USA Spec PA-15 Location ?
Discussion in 'Audio & Video' started by OZ-T, Feb 15, 2012.
  1. Feb 15, 2012 at 7:25 PM
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Were is everybody mounting the actual PA-15 box itself , and is it important to be able to access it ?
    Thanks in advance all
  2. Feb 15, 2012 at 7:28 PM
    OZ-T
    Peter North
    British Columbia
    Is there any need to access it after the initial install ?
  3. Feb 15, 2012 at 7:28 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    I opened my glove box, pulled it out, stuck the actual box in the small space that exists between my glove box and the dash. Left the wire running into my box, allowing access to the ipod itself, hiding the box, and keeping a clean look
    @ OZ: nope.
  4. Feb 15, 2012 at 7:30 PM
    OZ-T
    Peter North
    British Columbia
    Thanks
    You mean the RCA jacks on the unit itself ?
  5. Feb 15, 2012 at 7:33 PM
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
    Mine is underneath the cup holder. I ran the iPhone cable out into the slot next to the shifter, and ran another cable up to a 3.5mm input that I installed on my dash (in the blank opposite my 4x4 switch). It works fantastic.
    I can only see needing to get at the unti itself if you wanted to add an additional Aux input or something like that.
  6. Feb 15, 2012 at 7:35 PM
    OZ-T
    Peter North
    British Columbia
    Actually saw that in the other thread
    I searched first :D
    Thanks
  7. Feb 15, 2012 at 8:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I used double sided tape, and stuck it to the fire wall, above, and right of the throttle. THat way, I have access if needed, and its out of the way. I keep my Ipod in the little "cubby" to the left of the steering wheel.
  8. Feb 15, 2012 at 8:20 PM
    OZ-T
    Peter North
    British Columbia
    Thanks 16
  9. Feb 15, 2012 at 8:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    anytime ZO-T
