URD O2 Sim.
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaforlife, May 28, 2010.
  1. May 28, 2010 at 7:36 AM
    tacomaforlife
    tacomaforlife [OP] Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    Just bought the URD O2 sim. for my truck so i can get rid of the cel from running no cats anyone else running the URD O2 sim.?
  2. May 28, 2010 at 9:59 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I have it, but found out I didnt need it, and just needed to replace my o2 sensor's again... But Ive great things about it, and it works like a charm..
  3. Jun 1, 2010 at 7:57 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    well my O2 sim. comes in today now time to wait by the door!:popcorn:
  4. Jun 2, 2010 at 8:09 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    got my O2 sim of course it didnt come with instructions how do i install it ? where at?
  5. Jun 2, 2010 at 8:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    take the plastic runner up by the front passenger seat......lift the carpet up, and you'll see some plugs. follow the one from the rear sensor to under the seat...then unplug under the seat and plug in the o2 sim.
  6. Jun 2, 2010 at 9:13 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    o cool thanks. only bad part is im still getting a cel even after i disconnected the battery.??:(
  7. Jun 3, 2010 at 8:36 AM
    ETaco23
    Evan
    PNW
    Is the CEL the P0420? Have you checked to make sure its not another code? I know that some guys have had other codes appear after installing the Sim. Check all your connections, and then make sure that your rear o2 is still good. Dont know what it could be man, sorry....
  8. Jun 3, 2010 at 7:49 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    i played with it again this morning at left the battery disconnected for a while then hooked it up then it work ive driven around all day with no cel and my gas mileage seems to be better as well:D
  9. Jun 3, 2010 at 9:21 PM
    ETaco23
    Evan
    PNW
    Awsome!
  10. Jun 5, 2010 at 4:01 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    well the check engine light came on again but looks like it could be the MAF sensor. its caused the cel to come on before do to dirt build up, sure thats some help from the deck plate. :rolleyes:
  11. Jun 5, 2010 at 6:15 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    get some maf cleaner and spray the sensor down real good.
    what kinda filter are you running?
  12. Jun 5, 2010 at 6:22 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    i have the 02 sim. I get a code if I have an exhaust leak. I cant keep my header bolts tight and every couple months they start loosening up again and the cel comes back on.
  13. Jun 5, 2010 at 11:13 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    i used sensor cleaner before the last time i got a cel from the maf sensor and it fixed it. im using a k&n filter
  14. Jun 5, 2010 at 12:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd do it again...and ditch the k&n filter. if you over oil it..the oil can get on the maf sensor. go with an afe pro dry s.
  15. Jun 5, 2010 at 2:05 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    yea i make sure not to over oil it but it may be the filter makeing the maf sensor so dirty.
  16. Jun 5, 2010 at 10:58 PM
    ETaco23
    Evan
    PNW
    Wow Matt, that sucks. Have you tryed some thread lock on them? I
  17. Jun 5, 2010 at 11:00 PM
    ETaco23
    Evan
    PNW
    I had the K&N before, and it always got dirty way too fast. After just 3-4 months it was getting dirty. So I switched to the dry AFE. Mucho Better!!
