USB port amperage?
Discussion in 'Technical Chat' started by Paleus, Aug 4, 2014.
  1. Aug 4, 2014 at 7:21 PM
    Paleus
    Paleus [OP] Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
    Does anyone know the output of the factory USB port? My phone (Nexus 4) will charge very slowly when plugged into the factory USB port. If I am listening to music from my phone through the head unit, it still discharges even when plugged in. If it is limited to 500mA, that would explain it. Has anyone tried using a charge only cable with the data pins shorted to charge at a higher rate?
  2. Aug 4, 2014 at 7:48 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  3. Aug 4, 2014 at 8:09 PM
    froh
    froh Beachin' Storm Trooper
    Dave
    Wilmington, DE
    2015 DCSB Storm Trooper
    Avid Light Bar and Hitch Step, Fold-a-cover G4 Tonneau, Weathertech mats, No-Drill Front Plate, Flyzeye Interior lights, Matt Gecko's LED Bed Lights with Remote, Rear Window Security Bar, Pop & Lock, Android Auto, LED Bar, Relentless Fab Tailgate Reinforcement
    Dude, i had the same problem... The Aux USB sucks for charging. If I ran GPS or webex apps, my battery would still drain while charging. I found a sweet low profile charger called Volt Ranger (Stupid name, i know). It offer two usb ports, one which is 2.1 output amps.
  4. Aug 5, 2014 at 5:01 AM
    Paleus
    Arkansas
    '13 DCSB TSS 4x4
    Well that's a bummer. Guess I will have to get a 12V to USB adapter. It sucks because the 12V outlets are right over the cupholder. I might try mounting some USB charging ports in one of the blanks next to the factory USB port. Thanks for the responses.
