URD TCAI + re-tune
Discussion in 'Performance and Tuning' started by tacoskim, Dec 15, 2008.
  1. Dec 15, 2008 at 11:27 AM
    tacoskim
    tacoskim [OP] Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    hey guys installed the URD tcai this weekend. this thing is bad ass, the hole was kinda of bitch to cut out but i managed. Gadget over at URD re-tuned my truck and is now "dialed in" as he would say. the truck runs alot smoother now. I also wanna say Thanks to URD and Gadget for answering any questions and for their help, its a pleasure watching Gadget work. :thumbsup:
  2. Dec 15, 2008 at 11:47 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I just noticed on mine that the filter has a few holes worn in it because the back of the grill came into contact with the filter. Check to make sure you have some clearance on that.
  3. Dec 15, 2008 at 11:51 AM
    tacoskim
    Los Angeles, CA
    Stock
    thanks for the heads up.. ill check that later, its also starting to rain here so im gonna put the filter cover on later... hopefully when i change the grille to the grillcraft in a few weeks the clearance will be better
  4. Dec 15, 2008 at 11:56 AM
    lsocoee
    Hotdog
    Wet Okole Underwear
    The K&N filter hurt my gas mileage by about 2mpg. I drive in the rain often and I don't notice any difference without the filter except for the gas mileage. The grillcraft will definitely help because you won't have the sharp ridges digging into it. But I'd still check it out.
  5. Dec 15, 2008 at 12:11 PM
    tacoskim
    Los Angeles, CA
    Stock
    damn so the cover robbed 2 mpg from u? then i might just keep that off and only put it on when i go offroading.
  6. Dec 15, 2008 at 4:17 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    How was the install as far as extending the MAF sensor wire and all???
  7. Dec 15, 2008 at 4:27 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    extending the maf wires are easy. just cut one at a time, and slide a heat shrinktube on each end, which is included, and then just solder in the wire extention that also comes with it. then slide up the heatshrink and heat her up.
  8. Dec 15, 2008 at 4:29 PM
    roxspin72
    NC
    Oh Yeah!!!
    Ok, and soldering is the only way to gaurantee connection, right?
  9. Dec 15, 2008 at 4:34 PM
    jaxchrisfla
    flooriduh
    lots
    you can use butt connectors, but i highly highly recommend soldering the connections. one, it will help keep things looking clean, and two, unless you have something rip it out, the chances of the connections breaking compared to butt connectors comming off is ridiculous.
  10. Dec 15, 2008 at 4:35 PM
    roxspin72
    NC
    Oh Yeah!!!
    Cool thanks for the info. Better start searching for a decent soldering gun...
    Laters.
  11. Dec 15, 2008 at 4:43 PM
    jaxchrisfla
    flooriduh
    lots
  12. Dec 15, 2008 at 6:57 PM
    roxspin72
    NC
    Oh Yeah!!!
  13. Dec 15, 2008 at 7:25 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I experienced the exact same thing. My K&N cover sits in my glovebox now.
    Crap. I guess I better check this before I drive 2,800 miles, huh? D'oht!
