URD Short throw shifter on the way!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NYCO, Dec 22, 2010.
  1. Dec 22, 2010 at 2:58 PM
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    Finally had some $$ free and decided to get my truck a xmas gift, so I went for the URD Short throw shifter kit...should be coming via FedEx on Friday!!!:headbang:
    Anyone who has this have suggestions on installation? Is it pretty straight forward? i've hear the instructions are good quality and shouldn't take more than a half hour...any special tools i need for the job?
  2. Dec 22, 2010 at 3:09 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Be careful separating the shift lever from the transmission housing.
    If you have a bench vice it'll probably help with the bushing...Be ready to battle that little guy for a bit.
    Otherwise- Enjoy...and don't freakout if the shifts are stiffer than before (specially Reverse)..Just take the time to make sure there is no metal on metal binding and work to find a comfortable technique to shift.
  3. Dec 22, 2010 at 3:20 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Need to do this install too. Have had the thing sittin here since the group buy thing awhile back.........4 cyl 5 speed tho.
  4. Dec 22, 2010 at 3:21 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Good choice! You'll like it.
  5. Dec 22, 2010 at 3:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I can not think of anyone who said they didn't like it. I'm sure they are out there...I just haven't heard of it.
    If you are worried about it- You can just not peen the set screws-Try it out and if you don't like it-Take it out and sell it on here...
    Keep your eyes peeled cause URD drops the price to 99 bones now and again...
  6. Dec 22, 2010 at 6:13 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    They are currently at $99.
    I have installed several. No special tools required. The instructions are excellent.
  7. Dec 22, 2010 at 9:35 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
  8. Dec 27, 2010 at 9:03 AM
    NYCO
    bOb
    Colorado
    dents & scratches
    Thanks for the tips....installation went smoothly...took my time and read the directions like 4 times before the process to get a handle on it which helped a bunch...by the time i did the install it went by pretty smooth...taking everything apart was straight forward, when it came time to remove the actual shifter housing, i couldn't get my rubber mallet a solid hit on the tower so i had to find a piece of wood to tap it loose then i used some elbow grease to yank it off...the plastic bushing was stubborn getting off too, but with some help of my needle nose handle as extra grip, that baby went flying off, and a little tap of the rubber mallet to get it back on...peening the set screws was a nervous point and i hope i got the metal over enough to keep those babies in there...but got everything in like planned, torqued everything down to the specified lbs with all the grease, lock tight and sealant suggested so hoping things work out in the long run too...
    takes a bit to get used to the shorter throws but so far liking the kit...1st-2nd shift seems a bit stiffer than the rest and reverse takes a bit to get used to the stiffer shift, but 2-3-4-5-6 is smooth as butter...
    now to start saving for some new sliders and long tube headers...and start fab'ing up a new back bumper with my buddy
  9. Dec 27, 2010 at 9:08 AM
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    do they make a set for the 5 speed or will this set work ok for it?
  10. Dec 27, 2010 at 12:19 PM
    NYCO
    bOb
    Colorado
    dents & scratches
  11. Aug 22, 2014 at 10:30 AM
    kain102708
    kain102708 Well-Known Member
    Stan
    Denver
    08 DBCB TRD Off Road
    rear locker anytime mod, lifted
    Just purchased this short shift kit with the URD Stage III clutch kit. I had them include the lightweight flywheel as well as the upgrade TOB kit. Can't wait to do this little project next weekend over Labor Day weekend.
    thecoz likes this.
  12. Sep 4, 2014 at 2:25 PM
    kain102708
    Stan
    Denver
    Hey Bob, how are you liking the short shift. I just got all of this installed on my truck over the holiday weekend.
    URD stage III clutch kit w/ light weight flywheel
    URD short shift
    Had to buy a new jack but got it done over the weekend with some help in the garage.
  13. Sep 4, 2014 at 2:36 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Have one in my 4cyl....love it
  14. Sep 4, 2014 at 3:11 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I'd buy one if it wasn't another $99 in shipping to canada. :p
  15. Sep 30, 2015 at 6:22 PM
    thecoz
    thecoz Well-Known Member
    Tim
    Columbus Ga
    07 DC 4x4 6 speed
    K&N drop in, flowmaster 40 dumped before rear axle, 20% tint up front. 3 inch fat bobs coilover. Rear aal and zone shocks. LR UCA. 1.5 inch rear block. CBI moab 2.0 front bumper with wrap around guard. Smittybuilt 9500lb winch. URD short throw shifter.
    Doing this in a couple days when it comes in the mail, very excited.
  16. Oct 10, 2015 at 5:50 PM
    thecoz
    Tim
    Columbus Ga
    07 DC 4x4 6 speed
    Installed and loving it.
