Urd y pipe andd???
Discussion in 'Performance and Tuning' started by Myz250f, Aug 4, 2016.
  1. Aug 4, 2016 at 12:01 PM
    Myz250f
    Myz250f [OP] Well-Known Member
    daniel
    New York
    exhaust, headlight bulbs, k&n intake, programer, toytec boss front coil overs, toytec boss rear shocks, sway bar relocation, Dakar leaf pak, oc taco extended stainless steel break lines (red), kicker component front speakers, kicker 2 way rear speakers, pioneer head unit, mtx thunder amp, reverse light bulbs
    I have a 2007 double cab short bed V6 6 Speed. And I am looking to replace the exhaust as the current exhaust is rusted out. my original plan was to go with the urd y-pipe and Mark 3 exhaust system all together I am looking at around $1,000 shipped. I am looking to decrease that cost by only purchasing the y pipe and creating my own exhaust back from the y pipe. Does anyone have experience with building this setup with the exhaust dumping before the rear axle. My concern is that I may get too much noise in the cab of the truck. And I do not to want to create a large amount of drone while on the highway
  2. Aug 4, 2016 at 12:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    URD 4x4 y-pipe. Add a good muffler in to keep rasp and resonance down. Something between 18" to 24" in length. The longer the better. Straight through 2.5", unless planning to go F/I. Then 3".
  3. Aug 8, 2016 at 5:53 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If all you want is Y back and are going to bob it at the axle, just find a stock catback from someone who has upgraded, or from a junkyard, and replace the muffler.
