URD o2 sim + water = code? maybe?
Discussion in 'Technical Chat' started by NYCO, May 20, 2011.
  1. May 20, 2011 at 9:02 AM
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    basics: 2006 TRD off-road 4.0L with Doug Thorley LT and o2 sims, code was thrown
    so i was wheeling through kane creek this past weekend in moab and my check engine light came on. at first thought, we went to the gas cap to make sure it was on tight and it was loose. so we thought that must have been it and just need to get the light reset. wrong. just took it in to my buddy at toyota and the code came from iirc bank 2 sensor 2 (downstream o2 sensor). i remember hearing that some people have had issues with the sims and running through water.
    has anyone had this issue?
    and if so, how have you fixed it?
    thanks
  2. May 20, 2011 at 9:08 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Are you an xrunner?
    Edit: Never mind, gotta learn to read better. It might just be very well as simple as a bad O2 Sensor if she got dumped in water. first thing I'd do is look underneath and make sure the sensor wires are all still attached in the correct places
  3. May 20, 2011 at 9:29 AM
    NYCO
    bOb
    Colorado
    dents & scratches
    yea i'll be taking apart the connections this weekend to see how everything looks...hoping that it's not the sensor and just a connection issue (that's repairable!)
  4. May 20, 2011 at 10:11 AM
    NYCO
    bOb
    Colorado
    dents & scratches
    awesome, just read through your thread there...thanks! i'll try out that zip lock bag idea too for future water endeavors
  5. May 20, 2011 at 2:59 PM
    NYCO
    bOb
    Colorado
    dents & scratches
    got my ultragauge installed and these codes were the culprit
    P0158 - 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0606 - HO2S Heater Resistance (Bank 2, Sensor 2)
  6. Jun 1, 2011 at 8:27 AM
    NYCO
    bOb
    Colorado
    dents & scratches
    turned out to be a bad o2 sensor...replaced the sensor that threw the code and haven't had an issue since. The sensor voltage has been acting normal again. i put the o2 sim in a ziplock bag and duct taped the seems for good measure too.
  7. Jun 1, 2011 at 12:55 PM
    NYCO
    bOb
    Colorado
    dents & scratches
    got both rear sensors for $105 at rock auto so it wasn't too bad but still ain't cheap...figured to get it while i could save a couple bucs on shipping and have a spare for when the second rear goes
