URD Supercharger Install on a post-09 Tacoma
Discussion in 'Performance and Tuning' started by krisxone, Mar 11, 2015.
  1. Apr 28, 2015 at 7:52 PM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I don't have the slightest doubt that more are in production. So it is just a matter of time before they'll be back.
  2. Apr 29, 2015 at 7:10 AM
    #42
    justrynarip
    justrynarip Well-Known Member
    Bryan
    Detroit, MI
    09 TRD Sport
    OME lift, AAL, 17" ultra phantom wheels, 32" goodyear wrangler tires, OEM running boards, custom grille, doug thorley long tube headers, URD mark III exhaust with magnaflow muffler, TRD CAI, on demand backup camera switch
    I bet if you gave Gadget a call, he would be able to tell you if they can get you one or not. You should also notice that the MarkIII super charger kit says "in stock" which has the UCON as part of the kit. This tells me that they have the some UCON's in stock. Just pointing that out.
  3. Apr 29, 2015 at 10:23 AM
    #43
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    AEM used to make extension harnesses for the 05-08 tacoma (aem 30-2992). I see some online shops still advertise them, but they have been discontinued. For people interested, there might be some floating around for ~$200, but make sure you call or email before buying. Lots of motorsports stores drop ship and don't update their site until someone points out it's no longer available.
    Another solution is to find a different vehicle that matches the same ECU harness and use that. Since you don't care which wires are what if you are building your own and you're just using the connectors, it won't matter what vehicle ecu you choose. There are a few other shops that make blank harness extensions like boomslang. I just checked and they do make one for the 05-08 tacoma. http://www.boomslang.us/harness-extension.php. Unfortunately, the only place I know of that has harness extensions for 09+ is unichip. Then again, if you could source a junked 09+ ECU, you could build your own. In the end, for me, the time to track down parts isn't worth the extra savings I might get.
    Here's a list that AEM provided for that 30-2992 harness:
    Application(s):
    2002-2005 Lexus GS300 3.0L/2997cc L6 [2JZGE]
    2003-2008 Lexus GX470 4.7L/4663cc (285ci) V8 [2UZFE]
    2002-2003 Lexus IS300 3.0L/2997cc L6 [2JZGE]
    2004-2005 Lexus IS300 3.0L/2997cc L6 [2JZGE]
    2002-2003 Lexus IS300 Sportcross 3.0L/2997cc L6 [2JZGE]
    2004-2005 Lexus IS300 Sportcross 3.0L/2997cc L6 [2JZGE]
    2003-2007 Lexus LX470 4.7L/4663cc (285ci) V8 [2UZFE]
    2002-2007 Lexus SC430 4.3L/4293cc V8 [3UZFE]
    2005-2006 Scion tC 2.4L/2398cc L4 [2AZFE]
    2003-2004 Toyota 4Runner Limited 4.7L/4663cc (285ci) V8 [2UZFE]
    2005 Toyota 4Runner Limited 4.7L/4663cc (285ci) V8 [2UZFE]
    2006-2008 Toyota 4Runner Limited 4.7L/4663cc (285ci) V8 [2UZFE]
    2004 Toyota 4Runner Sport 4.7L/4663cc (285ci) V8 [2UZFE]
    2005 Toyota 4Runner Sport 4.7L/4663cc (285ci) V8 [2UZFE]
    2006-2008 Toyota 4Runner Sport 4.7L/4663cc (285ci) V8 [2UZFE]
