USB Not Charging
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crazytx, Oct 18, 2015.
  1. Oct 18, 2015 at 8:14 PM
    crazytx
    crazytx [OP] Member
    ALABAMA
    Went from 2002 Toy Taco to 2016 DC trd of
    Hey Guys,
    I just realized today that my usb outlet does not charge my phone. i have a Sony Xperia. Has anyone one else had the same problem?
    The cable I used is functional. I plugged it into my computer and it worked just fine.
  2. Oct 18, 2015 at 8:16 PM
    WhiteMud
    WhiteMud Well-Known Member
    British Columbia
    2017 DCSB TRD Sport
    Try another device, and if not call your dealership. One of the perks of warranty.
  3. Oct 18, 2015 at 8:17 PM
    BlazingInfernoTaco
    BlazingInfernoTaco Well-Known Member
    Fort Worth, TX
    2016 Inferno Tacoma TRD Sport SB/AT "PreRunner"
    Have you tried a different cable in the Taco? I had a cheapo iPod usb cable (Dynex) and it would NOT work in the Taco but worked just fine in my Mazda. Plugged in an Apple cable and everything was fine, iPod was recognized and played just fine.
  4. Oct 18, 2015 at 8:20 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    turn off the phone and look at the battery before you turn off. Drive somewhere with it plugged in. Turn on when you get there and look at battery. If it raised at all, it was charging.
    your phone is probably using as much wattage as the charger is providing while it's turned on.
    smitty99 likes this.
  5. Oct 19, 2015 at 12:12 AM
    Chaboi
    Chaboi Well-Known Member
    USB 2.0 won't charge some phones especially those with large capacity batteries. Get a car charger and plug it into the 12v outlet.
    smitty99 and TacoBella like this.
  6. Oct 19, 2015 at 2:33 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    This.
  7. Oct 19, 2015 at 5:40 AM
    knhorn
    knhorn Well-Known Member
    San Diego
    2016 TRD Sport DCSB Quicksand
    Icon Stage 5 set at 3", Toyo ATII, Fuel Throttle
    Are you trying to charge it while the truck is turned off? The truck needs to be running or engaged for the power outlets to work.
    crazytx[OP] likes this.
  8. Oct 19, 2015 at 7:20 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    this may be your issue.
  9. Oct 19, 2015 at 7:29 AM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    Yeah my USB drive doesn't charge my phone, but I plug in my flash drive and it plays the music off my flash drive. I just charge my phone using the 12v outlet.
    TacoBella likes this.
  10. Oct 19, 2015 at 7:31 AM
    8bitaudio
    8bitaudio Member
    2016 Tacoma Blue JBL + Tech Package
    Yeah this may end up being your issue. Had my Note 4 plugged into the USB on a Nissan Altima, phone would not charge.
    When you plug it in does it at least show your phone is receiving a charge?
  11. Oct 19, 2015 at 9:31 AM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    Same except I use the Qi Wireless Charger. USB is for music
  12. Oct 19, 2015 at 12:57 PM
    crazytx
    crazytx [OP] Member
    ALABAMA
    I figured it out. My phone is just power hungry. In order for it to indicate charging I have to turn my phone off while it's plugged in.
  13. Oct 19, 2015 at 1:42 PM
    BlkTaco47
    BlkTaco47 Unhinged
    Makes sense, with it on it's drawing too much power and the 2.0 USB doesn't support that.
  14. Oct 19, 2015 at 5:02 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    thanks for thanking me
  15. Oct 19, 2015 at 5:45 PM
    BillyM67
    BillyM67 Well-Known Member
    2014 Silver Avalon Limited
    So, basically, Toyota put a cheap under powered USB (the only one) in their "brand new" 2016 truck? :eek: :annoyed: The USB's in my 2014 Avalon charge my new Samsung S6 and my wife's iPhone 6 without a problem. :thumbsup:
  16. Oct 19, 2015 at 6:09 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    What is the amp rating of the built-in USB port?
    Maybe a high-capacity 2.4A USB adapter that plugs into the 12v outlet would work?
    0uTkAsT likes this.
  17. Oct 19, 2015 at 7:28 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    This is realistically the best option.
    I have noticed my self the USB port in the car charges very slow. It is a USB 2.0 and I'm giving the comparison to the USB 2.0 ports on my desktop(old pc). The specifications for USB 2.0 is up to 500mA. I was reading the manual and it was saying that the USB port is iPod/iphone compatible and that you can hook up USB memory sticks with music on it. I'm thinking the USB port is probably intended more for the entune to get data rather than for it to be used as a charger.
    A lot if not all the electronics are not made by toyota rather by the lowest bidder so it is possible that in order to cut costs they used cheaper parts that don't necessarily put out 500mA. I kinda find it junk anyways, apple compatibility only? Because no one uses android obviously. I'm going to install my own wireless charging and I can say good bye to wires all together. Just put the phone down, have it charge while playing off bluetooth which connects automatically.
    0uTkAsT likes this.
  18. Oct 25, 2015 at 5:26 PM
    Tiny
    Tiny Well-Known Member
    2016 Base. 4x4, 5-spd, 2.7L Access Cab.
    I came across this problem today. The USB port charges my E-cig just fine, but won't charge my phone at all. My trusty cheapass 12v cig-lighter adapter DOES charge my phone, which lead me to realize that this truck doesn't actually have a cigarette lighter for the cigarette lighter port it comes with. I don't smoke real cigs anymore, but that cherry-red firestarter has come in handy a few times in the past when camping. Can you buy those aftermarket? Will they still work like the old ones, where you push it in to heat it up and it pops out when it's super-hot and ready?
  19. Oct 25, 2015 at 6:09 PM
    Sep1911
    2016 Taco
    Toyota offered a smokers package. I wonder if you can just buy the lighter from Toyota
  20. Oct 28, 2015 at 9:08 AM
    Haikin
    Haikin Well-Known Member
    Funny thing is my 16 is doing the opposite of this. I can charge my phone via USB but it will not recognize or detect it as a source for audio, and it also will not detect the audio files on a thumb drive either. Thoughts?
