Urgent problem zero electric power solved… I’m an idiot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SPARROW66, Jul 31, 2024.
  1. Aug 1, 2024 at 11:32 AM
    #61
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I mean, you could run a jumper from the battery + to the terminal in the fuse box.
    But that wont get the truck to crank.
    It would get the window up.
    The bigger the jumper wire. The better.
    Just don't crank the truck. You'll be pulling way to many amp through that small wire.
  2. Aug 1, 2024 at 11:32 AM
    #62
    SPARROW66
    SPARROW66 [OP] Well-Known Member
    RAYMOND
    OKC
    2015 DOUBLE CAB 4X4
    LED INTERIOR LIGHTS
    Well now get this I did put a jumper from battery to that positive stud in the box and it sparked like crazy. No blown fuses when it happened I don’t have any big cables here at the house but I’m working on getting some
  3. Aug 1, 2024 at 11:34 AM
    #63
    TnShooter
    Deogee
    STOCK
    Ok......hold on a sec.
    Take your voltage meter and go from the POSITIVE post of the battery, to the wire in the fuse box.
    Tell us what the reading is.......
    KEY OFF. Key off....... make sure the key is OFF.
    GilbertOz likes this.
  4. Aug 1, 2024 at 11:37 AM
    #64
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    did you try a voltage drop test. It’s how I would start diagnosis.
    https://youtu.be/xerAp9Yd53Y?si=kM2xNi-RovsZZa_T
  5. Aug 1, 2024 at 11:41 AM
    #65
    TnShooter
    Deogee
    STOCK
  6. Aug 1, 2024 at 11:45 AM
    #66
    SPARROW66
    RAYMOND
    OKC
    2015 DOUBLE CAB 4X4
    LED INTERIOR LIGHTS
    Key is in the house for safety
    12.34 volts
  7. Aug 1, 2024 at 11:47 AM
    #67
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    There is no power getting to the main positive feed post inside the fuse box. (If there was, this would read 0.0 volts, i.e. because the battery's positive voltage would be "getting to" that post inside the fuse box, as it should in normal circumstances.)
    The challenge w/ your setup is that folks on TW forums don't know the extent & details of the aftermarket changes that have been made to your stock wiring, to accomodate your 2nd battery, inverter, DC/DC, etc.
    So it's a bit of a mystery why there is no power getting to that post in the main (stock) fuse box in the engine bay. Are there aftermarket cut-out or transfer switches in your system? Are there other in-line fuses (for example in add-on fuse blocks and/or in-line "bullet" fuse housings on cables) that are part of your 2nd battery setup?
  8. Aug 1, 2024 at 11:51 AM
    #68
    GilbertOz
    GilbertOz Driver
    CA
    To be clear, I'm just asking if there are other switches, fuses, etc.
    Without knowing exactly what is going on or how things are set up I don't recommend "just trying stuff" as there is the potential to melt, burn, or blow out components accidentally.
    Jakerou likes this.
  9. Aug 1, 2024 at 11:51 AM
    #69
    TnShooter
    Deogee
    STOCK
    Yeah.......
    That means the cable in the fuse box is grounded somewhere.
    You need to trace the wire in the fuse box to where ever it goes.
  10. Aug 1, 2024 at 11:54 AM
    #70
    TnShooter
    Deogee
    STOCK
    Do you have a test light by chance?
  11. Aug 1, 2024 at 11:55 AM
    #71
    GilbertOz
    GilbertOz Driver
    CA
    Grounded, or I would think more likely disconnected (floating).
    OP this is a stretch, but do you have a clamp-style DC current meter? If yes, you could use that on the main + cable coming off your main battery (under the hood) to see if significant current is being drained by a partial short.
    I would not suggest using a traditional multimeter in-line for current diagnostics as those are limited to only 10 amps. (The multimeter's internal fuse will blow if >10 amps flows in current-reading mode.)
    Example of a clamp-style current meter:
  12. Aug 1, 2024 at 11:55 AM
    #72
    SPARROW66
    RAYMOND
    OKC
    2015 DOUBLE CAB 4X4
    LED INTERIOR LIGHTS
    The 2’d battery is a lionph battery that is only connected to the truck through a dc/dc charger that at the moment isn’t connected to the truck battery at all. Does the positive battery cable have a fusable link in it? Except for the winch (which isn’t connected right now). I haven’t don’t anything to the stock battery system
  13. Aug 1, 2024 at 11:57 AM
    #73
    SPARROW66
    RAYMOND
    OKC
    2015 DOUBLE CAB 4X4
    LED INTERIOR LIGHTS
    And yes that mess of wires is embarrassing but it’s worked the last year and I’m ripping everything out and reorganizing when I build a new platform back there.
  14. Aug 1, 2024 at 11:57 AM
    #74
    TnShooter
    Deogee
    STOCK
    If you go from + to + you should see 0v.
    I'd start by disconnecting the wire in the fuse box.
    And using a test light from battery - to the wire.
    Then from battery + to the wire.
    Again, wire not bolted to the fuse box.
    Confirm the issue.
    Then identify the cause.
  15. Aug 1, 2024 at 11:58 AM
    #75
    545
    545 Well-Known Member
    2015 Access Cab
    Has to be grounded, or it would read 0
    TnShooter likes this.
  16. Aug 1, 2024 at 12:00 PM
    #76
    TnShooter
    Deogee
    STOCK
    You can check wire via a resistance. Unbolt it from the fuse box, and the battery.
    Check resistance (continuity)
  17. Aug 1, 2024 at 12:00 PM
    #77
    GilbertOz
    GilbertOz Driver
    CA
    Oh, right. You're correct. My bad.
    It is grounded for sure. Through either a high-resistance or low-resistance connection, TBD.
  18. Aug 1, 2024 at 12:02 PM
    #78
    545
    2015 Access Cab
    What’s that black cable that comes over the top, with the big connection in the middle wrapped in tape?
    can you disconnect it and test positive to the terminal again?
  19. Aug 1, 2024 at 12:09 PM
    #79
    dfanonymous
    sound like he does have voltage from body ground to positive terminal.
    The point is to check positive battery terminal to positive cable, and negative post to negative cable. If both are “no voltage” then it’s the battery….
    if one cable is good and the other is 12v, then that cable is bad.
  20. Aug 1, 2024 at 12:30 PM
    #80
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I think I see the issue here, if the cable coming from that stud is the one I have circled in red it should be hooked up to the positive battery post not the negative.
