Urgent help required.... spark plug question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhowell, Feb 3, 2013.
  1. Feb 3, 2013 at 3:24 PM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    Just followed Chris steps to the tee. now when the truck starts up it is not making a good sound. I am afraid to start it up again. the only thing I noticed is I forgut to reconnect the surge tank hose could this be the problem?????
  2. Feb 3, 2013 at 3:26 PM
    rhowell
    Robert
    Canada
    All plugs came out no problem. All plugs had anti sieze put on and hand torqued to the end. The torqued to 15ft/lb (180in/lb). All in all it was a easy job. Cant see what could have went wrong.
    All spark plugs gapped to 0.41.
  3. Feb 3, 2013 at 3:26 PM
    RoninTaco
    RoninTaco Well-Known Member
    Scott
    Kansas City
    09 Off-Road Super White
    What kind of sound?
    Did it continue to run or did it stop running itself?
  4. Feb 3, 2013 at 3:28 PM
    rhowell
    Robert
    Canada
    Hard to describe. It continued to run. I stopped it myself. What do you think should I connect the surge tank and start her up again or should I re-check everything buy going back to the beginning.
  5. Feb 3, 2013 at 3:31 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Re check everything. Not pulling plugs yet just make sure all the coil packs are pushed on the plugs good and you didn't knock or leave any wire connection unhooked.
  6. Feb 3, 2013 at 3:35 PM
    rhowell
    Robert
    Canada
    Just plugged the surge tank hose and now everything sound normal again. Wholly shit my blood pressure is through the roof.
    What the hell does that surge tank do anyways. It was basically wistling with the hose out.
    I was just thinking to myself. Wow would my pap every be proud to see me turning into a little bit of a mechanic and then that happens.
  7. Feb 3, 2013 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    LOL!! Ive had that happen a co0uple times. I stand there scratching my head wondering WTF I missed :eek:
  8. Feb 3, 2013 at 3:48 PM
    RoninTaco
    Scott
    Kansas City
    I do believe if helps keep pressure in the fuel system at a constant so that when there is a momentary lapse in fuel because of air or something like that the fuel is still given to the rail.
    But that is just from preliminary investigative work.
  9. Feb 3, 2013 at 3:48 PM
    rhowell
    Robert
    Canada
    Dude, seriously..... where were you. The next time I have a spark plug realted question I excpect you to be the first to answer. I got to change my f'n shorts.
    Seriously though. Thanks for the write up.
  10. Feb 3, 2013 at 3:50 PM
    rhowell
    Robert
    Canada
    Thanks for taking a look. I will look into it myself.
    Next up is the dif oil change.............. with my luck I will probably leave the freakin fill hole open and drive it down the street.:mad:
  11. Feb 3, 2013 at 3:52 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Triple check you're not draining the transmission. Just a heads up!
  12. Feb 3, 2013 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Super Bowl is on. :eek:
  13. Feb 3, 2013 at 4:29 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Wait...Wut?
  14. Feb 3, 2013 at 4:37 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Front diff is tricky I used a hose thingy big pita
  15. Feb 4, 2013 at 6:53 AM
    rhowell
    Robert
    Canada
    Thanks everyone.
    One last question. Everything seems to be running great but I did use Champion Platinum plugs that were on sale for half price (2 for 10). Now I feel like I should have stuck with stock. Should I just leave em or swap em out.
  16. Feb 4, 2013 at 7:04 AM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Leave them!
  17. Feb 4, 2013 at 7:10 AM
    rhowell
    Robert
    Canada
    Thanks, next time I swap out I will go back to stock
  18. Feb 4, 2013 at 8:06 AM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I have the same exact plugs in mine. They've been in for over a year, mabye closer to two. I've had no problems, but the OCD side of me wants to take them out and put in factory Denso plugs instead. I'll just leave 'em.
  19. Feb 4, 2013 at 8:09 AM
    RoninTaco
    Scott
    Kansas City
    Haha yea leave'em, if you had blood pressure spikes with changing the first time maybe you should just wait a while until you put the OEM ones back in, give your heart a break :)
  20. Feb 4, 2013 at 8:10 AM
    Millertime187
    David
    Clay City, KY
    1995 Taco
