USB problems
Discussion in 'Audio & Video' started by 07TacoRidah, Mar 27, 2013.
  1. Mar 27, 2013 at 11:43 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    Pasadena CA
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    I have a Pioneer DEH-5000UB
    http://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/DEH-P5000UB
    used to plug up my Nokia Node E73 to it for charging and MP3's on it. Kept on getting this message on the h.u. after a while of plugging up (Error - 19). So then I stopped and got myself a USB flash card reader from Fry's. Which was about maybe a month or two ago, WORKED GREAT ... until yesterday. I started to get the same message again (Error - 19). Tested the USB card reader and it doesn't even read ANY CARD (it says 5 in 1 but so far I have only used my Micro SD and a DLSR SD card in it - tried BOTH yesterday and NOTHING). I tested both cards - one via my cell to comp, WORKED. DSLR card, on my moms card reader WORKED.
    Is my USB cord from the h.u. causing problems? The USB card reader died oddly yesterday. One minute I'm playing music fine like I usually do, and then within maybe 5 minutes of music it goes dead and I get the Error - 19 message on the h.u. Although this h.u. is fairly old, it still works like new imo. I baby it and ONLY use the remote. I sweat from time to time so I don't like putting finger prints all over it or the dash ... or pretty much anything in my truck.
  2. Mar 27, 2013 at 4:41 PM
    pinktaco808
    pinktaco808 Hot Steppa
    what does it say in the manual about the error message 19?
  3. Mar 27, 2013 at 4:47 PM
    Aw9d
    Aw9d That one guy
    Az
    The manual doesn't list error 19, you'd have to call pioneer.. My GUESS is that your phone is requiring more amps to charge/connect than what the pionner deck is able to output. My avh3300bt won't play nice with a lot of external hard drives unless they are low powered. I'd call pionner and ask them what that code really means.
  4. Mar 28, 2013 at 7:35 PM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    From a Pioneer manual:
    Error-19
    Cause - Communication Failure
    Action - Perform one of the following operations
    - Turn the ignition switch OFF and back ON
    - Disconnect or eject the external storage device
    - Change to a different source. Then, return to the USB or SD source.
    What's the cause? Dunno, but I would suspect the USB cable first just because.
  5. Mar 28, 2013 at 8:06 PM
    TreeFortRichard
    TreeFortRichard Going to hit 100K this month...
    Massachusetts (Central)
    '10 Access 4x4 SR5 Manual
    some advice on that...I always use a usb extension cable for electronics with permanent usb connections...that way I always leave the cord plugged in and the extension cable bears the wear of all the insertion and removal cycles...
    It's possible you damaged the usb port..
  6. Mar 31, 2013 at 11:49 PM
    07TacoRidah
    Pasadena CA
    did some testing:
    1. something is wrong with the card reader. plugged it up to my comp, comp knows it's there and shows up BUT when I have a card inserted into either port, the reader won't read it.
    2. usb cord. when I was using my cell phone for music and charging, it was the usb cord. I tested it on my comp with my phone, and it wasn't working. I had a spare (one that I kept at the house and on my comp), used it and worked like nothing.
    Question:
    I was speaking with my cousin about usb cords. he said that when using usb extensions, the current or what have you going through the usb cord will weaken. The usb extention that I was using is fairly long (not sure but it could be 6 ft.), could the pairing up with the h.u. usb be the cause of things? I want to unplug the h.u. extension and swap it for the usb cable that I was using (it has the plug for my phone), or is that a bad idea?
