URD SPEC-U LT review
Discussion in 'Performance and Tuning' started by hillbilly57, Jan 24, 2016.
  1. Jan 24, 2016 at 2:20 PM
    hillbilly57
    hillbilly57 [OP] Well-Known Member
    2010 trd off road
    Installed AFE stage 2 si and urd headers.This is just a hillybilly nothing scientific just using an ultra gauge em with the performance mode.My truck has 33'' 10 ply tires which slowed the truck, according to my ultra gauge my truck did 1/4mile in 16:44 now 15:80 .reduced by .64
    Truck pulls strong I'm impressed. Now 0 to 100 mph before 25:42 after mods22:57. You really feel the gains from 65 up big difference. NEXT week maf cal.
    THANKS URD FOR MY POWER BACK!
    shr133, Biscuits, TreyStewart and 2 others like this.
  2. Jan 24, 2016 at 2:26 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Just installed those headers as well. Very pleased.
  3. Jan 24, 2016 at 2:31 PM
    hillbilly57
    2010 trd off road
    Just wanted to get the power to turn them heavy tires and perform like stock.
    Will check gas mileage tomorrow.
    Hope to see a bump!
  4. Jan 24, 2016 at 9:41 PM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    Pics!
  5. Jan 24, 2016 at 10:43 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    not the most photogenic mods imho
  6. Jan 25, 2016 at 4:04 AM
    hillbilly57
    2010 trd off road
  7. Jan 25, 2016 at 4:17 AM
    hillbilly57
    2010 trd off road
    Before headers and intake .Love them headers
  8. Jan 25, 2016 at 11:38 PM
    rat107
    Kauai, HI
    Headers look a lot better than the stock Model A style exhaust logs haha.
    hillbilly57[OP] likes this.
  9. Jan 26, 2016 at 9:39 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    yeah but have u actually seen them installed on a tacoma? Mine are shiny thorleys and they still arent photogenic in those tight spots.
  10. Jan 26, 2016 at 2:21 PM
    hillbilly57
    2010 trd off road
    Pic when I first received them.
    rat107 likes this.
  11. Jan 26, 2016 at 2:39 PM
    hillbilly57
    2010 trd off road
    rat 107 I though you wanted pics of performance not headers,but I have some now.All I care about is performance but they look good too.20160126_173258.jpg20160126_173144.jpg 20160126_173144.jpg
    Torspd and rat107 like this.
  12. Jan 26, 2016 at 7:17 PM
    rat107
    Kauai, HI
    That's what I wanted to see!!!
  13. Jan 27, 2016 at 9:59 AM
    WOODEX M.E.
    Corey
    Maine
    I didn't bother to take pictures of mine. You can't see crap anyways with all the air injections system and crud in the way.
    Justus likes this.
  14. Jan 27, 2016 at 4:10 PM
    hillbilly57
    2010 trd off road
    Did you install them yourself and if you did how long did it take you.
    I haven't looked at the newer models with air injection but sounds like it's tighter to work on.
  15. Jan 27, 2016 at 5:33 PM
    WOODEX M.E.
    Corey
    Maine
    Not to be discouraging, but im prety mechanically inclined, and so arent theree guys helping me with it. 2 of them have done engine swaps both LS1s into a 944 and an old M3.
    It took the 4 of us, in a maching shop with a lift, 6 hours of work to get them in. Used lots of pb blaster. We had to use the torch twice on some exhaust flange bolts and a couple smaller bolts snapped (the ones holding the air injection system to the truck.) We drilled and tapped and put new bolts in and continued on. When installing everything i bought all new manifold studs and nuts cause the old ones were rusty. I also got new manifold gaskets as well.
    Listen to the instructions about the steeing wheel! Dont spin your wheel when it is disconnected from the linkage. My friend must have allowed 1 revolution, (i was working on the passenger side) bcause when i backed out of the garage and turned the wheel it snappd my clock spring in the steering wheel. No more airbag or wheel controls. That was a $223 mistake and only that because i installed the new part myself.
    But in the end, totally worth it. I gained more from these headers than i did from the pully swap.
    Biscuits likes this.
  16. Jan 27, 2016 at 5:35 PM
    WOODEX M.E.
    Corey
    Maine
    Also just looked back and saw you had already installed yours. Glad yours is a 2010
  17. Jan 27, 2016 at 5:48 PM
    hillbilly57
    2010 trd off road
    Omg thank god I didn't have a newer truck with air injection.After reading your post I would never had tried to install.
    Sounds like you live up north with salt on the roads.Makes the job so much harder.Glad to hear you like them too.
  18. Jan 27, 2016 at 5:53 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Any issues with them rubbing the coil gusset I think its called
  19. Jan 27, 2016 at 5:56 PM
    WOODEX M.E.
    Corey
    Maine
    No, there is about 3/4" of space left on the passenger side. I dont know what the drivers side was. I did have to move some wires from the passenger side tho cause they were right between the headers and the gusset. Took like 2 ,minutes.
  20. Jan 27, 2016 at 5:57 PM
    WOODEX M.E.
    Corey
    Maine
    The salt makes everything crappy. I was snapping bolts on this thing when it was 2 years old. Even with lube.
