URGENT! MAF Cal. and Check Engine Light
Discussion in 'Performance and Tuning' started by NumNutz, Feb 19, 2009.
  1. Feb 19, 2009 at 4:38 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    So I have just installed my MAF Cal. from URD. Everything went smoothly but then when I start the truck the check engine light comes on.
    Any thoughts?
  2. Feb 19, 2009 at 4:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Did you disco the battery before installing?
  3. Feb 19, 2009 at 4:59 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    EDIT- lol... chris beat me to it...
  4. Feb 19, 2009 at 5:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I cant belive I even beat ya. :)
  5. Feb 19, 2009 at 5:15 PM
    Delmarva
    Tucson, AZ
    every now and then craziness happens... :laugh:
  6. Feb 19, 2009 at 5:36 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    No I actually didn't. I forgot to.
  7. Feb 19, 2009 at 5:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well. Disco the battery and let it sit for a while. Then reconnect, and you should be good.
  8. Feb 19, 2009 at 5:47 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Dang it. I thought you had it for a second. I called URD and Gadget told me to check my scanguage for an engine code.
    It is a low voltage code.
    Yes everything is connected correctly.
    Any ideas now?
  9. Feb 19, 2009 at 5:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Disco your battery and let it sit for a bit. Give it about 30 mins.
  10. Feb 19, 2009 at 5:54 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    I did it for 20 minutes earlier. I know its not thirty but I'll just give it more time.
    What is your reasoning behind? You can get technical.
  11. Feb 19, 2009 at 5:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It will allow your ECU to start fresh and learn the new addition right from the turn of the key. If the ECU senses a change in something from the last shut down to the next start up, it will trip a code. Thats why you need to disco the battery when adding engine mods.
  12. Feb 19, 2009 at 5:58 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    And that would be why I got a low voltage code?
  13. Feb 19, 2009 at 5:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could be.
  14. Feb 19, 2009 at 6:02 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Alright well it's unpluged. If this doesn't work do you have any other idea why the check engine light would come on?
  15. Feb 19, 2009 at 6:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im thinking about it right now. If you did nothing wrong, it should be only because you didnt disco the battery. You cleared the code before disco'ing your battery, right?
  16. Feb 19, 2009 at 6:06 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    On the scanguage?
  17. Feb 19, 2009 at 6:15 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    I got that code when tuning. If I set the fuel cells a little to low or high. You need to hook up your laptop and split second software to the calibrator, and make sure you got a good Map for your truck. I believe all the cells should be at 10 if you got it from URD. But double check.
    Hows it ideling?
  18. Feb 19, 2009 at 6:18 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Seemed a little low actually. I don't have a windows computer so I had to have URD do it. How do you even tune the Sensor? I don't see where you would plug it in or anything?
  19. Feb 19, 2009 at 6:28 PM
    roxspin72
    NC
    Oh Yeah!!!
    Unscrew the four screws on top the calibrator. Once opened you will see a serial port. You need to purchase a Serial to USB wire. Hook that up and run the Split second program.
    I highly suggest you find a buddy with a laptop and check this out. Definately should not have a CEL with a stock URD Map setting. And even the one I seen for TRD CAI, and exh was pretty much all 10's in each cel.
    When you get the software up check out this site:
    http://www.freewebs.com/mafmaps/05plustacoma.htm
  20. Feb 19, 2009 at 6:31 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    ...disco the battery? Haven't heard that one yet...
