Urgg, lifted 2.5" now I have wicked vibes...
Discussion in 'Suspension' started by BenWA, Nov 20, 2010.
  1. Nov 20, 2010 at 5:17 PM
    BenWA
    BenWA [OP] Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    2006 4x4 double cab, 120K miles, just put on front 5100's set at 2.5". Did all the work myself by the book. No diff drop was installed.
    Had it aligned and I have WICKED vibes between 25 and 40 mph (I didn't even try driving faster than that for fear of blowing something up). I did the test that has been discussed a number of times to diagnose a potential front diff problem -- switched to 4H and, indeed, the instant I switched the vibes disappeared, and the instant I switched back to 2H the vibes re-appeared. I have read a number of posts here that suggest that this is indicative of a blown front diff bearing.
    But I called 3 different Toyota stealerships, 4 different 4wheelparts stores, and 1 Les Schwab store that does its own 5100 installs and none of the 10+ different people that I talked to at all these places had ever heard of such a thing. ALL the people I talked to said that they had never received one complaint about vibes developing after lifting a Taco 2.5" -- they've only heard of vibes with 3" or greater lifts. These places have collectively lifted hundres of Tacomas and this was a mystery to everyone.
    But there are threads upon threads here about vibes with as little as .85" of lift, so what gives???
    As of now, I am planning on disassembling everything and resetting to 0" lift so I have time to reassess the situation. Any thoughts?
  2. Nov 20, 2010 at 5:24 PM
    0BlackTaco6
    0BlackTaco6 Ive got tiger blood
    New Hampshire
    06 BSP DC SR5 4x4 6 speed
    Color matched and satoshi grille, hella 500ff behind, bhlm, sockmonkey bedsides, 17" sports 265/70 grabber at2's.
    intrigued on hearing responses. subbed.
  3. Nov 20, 2010 at 5:27 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    what do your cv joints look like
  4. Nov 20, 2010 at 5:36 PM
    BenWA
    Seattle @ 0.9 Mach
    In terms of condition, the boots are in perfect shape, no noticable play in the joints when I tried to wiggle things around, and no other indication that anything in the CVs was amiss. In terms of angles, they look no worse or better than any other CV angles I've seen pics of here of 2.5" of lift (but then again, why should they look any different).
  5. Nov 20, 2010 at 6:45 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    seems you have a 50/50 chance of getting these.i have the same thing,just not that bad.ive got almost 25,000 miles on it since i did the lift(2.5")and no problems.its almost not noticeable anymore.guess im just used to it.
  6. Nov 20, 2010 at 7:13 PM
    BenWA
    Seattle @ 0.9 Mach
    Yeah, it's weird to read all the different threads and posts in which about half of the people have vibe and the other half doesn't. It was especially bewildering to hear 3 dealerships, 4 4x4 shops, and one Les Schwab all say that they have never heard a single vibe complaint when I described the problem that I was having. I did not get the impression that any of these places were putting an overly positive spin on things, particularly because they knew that they had nothing to gain from me by making things sound better than they really are. Sounded to me like they honestly had never encountered such problems.
    What I should do it call some of the 4x4 shops in Hawaii. After all, there are more lifted Tacomas there than anywhere in the world, probably by a factor of 10! :D Out there, every 10th vehicle you pass on the road is a Taco, and probably a third of them are lifted.
  7. Nov 20, 2010 at 7:32 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    i feal your pain,i was going to put mine back to stock as well because i cant stand shit not being right.but time went by and never did.kids didnt want me to anyways.
  8. Nov 20, 2010 at 9:00 PM
    BenWA
    Seattle @ 0.9 Mach
    I'm on post #225 of 538 of that thread over in toyota nation about the front diff vibe issue (still reading posts from 2008, haven't gotten to any recent resolutions yet -- I should be to 2010 after another hour of reading :rolleyes:).
    The suspense is killing me.
    So far, the only solutions have been 1) a front diff replacement or 2) going back to stock ride height. :(
    The main thing I'm trying to determine is if this is something that causes permanent or catastropic damage to the front driveline, or if it's just an annoyance that can be lived with if one so desires.
    Here's the thread for anyone interested in doing a little light reading:
    http://www.toyotanation.com/forum/showthread.php?t=220615&page=16
  9. Nov 20, 2010 at 9:18 PM
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    look into the carrier bearing drop. that has worked for many people.
