Urd supercharger 2012-15
Discussion in 'Performance and Tuning' started by Cody13boland28, Apr 15, 2018.
  1. Apr 15, 2018 at 9:39 PM
    Cody13boland28
    Cody13boland28 [OP] Well-Known Member
    Cody
    Starkville MS
    14 trd sport dc
    Aries bull guard w/kc spot lights, true dual straights w/5" tips, RC 3" lift, and more to come...
    Alright so we all know that urd hasn’t had a supercharger kit for the 2012-15 tacomas and it’s been driving us all crazy. We also know this is due to the air injection system. For the longest time, I swore it was the FUNCTION of the air injection system that prevented the supercharger from working. I sent gadget an email and it turns out it has nothing to do with the function, just the location. Here’s the email, and I quote:
    “The 2012 has the air injection system. Toyota is putting the parts for that system in the places we are mounting a supercharger and intake system. If you want to relocate those components it will work fine.”
    So it sounds just as simple as moving the air injection system somewhere else and voila, you can run a urd supercharger. Here’s the deal... has anyone already relocated their air injection system? If so, where? If not, why? And if it’s this simple, why hasn’t a lot of people done this already? I feel like since I haven’t heard if anyone doing this, it’s more complicated than what I imagine it to be.
  2. Apr 15, 2018 at 10:45 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    https://www.hewitt-tech.com/store/index.php?l=product_detail&p=44
  3. Apr 15, 2018 at 10:47 PM
    inwood customs
    Dave
  4. Apr 16, 2018 at 6:50 AM
    Cody13boland28
    Cody
    Starkville MS
    14 trd sport dc
    I’ve seen this before, but this removes the AI system completely, doesn’t it? And I’ve also heard that people who have used this has had codes thrown because of it. If possible, I’d just like to know if anyone has just relocated the AI system instead of completely removing it. If not, then I’d use the above mentioned product as a last resort
  5. Apr 16, 2018 at 6:53 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Just remove air injection and use a resistor to trick the sensor
  6. Apr 16, 2018 at 9:55 AM
    Cody13boland28
    Cody
    Starkville MS
    14 trd sport dc
    Is there any other systems beside the one made by Hewitt?
  7. Apr 16, 2018 at 10:51 AM
    Cody13boland28
    Cody
    Starkville MS
    14 trd sport dc
    Currently, the Hewitt system will not work on 2013-2015, so I’m out of luck since I have a 14. Also, the system requires that you still have the AI system attached, so this again wouldn’t work. I just want to know if there’s any way of relocating the system or deleting it altogether:(
  8. Apr 16, 2018 at 12:06 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Supposedly the OVTune can disable it, in the OEM ecu. Disable it, and swap to the pre-2012 valve covers. Problem all cleared up.
    05Taco4x4 and Jcyr like this.
  9. Apr 16, 2018 at 4:17 PM
    Cody13boland28
    Cody
    Starkville MS
    14 trd sport dc
    @Torspd is it possible to delete the files with the OVTune, then run the UCON? If possible I plan on running the mk3 stage 3, and seeing it requires the 7th injector, it needs the UCON. Although I’d hate to pay the $500 for the OVTune just for getting rid of the SAIS and nothing else.
  10. Apr 16, 2018 at 4:18 PM
    Cody13boland28
    Cody
    Starkville MS
    14 trd sport dc
  11. Apr 16, 2018 at 5:08 PM
    Jcyr
    Jack
    North east
    OVtune in theory should eliminate the need for uconn
  12. Apr 16, 2018 at 5:22 PM
    Cody13boland28
    Cody
    Starkville MS
    14 trd sport dc
    @Jcyr from what I’ve been reading in the OVTune thread it can’t handle a 7th injector, and the urd mk3 stage 3 requires it
  13. Apr 16, 2018 at 5:37 PM
    Jcyr
    Jack
    North east
    It requires more fuel but there are better options than a 7th injector. You could always get larger injectors and use the ovtune to adjust.
  14. Apr 16, 2018 at 5:46 PM
    Cody13boland28
    Cody
    Starkville MS
    14 trd sport dc
    @Jcyr I still haven’t ran up on where it states the max injector size for the OVTune. And plus, Id think the 7th injector cools temps better since it’s placed beside the throttle body instead of closer to the valves, right?
  15. Apr 16, 2018 at 6:12 PM
    Jcyr
    Jack
    North east
    No because larger injectors would have no bias.. there’s a reason serious boosted applications size up injectors they don’t throw one in the tb and hope it dispersed evenly. Guys at ov tune are super smart id message them and ask if they could help you increase injector size. If you’re worried about cooling down the line you could always add a meth injection to the tb..
  16. May 20, 2018 at 7:21 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'll never need a 7th. Meth injection and ovtune work great for me.
