URD Supercharger Install on a post-09 Tacoma
Discussion in 'Performance and Tuning' started by krisxone, Mar 11, 2015.
  1. Sep 12, 2015 at 12:33 PM
    #101
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
    After weeks of avoiding doing the inevitable I took out my Pre-09 ECU (From a salvage yard) and my Adapter that Kris made me and I finally plugged it all in. I was worried to death that doing the ECM wrecking yard OBD-II trick was going to fry my wiring harness, but after 30 nail biting minutes later the truck started up like I had the OEM (6Plug ECU/Post09 ECU) installed. I drove the truck around, mind you I’m a 6 speed manual Kris has the automatic, and everything worked the way it is suppose to. No check engine lights, no trouble codes, lights, back-up camera, hazards, 4high, 4low, everything works. During the ECM wrecking yard 30 minute trick, some lights on the dash will turn on and off for the entire 30 minutes that’s normal. I also heard a high pitched whine from the engine bay; I’ve never heard that before. Just let it go and the truck will start up in 30 minutes time no problem. A++ Kris is the man, now I just need to buy the URD Supercharger haha
    Just as a side note, since I don’t have the Supercharger yet, I wanted to go back to my hardwired Post09 OEM ECU. You will have to do the whole ECM wrecking yard 30 minute trick again, but after that it was like I never even use the Pre09 ECU.
    https://www.tacomaworld.com/threads/ecm-swap-with-wrecking-yard-ecm.315635/
  2. Sep 12, 2015 at 12:38 PM
    #102
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Still WTB a harness so I can plug a UCON in lol
  3. Sep 12, 2015 at 12:48 PM
    #103
    Ninj
    Ninja
    New Hampshire
    Like Kris said the hardest part for me was hunting down those 5 damn plugs. Getting the Post09 and Pre09 ECUs isn’t hard. Those damn plugs are worth their weight in gold, apparently. Now that I’m confident in doing the ECU/ECM 30 minute trick, I want the URD Supercharger that much more haha. Now that the TRD Supercharger are not available, I’m glad I went with Kris on the URD/Adapter route.
  4. Sep 12, 2015 at 12:58 PM
    #104
    VolcomTacoma
    Jeff
    NorCal
    Damn. Well, I just want UCON for tuning purposes, with all of my mods I'm pretty sure I can eek out a good chunk of HP from the 1GR
  5. Sep 12, 2015 at 12:59 PM
    #105
    VolcomTacoma
    Jeff
    NorCal
    Someday I might upgrade to the URD, but I'd have to have the UCON at that point because of this damn rich ass Toyota ECU reflash
  6. Sep 12, 2015 at 1:01 PM
    #106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well done Ninj. Bravo sir. :bowdown:
    Ninj likes this.
  7. Sep 12, 2015 at 1:05 PM
    #107
    Ninj
    Ninja
    New Hampshire
    I appreciate the support, but it was all Kris I gave him all the parts he needed and he worked his black magic voodoo.
  8. Sep 12, 2015 at 1:07 PM
    #108
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'm commending you for following through. Kris has already been given the :cheers: for this great write-up for the community.
    Ninj likes this.
  9. Sep 12, 2015 at 1:30 PM
    #109
    Ninj
    Ninja
    New Hampshire
    Thank you I appreciate it Torspd
  10. Sep 16, 2015 at 1:56 PM
    #110
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    So wait....Is this a 2nd confirmation of a successful 09+ conversion capable of using the UCON?
    Ninj likes this.
  11. Sep 16, 2015 at 1:58 PM
    #111
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    I'd love to see someone try this on a 2012 or newer... I know the TRD fit kit was different for those trucks and I'm wondering if the URD supercharger likewise is 2005 - 2011 compatible but the redesigned front end might be a problem?
  12. Sep 16, 2015 at 2:32 PM
    #112
    VolcomTacoma
    Jeff
    NorCal
    If someone makes me a harness, Id be willing to buy a UCON and give it a shot and if it works...TRD Supercharger for Sale :)
  13. Sep 16, 2015 at 3:07 PM
    #113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    PM Kris
  14. Sep 17, 2015 at 11:51 AM
    #114
    Ninj
    Ninja
    New Hampshire
    Number 2....who's going to be the 3rd? I know Justrynarip was working on an adapter with extra long wires.
  15. Sep 17, 2015 at 12:45 PM
    #115
    VolcomTacoma
    Jeff
    NorCal
    Or Im waiting until i can afford a URD SC and then ill look into it? Id say I'm right around 300 RWHP or will be damn close with headers. I'm gonna go ahead and get my long travel all installed next before i try to dive back into major ecu mods, but its on my list. I'd love to be jamming around with 400+ hp in a long travelled truck
  16. Sep 17, 2015 at 12:47 PM
    #116
    VolcomTacoma
    Jeff
    NorCal
    Pretty sure the Mark 3 is pushing 400...
  17. Sep 17, 2015 at 12:50 PM
    #117
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    why are you wanting to switch from the TRD to URD?
  18. Sep 17, 2015 at 12:52 PM
    #118
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is, and more. More efficient and more CFM per psi than the TRD.
    Ninj likes this.
  19. Sep 17, 2015 at 12:57 PM
    #119
    VolcomTacoma
    Jeff
    NorCal
    MOAR POWAH
  20. Sep 17, 2015 at 12:57 PM
    #120
    VolcomTacoma
    Jeff
    NorCal
    This.