  10. Nov 20, 2010 at 9:22 PM
    Laroche33
    Laroche33 Active Member
    Massachusetts
    05 TRD Off Road
    2.5" lift in front, 2" aal in back
    i have the same vibrations i put in blistein 5100's at 2.5" and also have the vibrations it seems like ti si form 30-45ph
  11. Nov 20, 2010 at 9:45 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    1 piece drive shaft for the rear
  12. Nov 20, 2010 at 10:21 PM
    BenWA
    Seattle @ 0.9 Mach
    I'm on post #384 of that TN thread...lotttttts of reading :bored:
    The consensus so far definitely seems to be that the vibes are caused by the front diff bearing being shot at various mileages (some as low miles as 12K), which is exaccerbated (or possibly even caused by) lifting the front end.
    EVERYONE who is considering lifting their truck should read this long ass thread first. I'm hoping at this point that the damage is not irreparable if one chooses to go back to stock ride height. The cost of a front diff replacement out of warranty is in the neighborhood of $2K. :eek:
  13. Nov 20, 2010 at 10:25 PM
    BenWA
    Seattle @ 0.9 Mach
    I'm 99% certain that this is not a rear driveline issue, but rather a front diff issue. I have not done anything to lift the rear yet (not even TSB), and all my vibes are coming from the front...and disappear when the 4H is engaged. So far, everything I have read indicates that this is a shot bearing in the front diff. Seems to be essentially a design flaw of our trucks, unfortunately.
    I had really been hoping that our 2nd gen trucks would prove to be as reliable as their predecessors....but I'm worried now that this may not the case with regard to the front driveline of the 4x4's. :(
  14. Nov 20, 2010 at 10:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If it is a shot bearing, putting the shocks to 0 is not going to fix that. Why not invest the $30 is diff drop kit to see if it helps to put the axle angles back a little closer to stock.
  15. Nov 20, 2010 at 11:20 PM
    BenWA
    Seattle @ 0.9 Mach
    Because I've read numerous threads that conclude that removing the diff to install the diff drop can cause more harm than good. That, and 05Moose tried a diff drop with his 5100's set at .85" and at first thought it solved his vibes but then later realized that it didn't solve as much as he had thought.
    Check out Moose's posts in this thread:
    http://www.tacomaworld.com/forum/2n...-30-40mph-after-5100s-installed-1-75-a-2.html
    Unfortunately, I think the driver's side bearing in the front diff is starting to sound like it's a serious design flaw in our 2nd gens, and it's a problem that seems to be amplified/manifested when these trucks are lifted, even as little as an inch or two.
    It's a bummer that the symptoms may not manifest until the warranty is expired. Sounds like a LOT of folks have had their front diffs replaced under warranty because of this vibe issue. At nearly 120K, my warranty is a thing of the distant past. Shittiest news I've heard all week.
  16. Nov 20, 2010 at 11:23 PM
    BenWA
    Seattle @ 0.9 Mach
    This is a major bummer. Besides this and the other threads I linked to, is anyone aware of this front diff problem being discussed at length in other threads? I did a search and didn't come up with much.
    I'm surprised this hasn't become a recall issue yet.
  17. Nov 21, 2010 at 11:23 AM
    Sprink669
    Sprink669 Well-Known Member
    Ok, I have a 2010 DBL cab off road. I installed the OME 886's and the dakar leaf pack. I have a ARB bumper and winch on the front so I needed the 886's I do believe that it rides pretty close to stock but it handles way better. I needed the swaybar relocation (I know I should have just removed it). I drove it for a while without an alignment and I had a minor vibration at around 20-30. Nothing major, I went ahead and ordered the diff drop and it got al little better but did not solve the problem. So, I went to summit racing and got 3* shims from Skyjacker for about $12 and installed them today and bam it is gone. I also greased all the u-joints, seems like Toyota skimped on the grease from the factory. It seemed like I put a ton of grease in each joint.
  18. Nov 21, 2010 at 11:29 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    a lot to read but before you go blow tons of money on front diff this and that (which to me makes no sense...the front end is always rotating whether it's in 4wd or 2wd) ANYWAYS...ALL of my vibration issues were because of my tires. i tried this, that, and the other and finally gave up. then i got new tires, and and therefore a new balance and presto - no vibes. i'd try that first before you go tearing the front end apart, worth a shot
  19. Nov 21, 2010 at 11:37 AM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    Which shims? For where?
  20. Nov 21, 2010 at 11:49 AM
    CopDoctor
    08 335i