    2003-2004 Toyota 4Runner SR5 4.7L/4663cc (285ci) V8 [2UZFE]
    2005 Toyota 4Runner SR5 4.7L/4663cc (285ci) V8 [2UZFE]
    2006-2008 Toyota 4Runner SR5 4.7L/4663cc (285ci) V8 [2UZFE]
    2002-2004 Toyota Camry LE 2.4L/2362cc L4 [2AZFE]
    2003-2006 Toyota Camry LE 3.0L/2995cc V6 [1MZFE]
    2002-2004 Toyota Camry SE 2.4L/2362cc L4 [2AZFE]
    2003 Toyota Camry SE 3.0L/2995cc V6 [1MZFE]
    2004 Toyota Camry SE 3.3L/3300cc V6 [3MZFE]
    2005-2006 Toyota Camry SE 3.3L/3300cc (202ci) V6 [3MZFE]
    2002-2004 Toyota Camry XLE 2.4L/2362cc L4 [2AZFE]
    2003-2006 Toyota Camry XLE 3.0L/2995cc V6 [1MZFE]
    2003-2005 Toyota Celica GTS 1.8L/1795cc L4 [2ZZGE]
    2007-2008 Toyota FJ Cruiser 4.0L/3956cc V6 [1GRFE]
    2008 Toyota FJ Cruiser Trail Teams Special Edition 4.0L/3956cc V6 [1GRFE]
    2007 Toyota FJ Cruiser TRD Special Edition 4.0L/3956cc V6 [1GRFE]
    2003 Toyota Land Cruiser 4.7L/4663cc (285ci) V8 [2UZFE]
    2004-2005 Toyota Land Cruiser 4.7L/4663cc (285ci) V8 [2UZFE]
    2006-2007 Toyota Land Cruiser 4.7L/4663cc (285ci) V8 [2UZFE]
    2003 Toyota Sequoia Limited 4.7L/4663cc (285ci) V8 [2UZFE]
    2004-2005 Toyota Sequoia Limited 4.7L/4663cc (285ci) V8 [2UZFE]
    2006-2007 Toyota Sequoia Limited 4.7L/4663cc (285ci) V8 [2UZFE]
    2003 Toyota Sequoia SR5 4.7L/4663cc (285ci) V8 [2UZFE]
    2004-2005 Toyota Sequoia SR5 4.7L/4663cc (285ci) V8 [2UZFE]
    2006-2007 Toyota Sequoia SR5 4.7L/4663cc (285ci) V8 [2UZFE]
    2002-2005 Toyota Solara SE 2.4L/2362cc L4 [2AZFE]
    2004 Toyota Solara SE 3.3L/3300cc V6 [3MZFE]
    2005-2008 Toyota Solara SE 3.3L/3300cc (202ci) V6 [3MZFE]
    2006 Toyota Solara SE Sport 3.3L/3300cc (202ci) V6 [3MZFE]
    2004 Toyota Solara SLE 3.3L/3300cc V6 [3MZFE]
    2004-2005 Toyota Solara SLE 2.4L/2362cc L4 [2AZFE]
    2005-2008 Toyota Solara SLE 3.3L/3300cc (202ci) V6 [3MZFE]
    2007-2008 Toyota Solara Sport 3.3L/3300cc (202ci) V6 [3MZFE]
    2005-2008 Toyota Tacoma 2.7L/2694cc L4 [2TRFE]
    2005-2008 Toyota Tacoma 4.0L/3956cc V6 [1GRFE]
    2005-2008 Toyota Tacoma Pre Runner 2.7L/2694cc L4 [2TRFE]
    2005-2008 Toyota Tacoma Pre Runner 4.0L/3956cc V6 [1GRFE]
    2005-2008 Toyota Tacoma X-Runner 4.0L/3956cc V6 [1GRFE]
    2005 Toyota Tundra 4.7L/4663cc (285ci) V8 [2UZFE]
    2005-2006 Toyota Tundra 4.0L/3956cc V6 [1GRFE]
    2006 Toyota Tundra 4.7L/4663cc (285ci) V8 [2UZFE]
    2003-2005 Toyota Tundra Limited 4.7L/4663cc (285ci) V8 [2UZFE]
    2006 Toyota Tundra Limited 4.7L/4663cc (285ci) V8 [2UZFE]
    2003-2005 Toyota Tundra SR5 4.7L/4663cc (285ci) V8 [2UZFE]
    2005-2006 Toyota Tundra SR5 4.0L/3956cc V6 [1GRFE]
    2006 Toyota Tundra SR5 4.7L/4663cc (285ci) V8 [2UZFE]
  4. Apr 29, 2015 at 11:54 AM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    URD also has those harnesses. :thumbsup:
  5. May 5, 2015 at 9:12 AM
    #45
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
    I'm not too keen on splicing my ECU, I'd like to see URD have a plug and play kit. So us 09+ ECUs can go boosted. Hell I would pay Krisxone to make me a plug and play harness for my 2011
    WOODEX M.E. likes this.
