URD Supercharger Install on a post-09 Tacoma
Discussion in 'Performance and Tuning' started by krisxone, Mar 11, 2015.
  1. Jun 29, 2015 at 2:43 PM
    #61
    ninjaexplosion
    ninjaexplosion Well-Known Member
    steven
    AZ, CA, CO
    2004 Tacoma Double cab
    stock height on 35s, 488s
    NO lol and it didnt take long for a WHATTTTT
  2. Jun 29, 2015 at 2:43 PM
    #62
    ninjaexplosion
    steven
    AZ, CA, CO
    Im waiting as well
  3. Jun 30, 2015 at 8:56 AM
    #63
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    Interesting!
  4. Jul 1, 2015 at 9:36 AM
    #64
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
    Hell Yeah, Gadget needs to get this worked out ASAP
  5. Jul 1, 2015 at 9:57 AM
    #65
    Konvict KROG
    Louisiana
    I have no experience with them.
    However I have been considering it for the long term on my 2015.
    I would like to do similar to super werty with the trd blower someday.. only I am a 6spd and I would be running dirt drags if I do that. No interest in street drags.
  6. Jul 2, 2015 at 10:46 AM
    #66
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  7. Jul 29, 2015 at 12:39 PM
    #67
    justrynarip
    justrynarip Well-Known Member
    Bryan
    Detroit, MI
    09 TRD Sport
    OME lift, AAL, 17" ultra phantom wheels, 32" goodyear wrangler tires, OEM running boards, custom grille, doug thorley long tube headers, URD mark III exhaust with magnaflow muffler, TRD CAI, on demand backup camera switch
    I think I'm going to give this harness a go. Does anybody know the part number of the cabin wire harness that contains the two lower ECU plugs for 05-08 trucks? I have the engine wire harness which contains the upper 3 plugs, but still need the lower two and want to be sure of which harness I need to buy to get the plugs.
  8. Jul 29, 2015 at 3:36 PM
    #68
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Check to see if Camelback has it, or give them a call. They have been my go to for parts and have great customer service.
    http://parts.camelbacktoyota.com/pa...r/?siteid=214329&vehicleid=203760&searchText=
  9. Jul 29, 2015 at 4:03 PM
    #69
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    Didn't see anything resembling wire harnesses on the site but what I'm really looking for is the part number, so I can make sure I get the right one.
  10. Jul 30, 2015 at 5:13 AM
    #70
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  11. Jul 30, 2015 at 7:20 AM
    #71
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    Cool. Well, I managed to source the plugs, so unless they arrive as the wrong ones, I think I've got er figured out. Turns out the guy I bought the engine wire harness from also had the dash harness, and he was willing to snip the plugs for me.
  12. Jul 30, 2015 at 7:44 AM
    #72
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    As far as sourcing an 09+ ECU, what years will work in my 09? Sounds like 2012 has a few differences, but is the female connector still the same as 09?
  13. Aug 7, 2015 at 10:30 PM
    #73
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    12 hours of work is what it took me to go from this
    to this
    What a task! Now just gotta plug er in and see if it works:fingerscrossed::fingerscrossed:
    Ended up going a bit longer than OP did in his, pry 8inches of wire off each plug. In any case, wouldn't have ever happened without the wire diagrams posted. I found it very easy to follow. Now hopefully everything was correct.
    Ninj likes this.
  14. Aug 7, 2015 at 11:59 PM
    #74
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    If it works, mass produce about 100 of those at like 1k a pop and we'd all buy one lol
  15. Aug 8, 2015 at 5:03 AM
    #75
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Can anyone recall what the difference is on the 2012+ For something like this to work?
  16. Aug 8, 2015 at 8:32 AM
    #76
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    If the connectors were easier to get then that might be an option. I got lucky sourcing my stuff. I got the pre09 ecu and all 5 connectors for $215, and a 2011 ecu for $100. So, roughly $300 into this build. Not really any other expenses involved if you already have a decent soldering iron.
    Ninj likes this.
  17. Aug 8, 2015 at 9:10 AM
    #77
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Man......good job sir! That is motivation right there.
    Have you had the chance to plug it in yet and test it?
  18. Aug 8, 2015 at 10:47 AM
    #78
    VolcomTacoma
    Jeff
    NorCal
    Yea thats pretty damn cool. I'm very tempted to try it myself, but I really hate fucking with electronics. Give me suspension or a pump or something i can get a wrench on any day...I'll gladly pay top dollar to someone that knows what theyre doing with electronics so I don't have to
  19. Aug 8, 2015 at 10:53 AM
    #79
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this.. seriously.. :drool:
  20. Aug 8, 2015 at 11:14 AM
    #80
    VolcomTacoma
    Jeff
    NorCal
    Yea i mean, if someone is willing to take the time to make a bunch of these, there is a HUGE profit margin here. Guarantee the 1st ten will sell out within a day
