urg 2010 tacoma timing cover leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlazeTaco, Jun 24, 2012.
  1. Jun 24, 2012 at 4:22 PM
    BlazeTaco
    BlazeTaco [OP] Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    Well yesterday I changed the oil and looked underneath my truck to prove if my earlier suspicions were correct, sure enough they were. I have wet oil spots on the oil pan right under the timing cover and I seen a wet spot behind the power steering pump where the block and timing cover meet. 2010 tacoma guys beware and look yourselves 25,800 miles on the clock, 4.0l engine.
  2. Jun 24, 2012 at 4:28 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That's not good. Honestly I'd get under there and snug up the pan myself.
  3. Oct 11, 2012 at 7:59 PM
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    Thank you for posting this, I'm going to check mine ASAP. I just passed 25k miles.
  4. Oct 31, 2012 at 12:50 PM
    Oscarbob
    Oscarbob Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    Just checked, back of my oil pan is wet. Dropped the stock skids and I found another wet oil spot just under the AC compressor right above the steering rack. Not sure if the oil migrated or is two separate leaks.
    There was a guy from Hawaii on here who had symptoms like this. Was leaking through passages formed from machining the block or something to that extent. Toyota ended up installing a brand new shortblock under warranty. Time for a trip to the dealer to see what they say. Have just under 30k.
    Here is the post from the Hawaii guy http://www.tacomaworld.com/forum/2n...1gr-fe-oil-gallery-leak-initial-findings.html
  5. Oct 31, 2012 at 12:57 PM
    HawaiiTRD
    HawaiiTRD "Some people feel the rain, others just get wet"
    Hawaii
    2022 MGM DCSB TRDOR
    Diamondback SE, FITCAMX
    Could u post pics of it please? I have a 2010 at 30k miles and I want to check it when I get home tonight.
  6. Oct 31, 2012 at 1:01 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    My timing cover leaked as well on my 2006 but I got it fixed under warranty.
  7. Oct 31, 2012 at 1:26 PM
    Oscarbob
    Bob
    Central New York
    Here are some pics of my leaks. Not sure if there is migration of oil from front to back or if it is comng from two different sources - edit -sorry for the massive pics
    This is looking at the front of the engine at the bottom on the drivers side, Idler #1 and AC Compressor in the picture
    Another angle of the same area
    Rear of engine, looking at oil pan and bell housing. This was after I cleaned it up quite a bit trying to look for a source
    Looking "up" at the bottom of the oil pan, lots of oil and debris
  8. Oct 31, 2012 at 1:34 PM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
    Thanks for the pics :) I'll post on here what I find on mines when I get around to it
  9. Oct 31, 2012 at 2:45 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    If you guys are still under warranty I'd just take it back to the dealership since this is a known problem anyways. Like I said, they fixed mine without any hassle.
  10. Oct 31, 2012 at 2:46 PM
    Oscarbob
    Bob
    Central New York
    Have you had any issues with leaks since then?
  11. Oct 31, 2012 at 2:47 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Negative. Its been a couple years now and still no leaks and I check it every oil change to make sure.
  12. Nov 1, 2012 at 1:34 PM
    BlazeTaco
    PA
    4.0l 6sp SR5
    Well I am have an appointment to take mine in on 11/12. Last I look at mine it looked like it was coming from the right side of the cover. But it also looked wet under the harmonic balancer too. So I might have the same leak as Oscarbob.
  13. Nov 12, 2012 at 6:31 AM
    BlazeTaco
    PA
    4.0l 6sp SR5
    Well stealership says that seepage is normal. That enough wetness around the timing cover to cause drips of oil to blow back on the oil pan, but not drip on the ground is not a leak. I call B.S.:mad:. Then when I asked to talk to the mechanic they got all fluster, especially when I talked about the drips of oil.
  14. Nov 12, 2012 at 7:42 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I thought it was part of a TSB? Mine only leaked a few drops on the ground but they fixed it without any problems.
  15. Nov 12, 2012 at 8:37 AM
    BlazeTaco
    PA
    4.0l 6sp SR5
    My opinion is that the mechanic didn't want to do it since is a rather time consuming job. He just kept giving my excuses when I would counter what he was saying. I have been around cars all of my life, I know what an oil leak looks like. Its not a bad one yet, but its still a leak. The first thing they tried to say was it was from someone changing the oil and spilling it on it. B.S. I changed the oil and did not spill any on it.
  16. Nov 12, 2012 at 9:18 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I hear yah. I thought it was part of a Toyota TSB so you might want to look it up and if you can get paperwork on it then I'd print it out and take the truck back to them. I know its a slow leak but its still a leak and they need to fix it. :cool:
  17. Nov 12, 2012 at 9:30 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Typical Toyota quality and lack of dealer effort. Call corporate and get a claim number. They will insure the dealer does it's job.
  18. Jan 9, 2013 at 6:31 PM
    bmpskir
    bmpskir Well-Known Member
    Dover, NH
    2010 TRD sport DCLB 4.0 auto
    blazetaco - did you get any resolution to this?
