URD Supercharger Install on a post-09 Tacoma
Discussion in 'Performance and Tuning' started by krisxone, Mar 11, 2015.
  1. Aug 8, 2015 at 4:06 PM
    #81
    justrynarip
    justrynarip Well-Known Member
    Bryan
    Detroit, MI
    09 TRD Sport
    OME lift, AAL, 17" ultra phantom wheels, 32" goodyear wrangler tires, OEM running boards, custom grille, doug thorley long tube headers, URD mark III exhaust with magnaflow muffler, TRD CAI, on demand backup camera switch
    Havent got a chance to plug it in yet. Decided that i'm going to go back and verify every pin with a dmm to make sure the connections are solid and there arent any shorts.
    But i decide to make this so that i could put a URD s/c kit on, but now im seriously considering custom turbo, which means i might not need it any more if i just stick to my map-ecu3. ...Bidding starts at $750;)
    Torspd likes this.
  2. Aug 8, 2015 at 4:13 PM
    #82
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    Thank you. Pretty proud that i was able to finish. About 3/4 the way thru, i started to doubt that i was looking at the diagram correctly. Fortunately i convinced myself that i was fine and finished it off. But, the proof is in the pudding so we'll see once i hook it up. Its feels quite accomplishing to get it done.
    Torspd[QUOTED] likes this.
  3. Aug 8, 2015 at 7:39 PM
    #83
    krisxone
    krisxone [OP] Active Member
    DC
    '10 TRD Sport
    Congrats justrynarip! If it helps, I just used the diagram from shredo post #22 to make a second wiring harness for another forum member and can confirm that what we documented works. If you wired it up to what was documented, it should work just fine! Definitely keep us posted.
  4. Aug 8, 2015 at 7:44 PM
    #84
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    oh yeah? ;)
  5. Aug 8, 2015 at 7:51 PM
    #85
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    WTB
  6. Aug 8, 2015 at 7:56 PM
    #86
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    x2
  7. Aug 8, 2015 at 10:48 PM
    #87
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    That document was definitely an amazing time saver. You sure put alot of time and effort into yours when you made your first one if you didnt have that handy little cheat sheet. I have a new great appreciation for what you've done:bowdown:
    Im not too worried about the wires being to the wrong pins, i'm more worried about joints breaking as i wrestled with the shrink wrap.
    As far as the ecu pairing procedure, will i need a writeable scan tool to do that?
  8. Aug 9, 2015 at 6:34 AM
    #88
    krisxone
    DC
    '10 TRD Sport
    Nope, you just need a jumper wire. I think even a paper clip will work in a pinch. Just stick it directly into the OBD port. Pins 4 and 13 I believe.
    Ninj likes this.
  9. Aug 10, 2015 at 11:34 AM
    #89
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    So I read the forum about the ECU pairing procedure, and it refers to an SST to jump pins 4 and 13. I have no idea what an SST is, but you're saying that all I need is a wire to connect the two pins, and then leave the key on for 30 mins?
    I might be able to get around to doing this tonight or some other time this week. Will let you know how it goes.
  10. Aug 10, 2015 at 1:28 PM
    #90
    krisxone
    DC
    '10 TRD Sport
    Yes, that's all you need to do. I'm not 100% sure but I think SST is just a generic term for special Toyota tools, I believe it stands for special service tool. In this case it's just an obd connector with pins 4 and 13 shorted. A paperclip that has a wire diameter similar to an OBD connector's pin diameter bent into a U shape is all you need.
  11. Aug 20, 2015 at 7:06 AM
    #91
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    Well, now I've been a few rounds with this harness...installing, taking out and trouble shooting, installing, trouble shooting. I've got everything in order now, meaning the harness with an 07 ecu runs and drives my truck with no CEL's. By saying it drives my truck, I mean up until 2nd gear anyways. Mine is an auto trans, and for some reason, 1st and 2nd behave just fine, but it wont shift into 3. Its as if I have the selector in 2 rather than D. Any thoughts? I double checked the wires that pertain to this, and everything is OK, so I guess my next plan of attack is to see what happens if I actually do put the selector in 2 and maybe it'll drive normally(I swapped back in my 09 ECU before I thought to try it :smack:). If that's the case, then those pins in the diagram are wrong for my truck for some reason.
    ninjaexplosion likes this.
  12. Aug 20, 2015 at 8:57 AM
    #92
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    I dont know if you have this info and if it can help.
    Ninj and justrynarip like this.
  13. Aug 20, 2015 at 9:06 AM
    #93
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    Wow, those are two amazing documents! Those should definitely help. Thanks man!
  14. Aug 20, 2015 at 10:46 AM
    #94
    Vassily28
    Be aware those documents are for 2005 trough 2008. If you need a reference document or a page listed (like AT155) in one of those documents, let me know. I probably can help
  15. Aug 20, 2015 at 10:49 AM
    #95
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    Good to know. They should still be helpful in trouble shooting. I'll let you know if I need anything.
  16. Aug 20, 2015 at 11:07 AM
    #96
    krisxone
    DC
    '10 TRD Sport
    If you can't get it sorted, I can offer to swap it into my truck to see if it exhibits the same behavior. If it does, then you know it's something with the harness. If the harness works fine on my rig, then it could be the 07 ECU or something different on your truck.
  17. Aug 20, 2015 at 11:10 AM
    #97
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    Ok, good to know if I end up not being able to get it dialed in. I also noticed that my rearview backup camera doesn't turn on when I go into reverse. Does your truck have a camera?
  18. Aug 20, 2015 at 11:12 AM
    #98
    krisxone
    DC
    '10 TRD Sport
    Yes mine has the camera in the rearview. Works perfect.
  19. Aug 20, 2015 at 11:16 AM
    #99
    Vassily28
    I think i got what you need. See attached.
    Do you have a check engine code?
    Ninj likes this.
  20. Aug 20, 2015 at 11:22 AM
    #100
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    Hmmm...The thing is that I went through pin by pin and checked for continuity as well as surrounding pins for shorts. Everything checks out.
    Thanks. No CEL'S...
