URD PERFORMANCE
Discussion in 'Performance and Tuning' started by IndianTaco, Aug 2, 2011.
  1. Aug 2, 2011 at 5:46 PM
    IndianTaco
    IndianTaco [OP] Well-Known Member
    Just order a MAF CAL Tuned for my truck cant wait to get it installed.
    I know it take soldering to install it. but how long will the install take? :confused:
  2. Aug 2, 2011 at 5:47 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Two hours tops. Take your time. You're cutting wires to your ECU. It's easy but it's worth the extra time. Check twice, cut once.
  3. Aug 2, 2011 at 7:58 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Congrats! I was wondering if this is really worth it? Im thinking about doing a CAI later on, and maybe getting the MAF Cal.
    But still undescided....
  4. Aug 2, 2011 at 10:48 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    The maf cal will make a good bump in power for ya.
  5. Aug 3, 2011 at 5:48 PM
    ETaco23
    Evan
    PNW
    really??? well I might have to try it out, when I get a CAI...
    I have a AFE filter in my stock intake, and charcoal filter removed. Would this be similar to a CAI, or does a CAI suck more air/faster? I assume the bends and silincer on the stock system dont help the air flow....
  6. Aug 3, 2011 at 5:57 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    If you're getting CAI, consider URD's CAI. I personally do not have it, but have done research on it and am planning on buying it when the time comes. It sucks in air from the grille, not the fender (stock) or engine bay (k&n), so it's true CAI. The kid DOES require cutting of the body by the headlight, but includes a template for cutting and a rubber gasket like object to clean the cuts up. Gadget does his research, and will not distribute this product without knowing it works.
    URD TRUE CAI
    from URD website
    The MAF calibrator and intake will run you $488.00, not including shipping.
  7. Aug 3, 2011 at 7:37 PM
    ETaco23
    Evan
    PNW
    Yeah, Ive considered that kit, but I sont think its great for my area, (pacific NW).
    I get alot of rain and am sometimes getting the truck soaked.
    I like the AFE stage2 Si Intake..
  8. Aug 3, 2011 at 7:53 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    They do make a shield and you can purchase filter covers. I think very little water gets in there regardless of the situation, there is a beam on your OEM grill (if you have yours) and the water, if inducted, has to go upwards and travel about 2 feet.
    But i do understand your concern, go with the AFE after URD. High quality products.
  9. Aug 4, 2011 at 9:03 PM
    IndianTaco
    got it in the mail today:D cant wait to install it!!!
  10. Aug 4, 2011 at 9:21 PM
    acdronin
    acdronin Well-Known Member
    Ok, I labeld the harnesses as I pulled them out to make sure i didn't put them back in the wrong place, then, without distractions, i checked each wire that i'm supposed to solder onto THREE times to make ABSOLUTELY freaking sure that the location and color were correct. I noticed that I had to pull on the lowermost harness to get enough play to work with, I then soldered the bottom ones first because they were the hardest ones to get to. Make sure you use some kind of insulation to ENSURE that nothing gets grounded.
  11. Aug 4, 2011 at 10:07 PM
    acdronin
    It was an extra little boost below 3000rpm, mainly because it corrected the MAF data going to the ECU, it leans out the fuel which helps. Ummm, wide open?, Above say 3500? Between that and the K&N and the cat-backs, to anyone who says it doesn't make much of a difference, drive your truck, then drive mine, it fucking hauls ass.
  12. Aug 4, 2011 at 10:14 PM
    joeblaze78
    joeblaze78 Member
    Joe
    Los Angeles
    X Runner
    Urd tcai,DTLT headers,Urd Maf Cal,Urd o2 sim and flowmaster 40
    I love mine i have both the maf cal and tcai in my xrunner and it screms after 3500 rpm
  13. Aug 4, 2011 at 10:21 PM
    acdronin
    Tell ya what, I'd race your AC, empty with just you in the truck, against me, in my DC, WITH the Rack, With the shell, with three other people in the truck, AND 400lbs of tools. I'd beat you like a rented mule
  14. Aug 4, 2011 at 10:37 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Tell you what, you bring your AC, you bring your DC, and I will race you both and I dont even have a MAF cal... Any takers???
  15. Aug 4, 2011 at 10:39 PM
    acdronin
    uh, yeah, you have a supercharger, of course you're gonna beat us both
  16. Aug 4, 2011 at 10:42 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    So, you never said I couldnt bring it... I figured since you guys were measuring your dicks I would just slap my supercharged horse cack on the table and declare it a victory. LMAO...
  17. Aug 4, 2011 at 10:44 PM
    acdronin
    Allright Chas, if it makes you feel better....yes you have a very fast truck
  18. Aug 4, 2011 at 10:48 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    I am just jerking you guys around. Nothing personal. I have actually yet to push my truck to an excessive speed. But man does it get up to normal speed excessivly quick.
    On a side note, I am trying to decide if I want/need the URD Maf cal, fuel pump, and 7th injector upgrade for my truck.
  19. Aug 4, 2011 at 11:00 PM
    acdronin
    it's all good
