Urgent!!!2007 tundra caliper on 2003 tacoma???
Discussion in '1st Gen. Tacomas (1995-2004)' started by InsaneDriver, Mar 19, 2012.
  1. Mar 19, 2012 at 6:59 PM
    InsaneDriver
    InsaneDriver [OP] Member
    Puerto Rico
    03-SR5-4x4
    MT 285/75-16R Definity Dakota ( Low budget) All Bilsteins 5100 Eibach Coil AAL ToyTec Diff Drop Kit
    Hi to everyone, this is my first post. I want to know if is possible to fit a 2007 Tundra calipers in a 1st gen tacoma(2003 DC sr5)?? Im be looking for the specs of 2007-2011 tundra calipers but I cant find anything. Oh! And Sorry for my bad English im in little bit of rush using mi Iphone to write this! Help!!!
    Greetings from Puerto Rico.
  2. Mar 19, 2012 at 8:19 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    No. They may (or may not) bolt on, but the geometry+rotor size and pads are different
  3. Mar 20, 2012 at 8:47 AM
    InsaneDriver
    Puerto Rico
    03-SR5-4x4
    Thanks 1GR, I will replace the pads and rotor too, my question is if the tundra 2007-2011 calipers are going to fit bolt on like the calipers of the 2000-2005 tundra.
  4. Mar 20, 2012 at 11:11 AM
    InsaneDriver
    Puerto Rico
    03-SR5-4x4
    Any help?
  5. Mar 20, 2012 at 12:20 PM
    1GR
    Scott
    BC, Canada
    The hub centric rotors are too large from the 2007-2011 tundra.. 2000-2006 tundra same size hub as Tacoma second gen.
  6. Mar 20, 2012 at 2:34 PM
    1GR
    Scott
    BC, Canada
    You mean first gen...
  7. Mar 20, 2012 at 4:22 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    search big brake upgrade... i'm too lazy to find the thread for you but a guy was selling the parts and left links to a bunch of write ups in his description
  8. Mar 20, 2012 at 4:26 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  9. Mar 20, 2012 at 6:03 PM
    InsaneDriver
    Puerto Rico
    03-SR5-4x4
    Thank you very much! I just had a great deal for a 2009 tundra calipers but you just save me some time and money. Anyone know the caliper model number? for example I know that for the 00-06 tacoma could be 13WE (199mm) or 13WL (231mm), 07-11 tundra should be 13W_??
  10. Mar 21, 2012 at 4:43 AM
    98tacoma27
    Ben
    Not Beech Creek
    Aren't those rotors 5 lugs anyway?
  11. Mar 21, 2012 at 6:09 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Why is this in the 2nd gen Tacoma forum again?
  12. Mar 21, 2012 at 6:38 AM
    1GR
    Scott
    BC, Canada
    2007+ Tundra, yes. Until then, no. Same hub size, and bolt pattern as second gen Taco.
  13. Mar 21, 2012 at 6:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    That part I knew. :D
  14. Mar 21, 2012 at 8:05 AM
    InsaneDriver
    Puerto Rico
    03-SR5-4x4
    I did not know that 2007+ tundra are 5 bolt, thanks again. And what about 2007 calipers on 2005 rotors ?? :pout:
  15. Mar 21, 2012 at 2:25 PM
    1GR
    Scott
    BC, Canada
    No. The rotor is smaller on the 2005. Therefore, after mounting the Caliper, the pads will sit too far past the rotor. The top of the pads must be lined up with outside edge of rotor, and bottom of pads lined up with inside edge of rotor. (Vertically, not width) Hard to explain without diagrams/pointing at components.
    2000-2006 calipers must be with same pads and rotors, and must fit hub and bolt locations for caliper. Cannot cross over with 2007+ Components. Also, you are talking about first gen, which gets a little tricky depending if you have VSC or not etc. etc...
  16. Mar 22, 2012 at 12:10 AM
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
  17. Mar 22, 2012 at 12:17 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    x2
    go on customtacos.com
    a few of our So Cal buddies on there upgraded their brakes to Tundra rotors and pads, and it didn't cost as much as the aftermarket kits out there...
    i want to say that Jarret and/or Joel did write ups on CustomTacos about what parts you need and how to swap them out...
    once done, you can no longer run 15 inch wheels on the truck...
  18. Mar 22, 2012 at 12:20 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
  19. Mar 22, 2012 at 12:21 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    oops.. not Joel... the write up was from Tam Nguyen... i don't know if he still has the truck...
  20. Mar 23, 2012 at 8:39 AM
    InsaneDriver
    Puerto Rico
    03-SR5-4x4
