USB storage limits?
Discussion in 'Audio & Video' started by Mad Irishman, Apr 8, 2014.
  1. Apr 8, 2014 at 9:51 PM
    Mad Irishman
    Mad Irishman [OP] Member
    Austin
    PreRunner SR5 TSS
    My '14 has the "plus" stereo and I've been trying to use the USB with a 32Gb flash drive to play my music. The flash drive will hold multiple thousands of songs but the most the stereo will recognize is 497 (apple AAC/M4a format) or 499 (mp3 format). Anyone else run into this issue? Page 132 of the owners manual seems to indicate the limit should be 9999 files.
  2. Apr 9, 2014 at 5:44 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Are they in folders on the USB stick, or just files at the top level? If files, you might try using folders to see if that limit can be bypassed that way.
  3. Apr 9, 2014 at 10:44 AM
    Mad Irishman
    Austin
    PreRunner SR5 TSS
    They aren't in a folder. That's a good idea. I'll give it a try and see if that helps.
  4. Apr 9, 2014 at 12:25 PM
    Mad Irishman
    Austin
    PreRunner SR5 TSS
    That did it. I'm able to hold 500 songs per folder and it still reads it as one single library of music (just with a higher track total). Thanks Lurkin!
  5. Apr 9, 2014 at 12:30 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    NP, haven't dealt with the Toyota unit, but I know the aftermarket HUs implementation of USB is minimal and "ify", so you need to go back to basics sometimes.
  6. Apr 11, 2014 at 10:39 AM
    trdspectacoma
    trdspectacoma Well-Known Member
    B.I Hawaii
    13 dCab preRunner
    i can put 255 per folder and that should work.
