URD Supercharger Install on a post-09 Tacoma
Discussion in 'Performance and Tuning' started by krisxone, Mar 11, 2015.
  1. Apr 10, 2015 at 11:52 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Once you figure that out PM me and we'll retire. :D
  2. Apr 12, 2015 at 9:02 AM
    shredo
    shredo (Brock)
    Vancouver, WA
    09 XRunner
    TRD SC 1 size smaller pulley, headers, cold air intake, lowered, 20" wheels, billet grill, more...
    Thanks Krisx for the helpful writeup. Any updates on the UCON-ems?
    I've been wanting to install one for several years in my 09 XR so now I know how. Attached is your wiring chart but in a pin/pin format (I've not yet checked for typos). I'll send you the xls if you want it.
    Wiring chart has now been verified (by krisxone) and updated. This is the latest version here below.
  3. Apr 12, 2015 at 9:58 AM
    krisxone
    krisxone [OP] Active Member
    DC
    '10 TRD Sport
    Thanks for cleaning that up! I'll have my truck back this Monday or Tuesday, and I can verify that wiring for you.
    Not sure what you mean about splicing pre-09 connectors. The UCON goes inline between the harness connectors and the ECU. It expects pre-09 connectors on both ends. If you wanted to keep your post 09 ECU, you'd have to splice pre-09 connectors to plug in to the UCON, then another adapter from the UCON to the post-09 ECU, so you're doing twice the work. Which is why i went with the pre-09 ECU route.
  4. Apr 12, 2015 at 12:57 PM
    shredo
    shredo (Brock)
    Vancouver, WA
    09 XRunner
    Yes, this is what I was wondering. It's more difficult work as it would be done in the truck. But less parts. The only parts needed would be pre09 computer with connectors. One could cutoff their post09 plugs (ha, no going back) and solder them to the pre09 computer socket then splice on the pre09 plugs where the wires were cut.
  5. Apr 13, 2015 at 1:16 PM
    krisxone
    DC
    '10 TRD Sport
    Yup, theoretically, that should be possible.You wouldn't even need the computer if you don't mind modding the UCON and can manage to replace the connectors on the UCON directly with the post-09 connectors you cut off from the harness.
  6. Apr 23, 2015 at 10:32 AM
    shredo
    shredo (Brock)
    Vancouver, WA
    09 XRunner
    Wiring chart updated. See post #22
  7. Apr 23, 2015 at 12:07 PM
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    Wait so are you saying I can mod the UCON to run on 2013?
  8. Apr 23, 2015 at 12:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is what this whole thread is about man!
  9. Apr 23, 2015 at 1:02 PM
    TripleThreat
    :eek:
  10. Apr 23, 2015 at 2:38 PM
    krisxone
    DC
    '10 TRD Sport
    Yes, I do think it's possible to mod the UCON to connect to the post-09 ECU. You would still have to either splice in the Pre-09 connectors to your wiring harness in the truck, or mod the input side of the UCON as well. Lots of ways to skin the cat. Going the harness route is probably not the cheapest or easiest, but it's easily reversible.
    Update: I was able to swap the APR-X1 with the UCON EMS with no issues. The truck runs perfect. I updated the original post with the details. Now get to it! I promise you won't regret it.
  11. Apr 23, 2015 at 5:40 PM
    shredo
    shredo (Brock)
    Vancouver, WA
    09 XRunner
    Krisxone, Do you recommend keeping the wires short (speaking of the connector adapter) or is there some advantage to giving it a bit more play?
  12. Apr 23, 2015 at 5:58 PM
    krisxone
    DC
    '10 TRD Sport
    The space where the ECU is installed is a bit tight. Keeping it short keeps the adapter small. However, it also make it tough to solder the connections. And too short makes the harness more inflexible. Each wire by itself is soft, but 100+ wires makes the harness as a whole surprisingly inflexible. If I were to do it again, I'd probably go maybe 2 inches longer, I think it would've helped with the APR install. But it's a moot point with the UCON, the way it mounts gives a lot more room. If you do go longer you can always compress/scrunch up the wires. I think the best thing to do would be to dry fit the UCON and the connectors to see how much room you're working with.
    Also, keep in mind that some pins on one side of the connector can go all the way across to a connector on the other side, thus needing a longer wire. Hope that makes sense.
  13. Apr 24, 2015 at 6:25 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    i want to do something like this so bad. The rewiring of the ucon sounds like the route for me and probably a bunch of others. Its just so hard to think of how to start and keep it cheapish. Also thats a big chunk if money to spend for R&D for personal use. Anything we can all work togeather on as a group. Research, wiring, time, money, you know that stuff? Tor, you seem to have a bottomeless wallet, get to it! Lol.
  14. Apr 25, 2015 at 9:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ha! If I was of the non plug-n-play years, I would have just like krisxone. Thus again, major props to him. :thumbsup:
    I don't sit well with the notion of "someone" saying to me, "it isn't possible." At worst, I'd have made plugs in the harness, and run a stand-alone into that. UCON is much easier to deal with over all, than a stand-alone though. There are options though. Desire being the motivating factor.
  15. Apr 27, 2015 at 12:56 PM
    #35
    justrynarip
    justrynarip Well-Known Member
    Bryan
    Detroit, MI
    09 TRD Sport
    OME lift, AAL, 17" ultra phantom wheels, 32" goodyear wrangler tires, OEM running boards, custom grille, doug thorley long tube headers, URD mark III exhaust with magnaflow muffler, TRD CAI, on demand backup camera switch
    Great write-up! I too plan on running a URD supercharger kit someday in my 09 tacoma. One question, how long did it take you to install the supercharger kit itself? I already have the cam gears and thermostat installed...major PITA to change out the cam gears, but at least I got it out of the way with now. My plan is to just go the cut and splice method with a piggy back ecu (probably MAP ECU 3). I really didn't want to go that route, but there are really not that many connections to make. If difficulty is the only concern (which mine is), the adapter harness sounds like alot more work than just hard wiring into the stock harness. Plus, I've already tampered with the wires when I installed an MAF cal previously. Anyways, great work.
  16. Apr 27, 2015 at 8:53 PM
    #36
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    hey Krisxone, can you give us your opinion the Rotrex? How's everyday driveability & MPG when driven conservatively? Reasons I'm asking is that I'm looking for more power in the mountains and for towing but some say the TRD supercharger was not that big of an improvement. Thanks in advance.
  17. Apr 27, 2015 at 9:16 PM
    #37
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    you need to go mk3. Get that blower reclocked so it is not at a goofy angle.
  18. Apr 28, 2015 at 10:41 AM
    #38
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Good stuff for sure! I had contacted Unichip for a blank harness. They are able to build them for later year models. I believe they made their own molds for the connectors. Price was $275 for a blank/extension harness. The rep told me the model no. for the blank is ppTOY27.1. It's not listed on their website, but you can contact them to order one. That number was for a 2012, so it might be different for the 2010-2011 w/o the air injection.
    I was considering asking them to build me two. One with a 2008 male to 2014 female and one 2008 female to 2014 male. This should allow a plug and play install for the UCON. However, the cost is rather prohibitive for me right now.
  19. Apr 28, 2015 at 12:32 PM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Wonder why I never heard of or thought of calling them to do just that, until now. That just might be the ticket to getting it done even easier....
  20. Apr 28, 2015 at 5:44 PM
    #40
    WOODEX M.E.
    Corey
    Maine
    Assuming one were willing to soend the coin on getting these harnesses made. $550??? . Where could you buy a UCON to use with it? I havent seen them listed for in stock and sale on URDs site for a very very long time.