  6. May 27, 2015 at 9:43 AM
    #46
    ninjaexplosion
    ninjaexplosion Well-Known Member
    steven
    AZ, CA, CO
    2004 Tacoma Double cab
    stock height on 35s, 488s
  7. May 30, 2015 at 8:15 AM
    #47
    Dr. Cornwallis
    Dr. Cornwallis Well-Known Member
    Flarrrrrrrida
    2016 Super White TRD Offroad 4x4 AC
    So does this open up the possibility of being able to completely tune 09-15 trucks? I'm not boosted and don't plan to be but it would be sweet to be able to tune out that awful rev hang that plagues the manual and just get rid of the shitty stock tune in general. I think these trucks run really lean from the factory, which may be why they ping so much.
  8. May 30, 2015 at 5:32 PM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What year is your truck? The history of these is that they run extremely rich. I'm thinking that yours has the air injection system?
  9. May 31, 2015 at 2:46 PM
    #49
    Ninj
    Ninja
    New Hampshire
    Torspd is right I'm pretty sure from the factory Tacomas run rich....If you have a 2012 and later they have that air injection intake system...and the pinging tends to be from use of low octane I run 93 all day long and have never heard a ping but people that run 87 tend to hear the pinging
    Torspd[QUOTED] likes this.
  10. Jun 1, 2015 at 10:37 AM
    #50
    Dr. Cornwallis
    Flarrrrrrrida
    I have a 2012, it's got new plugs, the tsb and I run 93 octane and it still pings.
  11. Jun 1, 2015 at 12:04 PM
    #51
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Interestingly, I just read about another guy with a similar problem. His ended up being a faulty OEM fuel pump. Swappee it out with a Walbro 255, and his problem went away. His started as pinging, then progressed to not being able to work. Then he crossed the fuel lines. Fixed it and truck runs great.
    That might be your problem.
  12. Jun 1, 2015 at 5:15 PM
    #52
    Dr. Cornwallis
    Flarrrrrrrida
    Is there any change it would be covered under my 6/60,000 warranty?
  13. Jun 2, 2015 at 8:11 AM
    #53
    Ninj
    Ninja
    New Hampshire
    I'd check with your local dealer pinging isn't normal/shouldn't be happening
  14. Jun 4, 2015 at 11:28 PM
    #54
    YouJamaicanTRUCK
    YouJamaicanTRUCK Active Member
    Jay
    Jamaica
    '09 4x4 4.L V6
    6" Fabtech Lift Kit, K&N Intake, 20" LED Light Bar (behind grille), Borla Catback Exhaust System, JL Audio Custom Sound System (10" woofers x2), Gen 3 Grille,Bumper, Front Fenders & Hood
  15. Jun 5, 2015 at 7:33 PM
    #55
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :popcorn: hmmmm
  16. Jun 29, 2015 at 2:13 PM
    #56
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    McCallywood and Ninj like this.
  17. Jun 29, 2015 at 2:17 PM
    #57
    ninjaexplosion
    steven
    AZ, CA, CO
    AMEN
    Ninj likes this.
  18. Jun 29, 2015 at 2:35 PM
    #58
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I just want UCON lol, don't even care about the URD SC since I've got a TRD sitting in my garage.
  19. Jun 29, 2015 at 2:38 PM
    #59
    ninjaexplosion
    steven
    AZ, CA, CO
    He is only going to offer it to URD charged guys
  20. Jun 29, 2015 at 2:41 PM
    #60
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Why? There are way more TRD S/C out there than URD and he can cash in on that.
    Did Gadget actually say that?
