URD Spec-U Exhaust, 2016+ Tacoma V6 AC/LB, DC/SB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Glenn_R, Jun 11, 2017.
  1. Jul 22, 2017 at 6:21 PM
    #201
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    I have the TRD cat back exhaust and have no rasp or drone and it has a quite pleasant sound IMO. When I added the URD y-pipe last February it did not add any rasp or increased sound levels. I would really like to add the spec u y-pipe and mate it to my TRD cat back but it looks like that is not a possibility. Gadget was great and sent me the updated version of his y-pipe but it still has some clearance issues. By the way, it is possible to have a tuned exhaust without having equal length pipes since each exhaust pulse from each cylinder has a finite length that can be calculated. It is just the easiest way but not the only way to produce a tuned exhaust. The first picture below shows the clearance for my first y-pipe while the second picture shows the clearance for my second y-pipe. i may have to find a shop that has a mandrel bending machine to fix this.IMG_0245.jpg IMG_0375.jpg[/QUOTE]
  2. Jul 22, 2017 at 6:28 PM
    #202
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    [/QUOTE]
    Interesting! Maybe it really all comes down to the massive magnaflow muffler supplied with the spec u in that case! My setup was much louder with y pipe and a straight through magnaflow muffler but maybe you're right and that's just due to the muffler design! And you are correct sir, technically you could also utilize two different sized y pipe sections to balance out back pressure from one side to the other!
    skyking3[QUOTED] likes this.
  3. Jul 23, 2017 at 12:43 PM
    #203
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I'm convinced Toyota put that shiny pointless bracket there to piss me off
    Restrictive junk
  4. Jul 23, 2017 at 12:48 PM
    #204
    Ice8
    Ice8 Well-Known Member
    Vancouver, BC
    2017 MGM Tacoma TRD Off Road SB
    A few listed in the signature
    Took an impact driver with a 10 mm socket to drive the bolts off that shield. Was a pain in the ass.
  5. Jul 23, 2017 at 12:49 PM
    #205
    dYL0n
    Dyl0n
    New Orleans, LA
    I just took off 1 12mm bolt off that bracket and it came out
  6. Jul 23, 2017 at 12:52 PM
    #206
    Ice8
    Vancouver, BC
    Ah I removed the 2 bolts on the cat cover.
  7. Jul 23, 2017 at 12:56 PM
    #207
    Ice8
    Vancouver, BC
    Day 2 of the exhaust even my wife confirms it seems to be breathing better. She also feels a response difference and merging feels easier.
    Silent under 2500 rpm, bit of a burble 3000-4000, over 4000 rpm sounds incredible. More sports car like than anything.
    Sadly nothing will ever sound like a good old V8.
    Heepspo and Nedrolls like this.
  8. Jul 23, 2017 at 1:05 PM
    #208
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    I said the same thing...that bracket I think is there incase somehow the exhaust came lose it won't just roll in the street...otherwise useless lol
    And I agree very restrictive piping
    taco 16 likes this.
  9. Jul 23, 2017 at 1:11 PM
    #209
    dYL0n
    Dyl0n
    New Orleans, LA
    I hit the halfway point. Any tips?
    SilverII likes this.
  10. Jul 23, 2017 at 1:17 PM
    #210
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    Drink a beer and continue with install, it helps.
    dYL0n[QUOTED] likes this.
  11. Jul 23, 2017 at 1:19 PM
    #211
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    I probably can't help much, I just added a urd ypipe to my TRD cat back, but I do hope the holes on your flanges all fit the bolts because they were to small and we had to use a dremel to make them bigger. It was off by a few mm.
    Make sure all the bolts are loosely fitted so you have some wiggle room to adjust if needed.
    Did the exhaust come with exhaust clamps? If not buy some. I thought they were included.
  12. Jul 23, 2017 at 1:26 PM
    #212
    dYL0n
    Dyl0n
    New Orleans, LA
  13. Jul 23, 2017 at 1:36 PM
    #213
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    It's a grease shield, prevent flying grease (from front drive shaft slide part) to hit the catalysator.
  14. Jul 23, 2017 at 1:38 PM
    #214
    dYL0n
    Dyl0n
    New Orleans, LA
    No the metal bracket. U shaped.
    SilverII and oscolivar1 like this.
  15. Jul 23, 2017 at 1:41 PM
    #215
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    I would assume so....is the other hanger on the other side being used?
  16. Jul 23, 2017 at 1:42 PM
    #216
    FinnJ
    Finland
    With WD40 they are very easy.
  17. Jul 23, 2017 at 1:44 PM
    #217
    FinnJ
    Finland
    U shaped bracket is what I just answered. Take a look under.
  18. Jul 23, 2017 at 2:08 PM
    #218
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Try running it with just open headers :laughing:
    https://www.instagram.com/p/BWGpsuIADg6/
    Doug Thorley long tubes in that video.
    trd_overland and oscolivar1 like this.
  19. Jul 23, 2017 at 4:11 PM
    #219
    Ice8
    Vancouver, BC
    Hand tight for from Y pipe, get it all aligned nicely then snug up. I reran my O2 sensor wire on the right side to make it prettier and give it more clearance.
    Use a Jack for the next set of pipes/muffler for easier alignment. Saves you from doing what I did balancing on my knee.
  20. Jul 23, 2017 at 4:13 PM
    #220
    dYL0n
    Dyl0n
    New Orleans, LA
    I'm done. The whole thing fits like shit. But no leaks and it sounds ok.
    For anyone who said it sound stock below 2500 RPM, that's a damn lie.
