URD Short Shifter problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deceitfulfate55, May 7, 2011.
  1. May 7, 2011 at 6:13 PM
    deceitfulfate55
    deceitfulfate55 [OP] Well-Known Member
    Tyler
    Hanover, Pennsylvania
    10 Tacoma TRD Off Road
    URD Short Shifter, Slim Cubby BiXenon and Fog HIDs, Bull Bar, Blackout Grill, Plasti-Dipped Front Valance and Badges, Diff Breather Relocation
    Hi everyone, i recently installed the URD short shifter on my 2010 Tacoma OR TRD 6 Speed. The shifter grinds slightly in reverse when i drive it normal to quick, if im really gentle in reverse it wont grind at all. I installed it according to gadgets pdf file, i also contacted gadget about this problem to hear his input. Has anyone else had this problem or heard of this problem. If anyone has any answers id appreciate the help, thanks.
  2. May 7, 2011 at 10:42 PM
    gbtoy4x4
    gbtoy4x4 Well-Known Member
    Greg
    Las Vegas
    2010 Silver TRD AC OR 4x4 6sp
    Factory Silver Sport Grill, Gray TRD Shift Knob, BFG 285/75/16 AT's, Debadged, AFE Cai, TRD Short Shifter, Redline Hood Struts, Leer Topper, Budbilt Front, Mid+Xcase Skids, ELocker Skid, Icon C/O, Built Right UCA's, Rear 2in AAL w/Bilstiens, AP U-Bolt flip, 1" 4Crawler Body Lift, Relentless Front Bumper w/Lights + Sliders, Rear Breather Mod, 5 ProComp 7089 Rims, AP SS Brake Lines, Famous Fab HC Rear Bumper W/Swing Out Tire Carrier, Synthetic Brake Fluid, Synthetic Power Steering Fluid, Front Superbumps, Hood Blackout,
    May need to define grind
    After installing mine, reverse is a little difficult to get in, also gears mesh in just fine
  3. May 7, 2011 at 10:58 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Never heard of a grind problem, but most people notice some kind of difficulty going into reverse. I don't know if that difficulty went away, or if I just got used to it. Maybe a combo of both.
    GL
  4. May 8, 2011 at 1:09 AM
    deceitfulfate55
    Tyler
    Its definately a tranny grind, I smell tranny burning, but only when in reverse, it makes a distinct noise of grinding
  5. May 8, 2011 at 1:56 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    did you set the set screws with a punch?
    they can easily loosen up with all the vibrations that go on in that area.
  6. May 8, 2011 at 2:17 AM
    kauaibuilt
    kauaibuilt U no kea but AINOFEA!
    LA/SGV
    2011 DCSB
    Check out my sig...
    sounds like what happens when I let out the clutch too early or dont push it in all the way. Compress clutch completely and give yourself a 1/2 second more to make sure youre completely in "R" before releasing.
  7. May 8, 2011 at 8:13 AM
    deceitfulfate55
    Tyler
    I set the set screws and threadlocked them, pushed the clutch in all the way and held it and pushed it in reverse and made sure it was in all the way and went as far as the throw would allow, still grinds
  8. May 8, 2011 at 10:05 AM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    To aid finding reverse, if you will "slap" the shifter while going in the direction of reverse, the shifter will fall into reverse much easier.
    I know it sounds stupid, but it works.
  9. May 8, 2011 at 11:13 AM
    deceitfulfate55
    Tyler
    i actually do slap it over into reverse, i have no problem putting the truck into reverse it goes right in. It doesnt start grinding putting it into gear or sitting in gear, only when the truck is actually traveling in reverse(unless traveling very slowly and easing the clutch out very soft and slowly.
  10. May 8, 2011 at 11:19 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Does it shift well in all other gears?
  11. May 8, 2011 at 11:23 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Rear drivers don't need reverse :cool:
  12. May 8, 2011 at 6:28 PM
    deceitfulfate55
    Tyler
    Every other gear is fine, when you accelerate you can feel the tranny pull on the shifter if you hold on, its almost like if I gas it enough to make it pull that's when it grinds
  13. May 9, 2011 at 4:39 AM
    deceitfulfate55
    Tyler
    Yea that's probably what's going to end up happening, problem started immediately after installing shifter but who knows stranger things have happened, its a brand new truck so luckily if it is something else I've got the warranty
  14. May 14, 2011 at 10:50 AM
    deceitfulfate55
    Tyler
    Put back to stock, no longer grinding in reverse...
  15. May 14, 2011 at 7:09 PM
    deceitfulfate55
    Tyler
    Yea follow the pdf file linked for instructions that was included with the shifter 100%, double checked to make sure before i removed the shifter that everything was correct. I trimmed around the shift tower like gadget suggested and drove around without the console and rubber boot installed so i could watch to see if the shift tower was infact rubbing, it was not. I reinstalled stock oem shifter, works perfectly again, no grinding or smoking or fluid burning smell. Beats me..I know urd makes quality parts, must have just gotten unlucky
  16. May 18, 2011 at 4:03 PM
    deceitfulfate55
    Tyler
    Problem solved, shift tower was rubbing floor board as transmission rocked only while driving in reverse a certain way; removed small area of floor board that was touching.
  17. May 19, 2011 at 6:18 PM
    deceitfulfate55
    Tyler
    The square cutout above the shift tower in the floorboard had a little notch that was quite cut uniform like the rest of the corners in the lower left portion, that's where it was rubbing.
  18. Aug 5, 2013 at 4:41 AM
    bwanamukubwa
    bwanamukubwa Well-Known Member
    Tennessee
    I know this is an old thread, but thank you for coming back and reporting on your solution. I had the exact same problem and this helped me out.
