 has shorted out. Any one have a problem like this? Is it covered by URD? Ive left Gadget a voicemail but didnt hear back but I'd figure I'd ask on here before I call again
    Thanks,
  2. May 31, 2013 at 11:19 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    Not sure if we have spoken or not, but you can email Tech Support at Support@URDUSA.com or call 877-8URDUSA x3
    Gadget
