URD SPEC-U LT review
Discussion in 'Performance and Tuning' started by hillbilly57, Jan 24, 2016.
  1. Jan 27, 2016 at 5:57 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I just knew there where rubbing issues with some people and I just didnt want to deal with it
  2. Jan 27, 2016 at 6:02 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Yeah i think youll be all set. Offer some friends some pizza and make a day out of it like i dd.
    Biscuits likes this.
  3. Jan 28, 2016 at 5:57 AM
    hillbilly57
    hillbilly57 [OP] Well-Known Member
    2010 trd off road
    I believe the rubbing issues were on the first few set.My set went in no problem,just waiting on simulator for o2.Not sure on the ones with air injection.Good luck.
  4. Feb 12, 2016 at 2:40 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    The newer models with air injection are a nightmare.
    when I put my AFE shorty's on,one of the air injection bolts torqued off in the block during removal.
    It was a complete PITA putting drill bits in a dremel because there was no space for any conventional type of screw removal.
    My original idea of grinding a slot and using a flat head to remove also failed.
    Don't try and reuse air injection hardware.
    Install could not have been done on the AFe's without quick paw racheting box wrenches.
    I did it by myself and it took close to 10 hrs since I wanted to clean exhaust flange and wrap alternator wires in heat wrap
  5. Feb 12, 2016 at 5:23 PM
    WOODEX M.E.
    Corey
    Maine
    Yeah we broke a couple air injection bolts too. Glad i had the shop and all the help. Its a total bitch.
  6. Feb 12, 2016 at 6:47 PM
    hillbilly57
    2010 trd off road
    Sounds like you did good 10 hrs with
    broken bolt.Think I would've had a Heart attack when the bolt broke.
    Well done!
  7. Mar 7, 2016 at 1:09 PM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    These headers are the most difficult set I've ever had to install. Don't want to these again.
  8. Jun 9, 2017 at 7:08 PM
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Crap, I was planning on installing my headers tomorrow. I'm a bit freaked out now. Drilling and tapping aren't on my list of favorite things to do, especially in tight places.
  9. Jun 9, 2017 at 10:25 PM
    WOODEX M.E.
    Corey
    Maine
    Depends on what part of the country you are in whether or not stuff will likely break. If you are in the snow belt and your truck is over 3 years old youll probably snap a bolt or two. Its not terrible, but we had access to a milling machine and welder and the like, it was a full machine shop and we did need some of it to fix things and make some new parts.
    Others have done it without problems so i dunno. I even had to bust out the torch to get the y pipe bolts off.
  10. Jun 10, 2017 at 9:00 AM
    gersus
    Missouri
    14 Tacoma DCOR
    I'm four hours in working by myself and made two trips to the auto store for a torq socket set, copper manifold stuff, and pb blaster. So far I have the stock manifold out and getting ready to put the headers on. No problems what so ever! All the bolts/nuts came out real easy really.
    I have to take a break and do some other stuff but will get back on it this evening.
  11. Jun 10, 2017 at 9:36 AM
    WOODEX M.E.
    Corey
    Maine
    Remember you live in MO so you are probably gonna be fine anyways.
  12. Jun 10, 2017 at 10:18 AM
    gersus
    Missouri
    14 Tacoma DCOR
    We get a decent amount of salt in the winter typically but the last couple years have been so mild. Nothin like Maine of course. I'll take it!
    WOODEX M.E. likes this.
  13. Jun 11, 2017 at 1:15 PM
    gersus
    Missouri
    14 Tacoma DCOR
    Finished up this morning going back and checking everything. Took about 9 or 10 hours total by myself in my driveway. Installed the headers and the urd cai too. It all went a lot better than I expected. Fitting the headers up in their spot was quite a bit easier than I expected.
    Went for a test drive and instant cel. I forgot to plug the maf sensor in lol!
    Drives good and sounds good so far. Quite a sound difference for sure. I have oem y pipe and muffler.
    I didnt get crazy yet because I'm bd tuned currently. Ucon soon!!!
    SonnyBones, Torspd and jojotoo like this.
  14. Jun 11, 2017 at 4:40 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    you remove the steering shaft? i heard you can install them easier if you remove the front driveshaft and slide them by the steering shaft
  15. Jun 11, 2017 at 4:50 PM
    #35
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I love drilling and tapping in tight places...
    :bananadance:
    Torspd and gersus[QUOTED] like this.
  16. Jun 11, 2017 at 5:19 PM
    #36
    gersus
    Missouri
    14 Tacoma DCOR
    I separated the steering shaft. Didnt have to do anything to the front driveshaft or lift the motor.
  17. Jun 11, 2017 at 7:33 PM
    #37
    Blacktaco2042
    wisconsin
    i was told that instead of taking the steering apart you could remove the driveshaft and slide them in
  18. Jun 11, 2017 at 7:35 PM
    #38
    gersus
    Missouri
    14 Tacoma DCOR
    Idk, taking the steering apart was easy enough
  19. Jun 11, 2017 at 7:37 PM
    #39
    Blacktaco2042
    wisconsin
    yea my truck only has like 42 on it and im a mechanic so i can align it if needed just looking for the easiest way
  20. Jun 11, 2017 at 10:04 PM
    #40
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sharpie and a wrench for the steering shaft.
    gersus likes this.
