USB not charging Magsafe
Discussion in '3rd Gen. Tacomas (2016-2023)' started by john_t, Jan 2, 2022.
  1. Jan 2, 2022 at 9:21 AM
    john_t
    john_t [OP] Well-Known Member
    MA
    2018 Tacoma MGM Limited DCSB
    I set up an Apple MagSafe disc charger on a phone holder and connected it to the USB port on the center console. I got a USB-C adapter plug as well. When I place the phone on Magsafe, the green charging screen on Iphone pops up with % status. However, the charging doesn’t continue. After a while the phone isn’t charging. Any ideas? Maybe not enough wattage for Magsafe?
  2. Jan 2, 2022 at 9:24 AM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    On my 2020, the USB on the dash is for media. The two under the lid of the center console are for charging stuff.
    OmahTako likes this.
  3. Jan 2, 2022 at 9:25 AM
    john_t
    MA
    I meant center console, just fixed it.
  4. Jan 2, 2022 at 9:29 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yes, the built-in USB port on 2nd and 3rd gen Tacomas do not supply enough power so when your phone does the handshake with the wireless charger and then the charger starts pulling a lot of current, the Stereo (head unit) sees this and disables the USB port.
    You'll never get this to work with the built-in USB port and you'll have to supply your own USB port that can supply the necessary power.
  5. Jan 2, 2022 at 9:32 AM
    mattsolnitzky
    mattsolnitzky Well-Known Member
    2021 TRD Sport
    Timely post. I was just about to order a MagSafe charger and wireless car play adapter. I’ll guess I’ll have to reconsider my plans.
  6. Jan 2, 2022 at 9:33 AM
    BMH
    Bruce
    A quick google search says the mag charger pulls up to 3 amps. I believe (Don't set in stone) the charging ports on the Tacos are 2-2.5 amps (?) ... Maybe that's the prob? IDK...
  7. Jan 2, 2022 at 9:40 AM
    john_t
    MA
    That makes sense. I might try a power brick connected to the lighter port. Or get another offbrand magsafe charger. More research needed…
  8. Jan 2, 2022 at 11:26 AM
    andrewbrandon19
    andrewbrandon19 Well-Known Member
    A cigarette lighter quick charge outlet would do. Give or take $10-15 for a single outlet 3.0 quick charge and $20-30 for a dual outlet if you need them.
    Edit: here's what I use and it works well.
    https://www.amazon.com/dp/B01K9MQ8WW?_encoding=UTF8
  9. Jan 5, 2022 at 1:58 PM
    john_t
    MA
