URD Y-pipe sound
Discussion in 'Performance and Tuning' started by o313, Apr 11, 2021.
  1. Apr 11, 2021 at 2:48 PM
    o313
    o313 [OP] Well-Known Member
    N
    2018 DCLB AT SC
    Installed the URD Y-pipe for the extra bung for a wideband O2 sensor and after install I can only describe the noise as an Audi 4000 5cyl gurgle. Thinking about adding a resonator to see if it cures me of the Audi 5cyl gurgle, anyone else experience the same?
  2. Apr 13, 2021 at 11:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Apr 18, 2021 at 5:48 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Couldn’t stand the sound. Went back to stock almost immediately.
  4. Apr 20, 2021 at 9:04 AM
    o313
    N
    2018 DCLB AT SC
    I'm learning to accept the sound and aside from the gurgle I don't mind the noise.
  5. Apr 21, 2021 at 1:17 PM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Adding a resonator ain't gonna cut it. You need a good chambered muffler to cut back on that sound. I went though 3 mufflers + resonators before finding a combo I liked.
  6. Apr 21, 2021 at 5:26 PM
    o313
    N
    2018 DCLB AT SC
    Care to share the configuration you ended up with?
  7. Apr 21, 2021 at 5:46 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Header > Y pipe > large vibrant resonator > flowmaster 50 series > small vibrant resonator >
    I also tried magnaflow straight though and chambered. The chambered sounded better but it was drone city. The flowmaster is much more robust and much quieter.
    Junkhead and o313[QUOTED][OP] like this.
  8. Apr 26, 2021 at 4:15 PM
    thumpper
    thumpper Well-Known Member
    Bob
    Nebraska
    2008 Taco
    Where did you purchase the urd y pipe from? Link,, is there a vedor on here that might have them? (Off road one)
  9. Apr 26, 2021 at 5:18 PM
    o313
    N
    2018 DCLB AT SC
  10. Apr 26, 2021 at 8:31 PM
    thumpper
    Bob
    Nebraska
    2008 Taco
  11. May 17, 2021 at 2:16 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Did you have the straight through and chambered installed together inline of one another?
  12. May 17, 2021 at 2:51 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    No I meant I tried those mufflers also, same setup otherwise just swapping out the muffler.
  13. Nov 23, 2021 at 5:52 PM
    Coldfuzion
    Coldfuzion Active Member
    Andrew
    2018 Beige Tacoma TRD Sport 4x4
    Prinsu Rack, more to come
    Sorry for the bump but got my pipe installed the other day on my 2018 and omg the tin sound is driving me nuts. Did you even find a good replacement muffler to kill the tin civic sound?
  14. Nov 23, 2021 at 6:03 PM
    o313
    N
    2018 DCLB AT SC
    I have not even attempted with all my other projects but if you find one please let me know.
  15. Nov 23, 2021 at 6:04 PM
    Coldfuzion
    Andrew
    Will do.
  16. Nov 23, 2021 at 6:09 PM
    o313
    N
    2018 DCLB AT SC
    Eventually it kind of grows on you if you have the SuperCharger but it isn't pretty with the window down.
  17. Nov 24, 2021 at 10:27 AM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Like I said before a good chambered muffler is the ticket. Mine is still quite loud with the 50 series but the rasp is mostly gone. I still might swap it out for a 70 series later on to cut the dB's a little more.
    https://www.holley.com/products/exhaust/mufflers/street_chambered_mufflers/70_series/parts/52571
  18. Nov 24, 2021 at 4:24 PM
    Coldfuzion
    Andrew
    Thanks I have an appointment with my local shop to put a large resonator and series 50 single out on next week. Hope it works lol.
    PhoS likes this.
  19. Nov 24, 2021 at 6:31 PM
    o313
    N
    2018 DCLB AT SC
    I'm waiting patiently to hear what you think once its done.
  20. Nov 24, 2021 at 6:38 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    You still on stock manifolds?
