USB Phone connection NOT Android Auto
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ethbutt, Jan 4, 2024.
  1. Jan 4, 2024 at 2:23 PM
    Ethbutt
    Ethbutt [OP] Member
    2019 Tacoma SR5
    In order to try to reduce my exposure to EM Radiation, I want to connect my phone to my truck's stereo for calls and audio using the USB. 2019 Tacos factory stereos are not compatible with Android Auto or Apple Car play from what I can gather.
    I am unable to connect using a USB data cable. Is this because it is impossible, or is it due to some electrical or other fault?
    Thanks!
  2. Jan 4, 2024 at 2:29 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    I used to be able to plug my phone into the usb thing under the radio and get to my music and stuff. this worked with an old ipod nano i had too.
    unfortunately, it stopped working sometime this last fall. my gf plugged her phone in, something popped, and it hasn't worked since
    ¯\_(ツ)_/¯
  3. Jan 4, 2024 at 3:45 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    You don't need Carplay or AA for connection. Only one port in the truck is a media port and that is the one under the AC controls. The ones in the center console are only chargers.
  4. Jan 4, 2024 at 3:46 PM
    Ethbutt
    Ethbutt [OP] Member
    2019 Tacoma SR5
    Thanks! Unfortunately that's the one I was trying
  5. Jan 4, 2024 at 3:59 PM
    TacoSupremo19
    NJ
    Ok. Just had to clarify. You've selected USB as your source?
  6. Jan 4, 2024 at 4:01 PM
    Ethbutt
    Ethbutt [OP] Member
    2019 Tacoma SR5
    So USB is not a recognized option when the phone's plugged in. It is not selectable for me.
  7. Jan 4, 2024 at 4:09 PM
    TacoSupremo19
    NJ
    It should go from grayed out to selectable. I assume you used a known working cable and have no problem with your phones port. Did you buy this truck used?
    TreeFortRichard likes this.
  8. Jan 4, 2024 at 4:12 PM
    Ethbutt
    Ethbutt [OP] Member
    2019 Tacoma SR5
    It's a brand new data cable. I did buy the truck used. I haven't had any other issues with my phone's port. The phone will charge when plugged in. I'll see if the phone's port needs some cleaning, and I'll try to perform a data transfer test on another device.
  9. Jan 4, 2024 at 4:16 PM
    TacoSupremo19
    NJ
    It sounds like your problem is with the truck. That cable goes up and plugs into the back of the stereo. Either there's something wrong with the port, the cable, or it's not plugged into the stereo.
  10. Jan 4, 2024 at 4:17 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Have you tried cycling your phone and then unpairing then repairing? Every once in awhile that’s what end up having to do. Then it works fine for several months.
  11. Jan 4, 2024 at 4:18 PM
    Ethbutt
    Ethbutt [OP] Member
    2019 Tacoma SR5
    Thank you for taking the time to walk me through your thought process. I'll post here if I ever get this fixed.
  12. Jan 4, 2024 at 4:18 PM
    Ethbutt
    Ethbutt [OP] Member
    2019 Tacoma SR5
    Bluetooth pairing?
    Bluetooth works fine. My goal is to connect with USB.
  13. Jan 4, 2024 at 4:40 PM
    TacoSR523
    TacoSR523 Well-Known Member
    VA
    2023 Tacoma SR5 Barcelona Red
    Just a few accessories, mud flaps, bed cover , racks, seat covers, ….
    I think truck must be in park position , Apple does not allow usb connection while driving.
  14. Jan 4, 2024 at 4:47 PM
    Ethbutt
    Ethbutt [OP] Member
    2019 Tacoma SR5
    Thank you. I was in park while trying to achieve connection so I don't think that's it.
    TacoSR523[QUOTED] likes this.
  15. Jan 4, 2024 at 4:50 PM
    Stevie17
    Stevie
    Crossville, Alabama
    No not blue tooth , using the port with a usb cable. You can always try spraying some contact cleaner in the port and see if that helps.
  16. Jan 4, 2024 at 5:02 PM
    Ethbutt
    Ethbutt [OP] Member
    2019 Tacoma SR5
    Okay I'll try that!
  17. Jan 4, 2024 at 5:18 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    Did you check the outlet in the center console? maybe the previous owner switched them?
  18. Jan 4, 2024 at 5:30 PM
    Ethbutt
    Ethbutt [OP] Member
    2019 Tacoma SR5
    Hmm I'll check that thanks!
