URD Spec-U headers gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chueflee, Aug 4, 2023.
  1. Aug 4, 2023 at 8:38 PM
    chueflee
    chueflee [OP] Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    URD Spec-U headers, I have these headers on my 2013 tacoma trd offroad v6.
    It's leaking passenger side. Do we need gaskets specific to these headers? Or can I just get the oem gaskets?
  2. Aug 4, 2023 at 8:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Oreo Cat likes this.
  3. Aug 4, 2023 at 8:53 PM
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
  4. Aug 4, 2023 at 8:55 PM
    chueflee
    Chue
    really that so much easier thanks.thanks
  5. Aug 4, 2023 at 9:01 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    It’s leaking where the header bolts to the block? Or where the header bolts to Y pipe?
  6. Aug 4, 2023 at 9:02 PM
    chueflee
    Chue
    header to block
  7. Aug 4, 2023 at 9:04 PM
    Oreo Cat
    When I installed mine I just used some new OEM ones
    TnShooter and chueflee[OP] like this.
  8. Aug 4, 2023 at 9:09 PM
    chueflee
    Chue
    nice that is so much easier. I can get the oems from Amazon
    Oreo Cat[QUOTED] likes this.
  9. Aug 4, 2023 at 9:26 PM
    Oreo Cat
    just be aware there is a difference between the 05-11 and 12-15 parts
  10. Aug 4, 2023 at 9:28 PM
    chueflee
    Chue
    i'm checking parts with my vin number. Thanks
  11. Aug 5, 2023 at 9:09 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Lucky it’s the passenger side! Can’t go wrong with OEM, but I got an OEM-like FelPro gasket because it was only $10. As long as it’s the correct 2-piece steel it should be fine. Make sure you get the correct type depending on whether you have air injection or not. Assume you re-used the old one when you installed the headers?
    TnShooter likes this.
  12. Aug 5, 2023 at 9:10 AM
    chueflee
    Chue
    Yeah I used the old ones. It start leaking when I changed the studs and nut to arp. I'm just getting oems
  13. Aug 5, 2023 at 9:15 AM
    TireFire
    Olympic Peninsula
    Hope you chased the threads before putting in the new ARP studs. If they didn’t seat correctly that might also cause a leak, even with a new gasket
  14. Aug 5, 2023 at 9:56 AM
    chueflee
    Chue
    the header is off i can go ahead and do that. Is their a torque for the studs?
  15. Aug 5, 2023 at 12:32 PM
    TnShooter
    Deogee
    STOCK
    Chilton says 16 INCH pounds.
    That can’t be right
    OEM Service Manual for my 07 says 16 ft/lbs. that sounds more like it.
    @Dm93
    chueflee[OP] likes this.
  16. Aug 9, 2023 at 10:06 AM
    chueflee
    Chue
    reinstalled new oem gasket. I put some copper high temp rtv around the gasket holes..both side. torque the nuts 17ft/lbs. still getting a leak...
  17. Aug 9, 2023 at 10:19 AM
    SmoothTRD
    SmoothTRD Well-Known Member
    Lesson to learn.... don't install useless aftermarket headers
  18. Aug 9, 2023 at 10:30 AM
    TnShooter
    Deogee
    STOCK
    I never seen a set of headers that didn’t need to be tighten up after the engine got hit for the first time. Then again a week or two later. They eventually settle in and don’t come “loose” after a few times of retightening.
    And I can’t say I ever torqued any headers either. Then again, I rarely torqued anything until I joined this site. :rofl:
  19. Aug 9, 2023 at 4:19 PM
    Oreo Cat
    Not sure how adding power is useless. I think a more important lesson to learn is not to make useless posts
    stickyTaco and 1slow4.0 like this.
  20. Aug 9, 2023 at 4:22 PM
    chueflee
    Chue
    I think I know what i did wrong I had turned the wrong way. Installed it upside down. Will let sealant cure 24 hours 1st
