urd vs aero turbine cat back
Discussion in 'Performance and Tuning' started by Myz250f, Aug 28, 2016.
what cat back system do you prefer
  1. underdog racing development
    3 vote(s)
    60.0%
  2. aero turbine
    2 vote(s)
    40.0%
  1. Aug 28, 2016 at 1:38 PM
    Myz250f
    Myz250f [OP] Well-Known Member
    daniel
    New York
    exhaust, headlight bulbs, k&n intake, programer, toytec boss front coil overs, toytec boss rear shocks, sway bar relocation, Dakar leaf pak, oc taco extended stainless steel break lines (red), kicker component front speakers, kicker 2 way rear speakers, pioneer head unit, mtx thunder amp, reverse light bulbs
    i have a 2007 trd dcsb v6 4x4 with a k&n cai and my cat back needs to be replaced due to rust.
    i am currently going to run the stock y pipe but will be adding the urd y pipe in the future.
    my question is should i go with the urd mark 3 cat back or the aero turbine cat back.
    aero technologys
    model specific cat back
    2.5" mandrel bent precision manufactured T-304 stainless steel
    lapband clamps
    $399
    free shipping
    urd
    lots of tacoma r &d
    3.0'' t-304 stainless steel heavy duty gauge steel
    u bolt clamps
    $498$24 shipping
  2. Aug 29, 2016 at 7:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Link to the Aero Technology catback?
  3. Aug 29, 2016 at 7:41 AM
    Myz250f
    daniel
    New York
  4. Aug 29, 2016 at 7:53 AM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    What are your long term plans? If you're gonna boost, then 3" and URD y-pipe should be okay. If you plan to stay NA, then you might wanna find dyno sheet from a NA engine to see what the torque curve looks like. Unless you like just being loud while going nowhere fast.
    Having installed the URD y-pipe, I noticed a loss in low end but revs faster. Also in AZ, when temps get past triple digits, the URD y-pipe really heats up the trans temps in traffic. This is with 5.5lbs of boost at 2600ft elevation and 80F.
  5. Aug 29, 2016 at 8:10 AM
    Myz250f
    daniel
    New York
    i plan on staying na and i want to add the urd y pipe after this winter as i am driving from ny to denver and wouldn't mind having the cats keep my drive a little quieter.
    also any discount codes or laborday sales may sway my option too
  6. Aug 29, 2016 at 8:18 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    The aero kit looks like stock design with an aero muffler. Might be different steel but its basically the same as stock with a muffler swap and different tip. You can pick up an aero muffler for ~$100 if you go that route, I personally wouldn't spend the $400 on that when it can be done for ~$100
  7. Aug 29, 2016 at 8:40 AM
    Myz250f
    daniel
    New York
    i agree with you @mightytacoman but i do need to replace the cat back completely as mine is rusted out with broken hangers. and it is quite convenient to be able to order a cat back kit that mounts right up no labor needed. also the 304 stainless mandrel bent piping is better than anything i can get made around where i live in elmira ny
  8. Aug 29, 2016 at 8:47 AM
    mightytacoman
    Kel
    4.5L 1grfe
    A fellow N.Y. Guy. Gotta love our winters and how hard they are on vehicles. I'm from South of Utica
  9. Aug 29, 2016 at 9:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am partial to the XL Aero Exhaust line. They are resonated and the all stainless internal construction won't break down and wear out like packing style muffers.
    That Aero system sounds good due to the two muffling components. I like it.
  10. Aug 30, 2016 at 4:43 AM
    Myz250f
    daniel
    New York
    Does anyone know of a discount code for aero turbine
  11. Sep 2, 2016 at 6:19 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Run whichever one you like the sound of better
  12. Sep 8, 2016 at 7:10 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Why not go with the full URD spec U exhaust if you are planning on replacing the y pipe anyways? it sounds amazing.
  13. Sep 16, 2016 at 3:44 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I would NOT run the URD 3" with a ypipe, and especially if u want to run long tubes later.
    The truck will drive like a civic.
  14. Sep 17, 2016 at 7:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The Spec-U is currently under revision, due to buzzing humming sounds.
    inwood customs likes this.
  15. Sep 17, 2016 at 11:31 AM
    inwood customs
    Dave
    I didnt see that on the urd site a couple days ago.
  16. Sep 17, 2016 at 12:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It was mentioned on XRU a few weeks ago. And they stop selling the spec you exhausted because of that, until they come up with a solution.
  17. Sep 17, 2016 at 12:13 PM
    inwood customs
    Dave
    Thats good to hear they are taking care of it.
